Home » Eclipse Projects » Eclipse Platform » Multiple Different Editors for a Single Resource
Multiple Different Editors for a Single Resource [message #512294] Thu, 04 February 2010 10:19 Go to next message
Hi all,
When I want to open an editor from code I use the corresponding IDE.openEditor(...) method. If I have in my runtime a DiagramDocumentEditor opened on a certain IEditorInput and I want to open the same file in a DefaultTextEditor, calling
IDE.openEditor(new FileEditorInput(file), "org.eclipse.ui.DefaultTextEditor");
just activates the diagram editor that is already opened.
The developers guide on org.eclipse.ui.editors states "Only one editor can be open for any particular editor input in a workbench page. For example, if the user is editing readme.txt in the workbench, opening it again in the same perspective will activate the same editor. (You can open another editor on the same file from a different workbench window or perspective)"
But if I use "Open With -> Text Editor" in the package explorer or "Window -> New Editor" it is possible to open another editor in the same window (and in the same perspective).
Could anyone please point me to the actions associated with "Window->New Editor" or to "Open With -> Text Editor" in the package explorer? Or explain how they call IDE.openEditor(...) to open a second editor?
Best,
Holger
[Updated on: Thu, 04 February 2010 10:20] by Moderator
Re: Multiple Different Editors for a single Resource [message #512576 is a reply to message #512294] Fri, 05 February 2010 09:21 Go to previous message
You would use org.eclipse.ui.IWorkbenchPage.openEditor(IEditorInput,
String, boolean, int) which takes various IWorkbenchPage.MATCH_* flags
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Problem with Eclipse missing /usr/lib/eclipse/startup.jar on Unbuntu
Next Topic:SaveAll Action
Current Time: Sat Jul 19 00:03:52 EDT 2025
Powered by FUDForum. Page generated in 0.23801 seconds
