Home » Archived » Buckminster » How to generate a sdk feature?
How to generate a sdk feature? [message #512631] |
Fri, 05 February 2010 07:00  |
Is there a specific way to generate a sdk feature which contains both the source and runtime?
I can add the feature id's of the to-be generated source features in the overall feature.xml, but I guess that would
fail cause the source features are generated when building the site and not present earlier.
I searched the newsgroup and only found this reference (from april last year, so maybe it is easier/different now):
> 2) Alternatively, I'd also like to include a (generated) source feature in another feature. For example, my "SDK"
feature should not only contain the binary features, but also the sources. A user installing the SDK feature would then
automatically get the sources, too. Is that possible?
Yes, but I think it requires a buckminster.cspex that removes the dependency to the source feature. It will be included
in the build anyway due to attributes that references the source feature generation in the original feature. Not optimal
and room for improvements of course, I just haven't gotten that far yet.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: How to generate a sdk feature? [message #512665 is a reply to message #512638] |
Fri, 05 February 2010 17:44   |
Ouch, I still get an error with the approach I have chosen. I have the following structure:
a site feature, which contains
-> a runtime feature without sources
-> a sdk feature, which contains both sources and the plugins which are to be build
However with this setup the import fails (see below). When removing the sdk feature (only keeping the runtime feature)
then I don't get this error.
Is my setup not correct or should I configure it differently?
[java] WARNING [0007] : Component request
org.apache.commons.logging:osgi.bundle/[1.1.1.201001230825,1 .1.1.201001230825] is inconflict with request
org.apache.commons.logging:osgi.bundle/[1.0.4.v200904062259, 1.0.4.v200904062259]
[java] ERROR [0000] : No suitable provider for component
org.eclipse.emf.teneo.hibernate.eclipse.source:osgi.bundle was found in resourceMap
file:/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf .teneo.releng.buckminster/build/teneo.rmap
org.eclipse.emf.teneo.hibernate.eclipse.source:osgi.bundle was found in searchPath teneo.releng
[java] ERROR [0000] : Rejecting provider
cvs(:pserver:anonymous@dev.eclipse.org :/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.teneo/rel eng/{0}): Components
of type osgi.bundle are not supported
org.eclipse.emf.teneo.hibernate.eclipse.source:osgi.bundle was found in searchPath teneo.features
cvs(:pserver:anonymous@dev.eclipse.org :/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.teneo/fea tures/{0}-feature):
Components of type osgi.bundle are not supported
org.eclipse.emf.teneo.hibernate.eclipse.source:osgi.bundle was found in searchPath teneo.plugins
cvs(:pserver:anonymous@dev.eclipse.org :/cvsroot/modeling,org.eclipse.emf/org.eclipse.emf.teneo/plu gins/{0}): No
component match was found
[java] ERROR The server reported an error while performing the "cvs rlog" command.
[java] ERROR : The server did not provide any additional information.
org.eclipse.emf.teneo.hibernate.mapper.source:osgi.bundle was found in resourceMap
org.eclipse.emf.teneo.hibernate.mapper.source:osgi.bundle was found in searchPath teneo.releng
org.eclipse.emf.teneo.hibernate.mapper.source:osgi.bundle was found in searchPath teneo.features
org.eclipse.emf.teneo.hibernate.mapper.source:osgi.bundle was found in searchPath teneo.plugins
[java] ERROR [0000] : No suitable provider for component org.eclipse.emf.teneo.source:osgi.bundle was found in
resourceMap file:/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf .teneo.releng.buckminster/build/teneo.rmap
[java] ERROR [0000] : No suitable provider for component org.eclipse.emf.teneo.annotations.source:osgi.bundle
[java] WARN: CVS file
org.eclipse.emf/org.eclipse.emf.teneo/plugins/org.eclipse.em f.teneo.hibernate.mapper/plugin.properties either contains
invalid line endings on the server (CR/LF instead of just LF) or is a binary file that is not marked as -kb.
[java] ERROR [0000] : No suitable provider for component org.eclipse.emf.teneo.hibernate.source:osgi.bundle was
found in resourceMap file:/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf .teneo.releng.buckminster/build/teneo.rmap
[java] ERROR [0000] : No suitable provider for component org.eclipse.emf.teneo.hibernate..source:osgi.bundle
[java] ERROR [0000] : No suitable provider for component org.eclipse.emf.teneo.eclipse.source:osgi.bundle was
[java] INFO: TAG-ID 0007 = Query for org.eclipse.emf.teneo.releng.build.components:buckminster, path:
org.eclipse.emf.teneo.releng.buckminster:buckminster$1.0.0 -> org.apache.commons.logging:eclipse.feature$1.1.1.20100123082 5
[java]
BUILD FAILED
/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf.tene o.releng.buckminster/teneo_ant.xml:52: The following error
occurred while executing this line:
/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf.tene o.releng.buckminster/build/teneo_build.xml:50: The following
error occurred while executing this line:
/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf.tene o.releng.buckminster/ant_macrodefs.xml:54: The following
/home/mtaal/mydata/Projects/Teneo/build/org.eclipse.emf.tene o.releng.buckminster/ant_macrodefs.xml:41: Java returned: 1
Thomas Hallgren wrote:
> On 02/05/2010 05:56 PM, Martin Taal wrote:
>> Hi,
>> overall feature.xml, but I guess that would fail cause the source
> You guess wrong ;-)
> You can add your source features just like any other feature to an SDK
> feature. This was fixed fairly recently.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=294009
> HTH,
> Thomas Hallgren
The Netherlands
Re: How to generate a sdk feature? [message #512706 is a reply to message #512665] |
Sat, 06 February 2010 06:52   |
Hi Martin,
I forgot to mention that your cquery need a 'skip' rule for the source components. So you need to add an 'advisor node'
with a pattern that matches those bundles and then check the 'skip' flag.
