Home » Modeling » Epsilon » regarding Eugenia generated diagram(evaluating evl constraints on diagram and seeing markers)
regarding Eugenia generated diagram [message #513361] Tue, 09 February 2010 15:54 Go to next message
Dear Dimitris,
I am new to epsilon environment. I am interested in Graphical modeling and validation languages. I must say that epsilon has almost all i need to workout with my research at the moment. I was thinking to start GMF but decided epsilon as alternative. Now coming to the actual point, I followed the eugenia/evl example and generate graphical editor for creating and evaluating constraints on model. I bind the evl constraints with eugenia. Than i started building my own example. I cannot see validate button in my build example diagram menu. i can get error marker in the tree view but in diagram i cannot see them. Even though its not the problem in the filesystem example. my question is
- Do i need to extend the .diagram and add new extensions to it? in order to see markers on the diagram, or i am missing something?
what is the best way of dealing with such an issue? or if there is some example which can go through how to create markers which can appear in case of failure constraints?
thank you very much
saad
[Updated on: Tue, 09 February 2010 15:58] by Moderator
Re: regarding Eugenia generated diagram [message #513387 is a reply to message #513361] Tue, 09 February 2010 18:00 Go to previous message
Hi Saad,
In Galileo, "Validate" has moved under "Edit" (in Ganymede it is under
"Diagram")
Dimitris
saad bin abid wrote:
> Dear Dimitris,
> thank you very much
> saad
Re: regarding Eugenia generated diagram [message #585971 is a reply to message #513361] Tue, 09 February 2010 18:00 Go to previous message
Hi Saad,
"Diagram")
Dimitris
> Dear Dimitris,
> thank you very much
> saad
Previous Topic:regarding Eugenia generated diagram
Next Topic:[EVL] word "model"
Current Time: Sat Jul 26 23:25:21 EDT 2025
Powered by FUDForum. Page generated in 0.25215 seconds
