Home » Archived » DSDP - Mobile Tools for Java (MTJ) » De.schlichtherle.io - file is read-only!(CLDC and MIDP - Errors running builder)
De.schlichtherle.io - file is read-only! [message #509297] Thu, 21 January 2010 16:31 Go to next message
I'am facing this problem again. I'am using XP, Vista, PC and/or a notebook with eclipse 3.5.1 (EE) + MTJ 1.0.1 + Floggy 1.3.1, but I have no idea how to fix it.
Does someone know where is the "readOnly" file?
thanks.
Error
Thu Jan 21 17:22:19 GMT-04:00 2010
de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on: Archive file is read-only!
java.io.FileNotFoundException: de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on: Archive file is read-only!
at de.schlichtherle.io.ArchiveController.createOutputStream(Arc hiveController.java:579)
at de.schlichtherle.io.FileOutputStream.createOutputStream(File OutputStream.java:164)
at de.schlichtherle.io.FileOutputStream.<init>(FileOutputStream.java:124)
at org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .createManifestFile(Unknown Source)
at org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .updatePackage(Unknown Source)
at org.eclipse.mtj.internal.core.build.packaging.PackageBuilder .doBuild(Unknown Source)
at org.eclipse.mtj.internal.core.build.MTJIncrementalProjectBui lder.build(Unknown Source)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:627)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:170)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:201)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
at org.eclipse.core.internal.resources.Project$1.run(Project.ja va:523)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1800)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1782)
at org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:502)
at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate$1.r un(LaunchConfigurationDelegate.java:423)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.bui ldProjects(LaunchConfigurationDelegate.java:430)
at org.eclipse.debug.core.model.LaunchConfigurationDelegate.bui ldForLaunch(LaunchConfigurationDelegate.java:126)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:821)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
Caused by: de.schlichtherle.io.ArchiveFileSystem$ArchiveReadOnlyExcepti on: Archive file is read-only!
at de.schlichtherle.io.ArchiveFileSystem$LinkDelta.<init>(ArchiveFileSystem.java:487)
at de.schlichtherle.io.ArchiveFileSystem$LinkDelta.<init>(ArchiveFileSystem.java:478)
at de.schlichtherle.io.ArchiveFileSystem.link(ArchiveFileSystem .java:469)
at de.schlichtherle.io.ArchiveFileSystem.link(ArchiveFileSystem .java:403)
at de.schlichtherle.io.ArchiveController.createOutputStream0(Ar chiveController.java:620)
at de.schlichtherle.io.ArchiveController.createOutputStream(Arc hiveController.java:570)
... 30 more
Re: De.schlichtherle.io - file is read-only! [message #512705 is a reply to message #509297] Sat, 06 February 2010 11:36 Go to previous messageGo to next message
Originally posted by: news.s237965939.online.de
Am 21.01.2010 22:31, schrieb Bernardo:
There was something about Schlichtherle in this posting:
Message-ID: <9246a501cbf4bf6a2187ff7c67e009e9$1@www.eclipse.org>
HTH,
Hans
Re: De.schlichtherle.io - file is read-only! [message #515648 is a reply to message #509297] Fri, 19 February 2010 11:04 Go to previous message
Look this thread
http://www.eclipse.org/forums/index.php?t=msg&th=153463& amp;start=0&
Previous Topic:Re-syncing the file system
Next Topic:De.schlichtherle.io - file is read-only!
Current Time: Fri Jul 25 06:14:43 EDT 2025
Powered by FUDForum. Page generated in 0.65756 seconds