Thomas Hallgren
> to be build
> sdk feature (only keeping the runtime feature) then I don't get this error.
> resourceMap
> No component match was found
> rlog" command.
> resourceMap
> rlog" command.
> org.eclipse.emf.teneo.source:osgi.bundle was found in resourceMap
> org.eclipse.emf.teneo.source:osgi.bundle was found in searchPath
> teneo.releng
> teneo.features
> teneo.plugins
> rlog" command.
> org.eclipse.emf.teneo.annotations.source:osgi.bundle was found in
> resourceMap
> rlog" command.
> either contains invalid line endings on the server (CR/LF instead of
> org.eclipse.emf.teneo.hibernate.source:osgi.bundle was found in
> resourceMap
> org.eclipse.emf.teneo.hibernate..source:osgi.bundle was found in
> rlog" command.
> org.eclipse.emf.teneo.eclipse.source:osgi.bundle was found in
> resourceMap
> org.eclipse.emf.teneo.eclipse.source:osgi.bundle was found in searchPath
> teneo.releng
> teneo.features
> teneo.plugins
> rlog" command.
> [java]
> BUILD FAILED
> The following error occurred while executing this line:
> Java returned: 1
>>> Hi,
>> You guess wrong ;-)
>> HTH,
>> Thomas Hallgren
Re: How to generate a sdk feature? [message #512802 is a reply to message #512706] |
Sun, 07 February 2010 10:12   |
The resolution now works and things get build. But I get an error when performing the site.p2 action.
[echo] Creating site
[java] No component named org.eclipse.emf.teneo.eclipse.source:osgi.bundle is known to Buckminster
I have tried different setups but the error is the same for all of them.
Should I also set a special configuration for the site.p2 action?
This is the cquery (although afaiu it is not used anymore when building the site itself).
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="teneo.rmap">
<cq:rootRequest name="org.eclipse.emf.teneo.site" componentType="eclipse.feature"/>
<cq:advisorNode namePattern="^org\.eclipse\.emf\.(\..+)?\.source" componentType="osgi.bundle" skipComponent="true"/>
<cq:advisorNode namePattern="^org\.eclipse\.emf\.(\..+)?\.source" componentType="eclipse.feature"
</cq:componentQuery>
gr. Martin
> Hi Martin,
> components. So you need to add an 'advisor node' with a pattern that
> Regards,
> Thomas Hallgren
>> to be build
>> error.
>> resourceMap
>> rlog" command.
>> resourceMap
>> rlog" command.
>> teneo.releng
>> teneo.features
>> teneo.plugins
>> rlog" command.
>> resourceMap
>> rlog" command.
>> resourceMap
>> rlog" command.
>> resourceMap
>> teneo.releng
>> teneo.features
>> teneo.plugins
>> rlog" command.
>> [java]
>> BUILD FAILED
>> Java returned: 1
>>>> Hi,
>>>> the
>>> You guess wrong ;-)
>>> HTH,
>>> Thomas Hallgren
The Netherlands
Re: How to generate a sdk feature? [message #513041 is a reply to message #512868] |
Mon, 08 February 2010 11:10  |
Hi Thomas,
Here it is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=302153
I attached something which resembles my setup. I hope it helps to reproduce it, let me know if you need more info.
Btw, I am progressing quite nicely, my build runs on hudson with buckminster. It goes through the following steps:
1) downloads plugins and dependencies
2) build plugins and create update site
3) download test plugins
4) download dependencies and the plugins from the build step, use these to create the target platform
5) build test plugins
6) run tests
gr. Martin
> Hi Martin,
> Not sure what's causing this problem. I might be able to track it down
> if you enter a bugzilla with a detailed step by step instruction to
> reproduce it.
> Regards,
> Thomas Hallgren
>> the site itself).
>> <?xml version="1.0" encoding="UTF-8"?>
>> <cq:componentQuery
>> componentType="eclipse.feature" skipComponent="true"/>
>> gr. Martin
The Netherlands
Current Time: Fri Aug 29 20:04:48 EDT 2025
Powered by FUDForum. Page generated in 0.04949 seconds
