Home » Eclipse Projects » Rich Client Platform (RCP) » Menu entry enabled when a certain key is pressed
Menu entry enabled when a certain key is pressed [message #513107] Mon, 08 February 2010 15:49 Go to next message
I have a menu consisting of multiple menu entries. All the menu entries are contributed via org.eclipse.ui.menus extension point in my plugin.xml. Each menu entry is a command that has a default handler assigned.
I want to show one of the menu entries only if the CTRL key is pressed.
From the description of the above extension point I think that I should use "enabledWhen" but I do not know what to put next.
Or is there another way to achieve this?
Re: Menu entry enabled when a certain key is pressed [message #513240 is a reply to message #513107] Tue, 09 February 2010 08:29 Go to previous messageGo to next message
I don't believe there's a way to achieve this unless you are writing the
SWT yourself. You would basically have to know that there was a
SWT.KeyDown event and then your SWT.Show event for the Menu (without an
SWT.KeyUp event or a second SWT.KeyDown)
There might be another way, but I don't know it.
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Menu entry enabled when a certain key is pressed [message #513525 is a reply to message #513107] Wed, 10 February 2010 08:37 Go to previous message
Hello Paul
1. I 'hacked' something and it seems to work (see the code bellow). My only problem now is that I do not know how to add my test action from the code bellow to the menu defined in the plugin.xml Sad
2. Is my 'hack' bellow correct or do I need to do additional stuff?
3. How is a key binding defined in plugin.xml used? I mean who links the key sequence of a key binding to the actual command?
public class ApplicationActionBarAdvisor extends ActionBarAdvisor {
  private static boolean ctrlPressed = false;
  static {
    PlatformUI.getWorkbench().getDisplay().addFilter(SWT.KeyDown,
        new Listener() {
          public void handleEvent(Event e) {
            if ((e.keyCode & SWT.CTRL) != 0) {
              setCtrlPressed(true);
  private static void setCtrlPressed(boolean b) {
    ctrlPressed = b;
  private boolean getCtrlPressed() {
    return ctrlPressed;
  public ApplicationActionBarAdvisor(IActionBarConfigurer configurer) {
    super(configurer);
  protected void fillMenuBar(IMenuManager menuBar) {
    final IMenuService menuService = (IMenuService) PlatformUI.getWorkbench()
        .getService(IMenuService.class);
    AbstractContributionFactory factory = new AbstractContributionFactory(
        "menu:org.eclipse.ui.main.menu?after=myHelpMenu", null) {
      public void createContributionItems(final IServiceLocator serviceLocator,
          final IContributionRoot additions) {
        final MenuManager testMenu = new MenuManager("TestMenu");
        testMenu.setRemoveAllWhenShown(true);
        testMenu.addMenuListener(new IMenuListener() {
          public void menuAboutToShow(IMenuManager manager) {
            if (getCtrlPressed()) {
              testMenu.add(new Action("TestAction") {
                public void run() {
                  IWorkbench workbench = PlatformUI.getWorkbench();
                  IBindingService bindingService = (IBindingService) workbench
                      .getService(IBindingService.class);
                  bindingService.openKeyAssistDialog();
              setCtrlPressed(false);
        additions.addContributionItem(testMenu, null);
    menuService.addContributionFactory(factory);
Re: Menu entry enabled when a certain key is pressed [message #513570 is a reply to message #513525] Wed, 10 February 2010 05:28 Go to previous message
Catalin Gerea wrote:
> Hello Paul
> the code bellow to the menu defined in the plugin.xml :(
Your plugin.xml menuContribution can specify a class attribute that
points to your ContributionFactory.
As long as someone has pressed CTRL even once, you will always see your
menu.
keybinding sequence -> command id is done in the plugin.xml. Then
command id -> handler is done either in the plugin.xml or in the code
(IHandlerService.activateHandler(*))
PW
Paul Webster
Previous Topic:ContainerSelectionGroup -- advice on reuse?
Next Topic:Eclipse/RCP Application installed on Network Drive Bug
Current Time: Tue Jul 22 22:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.28466 seconds
