Home » Archived » Buckminster » site.p2 fails with NPE
site.p2 fails with NPE [message #512395] Thu, 04 February 2010 12:10 Go to next message
Aaaaand me again... :)
Now that materialization and testing work again, I still can't get my site to build. I don't know if this problem is on buckminster's side
of things or on p2's, but the P2SiteGenerator always fails with a NPE caused by the IArtifactRepositoryManager service not being registered.
org.eclipse.equinox.internal.p2.artifact.repository.Activato r.addingService(ServiceReference) has not (yet?) been called when the repository
is created, leading to
at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.setProperty(SimpleArtifactRepository .java:967)
at org.eclipse.buckminster.pde.tasks.P2SiteGenerator.run(P2Site Generator.java:308)
at org.eclipse.buckminster.pde.tasks.P2SiteGenerator.internalPe rform(P2SiteGenerator.java:427)
at org.eclipse.buckminster.core.actor.AbstractActor.perform(Abs tractActor.java:201)
Re: site.p2 fails with NPE [message #512401 is a reply to message #512395] Thu, 04 February 2010 17:49 Go to previous messageGo to next message
Hmm, that's odd. I had that problem and thought I had it fixed. This happened when the declarative services (ds) bundle
wasn't started. I guess you're using the absolute latest 3.6?
On what platform are you running? Do you get this with the sample that you provided in bug 301798?
- thomas
> site to build. I don't know if this problem is on buckminster's side of
> has not (yet?) been called when the repository is created, leading to
> at
> at
> at
> at
Re: site.p2 fails with NPE [message #512402 is a reply to message #512401] Thu, 04 February 2010 17:59 Go to previous messageGo to next message
Ahh, now I see. This is not the ds problem at all. The setProperty() method in SimpleArtifactRepository is not using the
agent to obtain the manager. This is a p2 problem. I'll deal with it and get back to you.
- thomas
> happened when the declarative services (ds) bundle wasn't started. I
> - thomas
>> at
>> at
>> at
>> at
Re: site.p2 fails with NPE [message #514259 is a reply to message #512402] Sat, 13 February 2010 01:29 Go to previous messageGo to next message
Hi Thomas,
I am encountering this same issue with the buckminster 3.6 I downloaded this morning. I downloaded from this location:
http://download.eclipse.org/tools/buckminster/headless-3.6/
or is there another download location with nightly builds?
gr. Martin
> method in SimpleArtifactRepository is not using the agent to obtain the
> - thomas
>> - thomas
>>> at
>>> at
>>> at
>>> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: site.p2 fails with NPE [message #514270 is a reply to message #514259] Sat, 13 February 2010 05:07 Go to previous messageGo to next message
Hi Martin,
You are using the right update site. I'm surprised that you get an NPE and I'm fairly certain that it isn't the same one
that we experienced earlier. We have green Hudson builds with CDO using this build.
Can you please run with --displaystacktrace so that we can see where this NPE comes from?
- thomas
On 02/13/2010 07:29 AM, Martin Taal wrote:
> Hi Thomas,
> gr. Martin
Re: site.p2 fails with NPE [message #514285 is a reply to message #514270] Sat, 13 February 2010 12:00 Go to previous messageGo to next message
Hi Thomas,
It indeed works better now! I can build and test (although the test results are not yet found but that's another story).
One thing I have not yet working is the sdk feature. I tried to replicate the cdo structure but I get this:
Doing full workspace refresh
[java] Waiting for jobs to end
[java] org.eclipse.buckminster.core.metadata.AmbigousComponentExcep tion: More then one version of component null
is known to Buckminster
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.a ddAttributeChildren(PerformManager.java:368)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.a ddAttributeChildren(PerformManager.java:321)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.g etOrderedActionList(PerformManager.java:392)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.i nternalPerform(PerformManager.java:413)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:285)
[java] at org.eclipse.buckminster.core.internal.actor.PerformManager.p erform(PerformManager.java:297)
I have run with buckminster debug:
https://build.eclipse.org/hudson/job/emf-teneo-nightly/41/co nsole
gr. Martin
> Hi Martin,
> and I'm fairly certain that it isn't the same one that we experienced
> - thomas
>> Hi Thomas,
>> gr. Martin
The Netherlands
Re: site.p2 fails with NPE [message #514306 is a reply to message #514285] Sat, 13 February 2010 17:06 Go to previous messageGo to next message
Don't particularly like that back trace :-). Something is obviously not right. Can you please add a bugzilla?
- thomas
On 02/13/2010 06:00 PM, Martin Taal wrote:
> Hi Thomas,
> More then one version of component null is known to Buckminster
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> [java] at
> gr. Martin
>> Hi Martin,
>> Thanks,
>> - thomas
>>> Hi Thomas,
>>> gr. Martin
Re: site.p2 fails with NPE [message #514318 is a reply to message #514306] Sat, 13 February 2010 21:26 Go to previous message
Me neither :-)
I updated the bugzilla I already had for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=302153
gr. Martin
> - thomas
>> Hi Thomas,
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> [java] at
>> gr. Martin
>>> Hi Martin,
>>> Thanks,
>>> - thomas
>>>> Hi Thomas,
>>>> gr. Martin
The Netherlands
Previous Topic:Latest Buckminster3.6 does not download target platform
Next Topic:[Aggregator] Installation Problem
Current Time: Sat Aug 30 22:20:48 EDT 2025
Powered by FUDForum. Page generated in 0.03763 seconds
