Home » Archived » M2M (model-to-model transformation) » [ATL] BPMN to BPEL simple rules transformation problem
[ATL] BPMN to BPEL simple rules transformation problem [message #512339] Thu, 04 February 2010 12:31 Go to next message
Hello everybody,
I'm working on some issues I'm meeting trying to make transformation rules from BPMN to BPEL.
Here are 3 very simple rules:
rule GenerationProcess {
from
pool:BPMN!Pool
to
sequence:BPEL!Sequence1 (
name <- pool.name,
activities <- pool.vertices
rule GenerationInvoke {
from
activity:BPMN!Activity (
activity.activityType = #Task
to
invoke:BPEL!Invoke (
name <- activity.name
rule GenerationSubProcess {
from
subprocess:BPMN!SubProcess
to
name <- subprocess.name,
activities <- subprocess.vertices
The problem is that I get this error when executed:
org.eclipse.m2m.atl.engine.emfvm.VMException: Trying to register several rules as default for element org.eclipse.emf.ecore.impl.DynamicEObjectImpl@dc8b55 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@16fb175 (name: SubProcess) (instanceClassName: null) (abstract: false, interface: false)) : GenerationInvoke and GenerationSubProcess
I took a look on the BPMN metamodel and I saw that the propriety "Instance Type Name" of the Subprocess is empty, do you think that this is the problem? Do I need to modify the metamodel? or maybe some other solutions exists...
Thank you very much.
François
Re: [ATL] BPMN to BPEL simple rules transformation problem [message #512342 is a reply to message #512339] Thu, 04 February 2010 12:43 Go to previous messageGo to next message
I don't know which meta-model you're using but this looks like an inheritance problem.
try :
from
activity.activityType = #Task and activity.oclIsTypeOf(BPMN!Activity)
and
from
subprocess:BPMN!SubProcess (subprocess.oclIsTypeOf(BPMN!SubProcess))
Re: [ATL] BPMN to BPEL simple rules transformation problem [message #512345 is a reply to message #512339] Thu, 04 February 2010 12:50 Go to previous messageGo to next message
It works, thank you very much. I am trying to resolve this problem for hours now. May you explain to me my mistake? So I will not do it again.
Especially the code you added to mine : .oclIsTypeOf()
Thank you very much again...
Re: [ATL] BPMN to BPEL simple rules transformation problem [message #512347 is a reply to message #512339] Thu, 04 February 2010 12:54 Go to previous messageGo to next message
I think that I will meet the same problems for other rules that I wrote:
rule GenerationReceive {
from
activity.activityType=#EventIntermediateTimer
to
wait:BPEL!Wait (
name <- 'waitId:' + activity.iD
from
activity.activityType=#EventIntermediateMessage
to
receive:BPEL!Receive (
name <- 'receiveId:' + activity.iD
rule GenerationGateway {
from activity:BPMN!Activity (
activity.activityType=#GatewayDataBasedExclusive
to
receive:BPEL!If (
name <- 'gatewayExcl' + activity.iD
I will work on it.
Re: [ATL] BPMN to BPEL simple rules transformation problem [message #512455 is a reply to message #512339] Fri, 05 February 2010 03:47 Go to previous messageGo to next message
If a class B inherits from a class A, then if you have an ATL rule on class A, every instance of B will also match this rule.
If you don't want this behavior, then you can specify in the filter if the rule on class A should match only instances of A by indicating .oclIsTypeOf(MM!A)
Re: [ATL] BPMN to BPEL simple rules transformation problem [message #689373 is a reply to message #512339] Mon, 27 June 2011 10:24 Go to previous messageGo to next message
Please tell me which metamodels you have used for these transformations
Deepak
Re: [ATL] BPMN to BPEL simple rules transformation problem [message #689753 is a reply to message #689373] Tue, 28 June 2011 05:41 Go to previous message
Hi Sylvain,
Would you please tell me what metamodels to use for transformation of bpmn to bpel using ATL. It would also be helpful if you provide one sample transformation.
Deepak
Previous Topic:[ATL]Inter Model References
Next Topic:[QVTO] Black-box problem with XML
Current Time: Wed Jul 23 11:59:31 EDT 2025
Powered by FUDForum. Page generated in 0.18677 seconds
