Home » Eclipse Projects » Eclipse Platform » Prevent file from being commited to CVS
Prevent file from being commited to CVS [message #509364] Fri, 22 January 2010 04:20 Go to next message
Regard the following scenario:
1. I have made some local changes to a file that is under CVS control
2. I know that I will never (and should not!) commit these changes back to CVS (e.g. I activated some debug code that is only necessary for local debugging)
What I want is to "lock" the file locally. That is, I am not able to commit this file to CVS. But a CVS sync will still show me if a new version exists (and I can merge locally). Of course, I should be able to remove the lock when I reverted my temporary changes.
Re: Prevent file from being commited to CVS [message #509578 is a reply to message #509364] Sat, 23 January 2010 02:27 Go to previous messageGo to next message
> local debugging)
In 'Team Synchronizing' perspective, right click on an outgoing change
-> add to .cvsignore.
Re: Prevent file from being commited to CVS [message #510323 is a reply to message #509578] Wed, 27 January 2010 04:34 Go to previous messageGo to next message
But wouldn't the .csvignore file be committed to the CVS server? Thus, everybody else would not be able to commit this file? As mentioned before, the file in question is already under CVS control, I just want to make the sure that my temporary changes are not committed accidentally.
Re: Prevent file from being commited to CVS [message #510693 is a reply to message #510323] Thu, 28 January 2010 06:06 Go to previous messageGo to next message
I'm afraid there is currently no way to achieve that. You could try creating a global ignore pattern on the Team>Ignored Resources preference page, but my guess is it won't work neither. Your scenario sounds reasonable to me, so you could open an enhancement request on Eclipse bugzilla. In the meantime, please have a look at bug 112549 which looks similar.
Re: Prevent file from being commited to CVS [message #511234 is a reply to message #510323] Sun, 31 January 2010 10:50 Go to previous messageGo to next message
On 1/27/2010 3:04 PM, Axel Mueller wrote:
> Quote:
Add .cvsignore to .cvsignore as well.
Re: Prevent file from being commited to CVS [message #511302 is a reply to message #511234] Mon, 01 February 2010 03:20 Go to previous messageGo to next message
Unfortunately, the .cvsignore trick does not work. Eclipse greys out the "Add to .cvsignore" option if the file is already under CVS control. Manually adding the file to .cvsignore does not work either. It seems .cvsignore (and Eclipse) ignores files that are under CVS control. The same holds for the Team>Ignored Resources preference page.
There are some similarities between my request and this bug, but I guess I have to open a new bugzilla request.
(see https://bugs.eclipse.org/bugs/show_bug.cgi?id=301389)
[Updated on: Mon, 01 February 2010 03:25] by Moderator
Re: Prevent file from being commited to CVS [message #513304 is a reply to message #511302] Tue, 09 February 2010 12:37 Go to previous message
On 2/1/10 3:20 AM, Axel Mueller wrote:
> Quote:
By the way, that's a feature of cvs (not Eclipse-specific); once a file
is known in the repository it can't be ignored. I suppose an
administrator could manually remove it from the repository, which makes
cvs "forget" that it ever knew the file. But IIUC that's not a solution
to the original problem discussed here.
Eric
Previous Topic:Editor association seems broken in Helios
Next Topic:Customizing tooltip for Eclipse perspective
Current Time: Wed Jul 23 12:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.07309 seconds
