Home » Archived » Buckminster » Bucky + Hudson does not retrieve platform-specific launchers
Bucky + Hudson does not retrieve platform-specific launchers [message #512222] |
Thu, 04 February 2010 07:49  |
Hi guys,
not sure if this is the right place to ask. I've been following Ralf
Ebert's (awesome! Thanks Elbert!) tutorial to make a headless build of
an eclipse RCP using Hudson and Buckminster. I've managed to export the
RCP correctly using bucky commands from within Eclipse. The problem
comes when I try to build from Hudson.
Bucky imports the target definition correctly from the workspace. My
target definition includes Eclipse Delta Pack to build the product for
multiple platforms.
importtargetdefinition -A
'${WORKSPACE}/com.opencanarias.mset.rosetta.site.feature/OC- Rosetta-TP-Definition.target'
Then the component query is imported:
import '${WORKSPACE}/com.opencanarias.mset.rosetta.site.feature/sit e.cquery'
And here comes the failure. Bucky doesn't seem to be able to resolve
some platform specific fragments. But not all fragments, but only those
Equinox Launcher. What is strange is that it actually resolves other
platform specific fragments, like those from SWT. And what's more
strange, the only Equinox Launcher fragment that's is imported is the
one from win32 (well, our hudson is being executed in a windows 2003
server...). Let me add some debug messages
Here the message for win32 fragment:
org.eclipse.equinox.launcher.win32.win32.x86:osgi.bundle: Using resolver
Local resolver
org.eclipse.equinox.launcher.win32.win32.x86:osgi.bundle: Trying
provider local(materialized)
No materialization found for
provider local(workspace)
No open workspace project found that corresponds to
provider local(target)
org.eclipse.equinox.launcher.win32.win32.x86:osgi.bundle: Found match
1.0.200.v20090519
org.eclipse.equinox.launcher.win32.win32.x86:osgi.bundle$1.0 .200.v20090519
As you see, it first looks at the target platform, finds a match and
selects it. Now lets look at what happens at, for instance, a macosx
equinox launcher fragment. What is weird about this case is that it
actually finds a match in the target platform, but doesn't select it!
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Using resolver
Local resolver
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Trying provider
local(materialized)
local(workspace)
local(target)
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Found match
1.0.0.v20090519
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Using resource
map
file:/C:/Hudson/jobs/OC-Rosetta/workspace/com.opencanarias.m set.rosetta.site.feature/site.rmap
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Using search path
resources
local({0}/{1}/)
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Using provider
local({0}/{1}/)
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: Resolution
attempt ended with exception: Provider
local(C:/Hudson/jobs/OC-Rosetta/workspace/org.eclipse.equino x.launcher.cocoa.macosx/):
Missing CSpec source required by component type osgi.bundle
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle: No provider was
found that could resolve the request
ERROR [0000] : No suitable provider for component
org.eclipse.equinox.launcher.cocoa.macosx:osgi.bundle was found in
resourceMap
searchPath resources
ERROR [0000] : Resolution attempt ended with exception: Provider
ERROR Provider
Do you guys have a clue why a match is being found, but not being
selected for the component query resolution?
A bit more insight about our build configuration:
- We have one single feature definition that includes ALL plugins from
our product, but only those that are platform independent.
- Then another feature includes all platform specific fragments (i.e.,
filesystem provider, SWT...). This was needed because otherwise PDE
Export would not include them, and the exported RCP would not work.
- our target platform is all stored in our SVN, so we don't resolve them
from p2 update sites.
One of the things I was stuck was that, while trying the build from
within eclipse and bucky, I had to set some flags (operative system,
window system and architecture) at the feature definition for platform
specific fragments, otherwise I would get an error. Also bucky is
sensitive for things like the language flag, so I removed them all.
I've tried many combinations:
- adding "org.eclipse.equinox.executable" feature, and removing it
- removing delta pack from target platform. That would drop more errors,
since things like SWT fragments won't be resolved.
- adding/removing equinox launcher from the feature that contains all
platform specific fragments/bundles
- modifying the "the product includes native launchers artifacts" flag
in the product definition.
- adding P2 site to the platform definition.
Sorry for the long post. Would like to hear your comments.
Víctor.
Re: Bucky + Hudson does not retrieve platform-specific launchers [message #512244 is a reply to message #512241] |
Thu, 04 February 2010 03:50   |
Hi Johannes,
thanks for your response. No, that directory does not exist.
However, im not sure if its supposed to exist. That bundle should be
resolved in the locator for the target platform, which is executed before :
local(target)
1.0.0.v20090519
A match is actually found, but for some reason is not resolved.
In the case of the win32 x86, that directory doesn't exist either,
but it is resolved successfully.
I can't really see what's different in one case and the other.
Víctor.
Johannes Utzig escribió:
> Hi Víctor,
>> path resources
>> local({0}/{1}/)
>> local({0}/{1}/)
>> resourceMap
>> ERROR Provider
> C:/Hudson/jobs/OC-Rosetta/workspace/org.eclipse.equinox.laun cher.cocoa.macosx/
> Does this directory exist, and if so, what does it contain?
> Best regards,
> Johannes
Re: Bucky + Hudson does not retrieve platform-specific launchers [message #512254 is a reply to message #512222] |
Thu, 04 February 2010 09:00   |
Hi Víctor,
The macosx fragment that is found is immediately rejected because of a filter mismatch. I checked the code and
Buckminster does that without logging it. That's unfortunate and I'll fix that.
The reason you get a filter mismatch is probably that your import is run without wildcard settings for the properties
target.os, target.ws, and target.arch. I.e.
target.os=*
target.ws=*
target.arch=*
Without these settings, the values default to the current platform.
Thomas Hallgren
On 02/04/2010 01:49 PM, Víctor Roldán Betancort wrote:
> Hi guys,
> multiple platforms.
> import
> Local resolver
> 1.0.200.v20090519
> Local resolver
> local(materialized)
> local(workspace)
> local(target)
> 1.0.0.v20090519
> map
> resources
> local({0}/{1}/)
> local({0}/{1}/)
> resourceMap
> ERROR Provider
> Cheers,
> Víctor.
Re: Bucky + Hudson does not retrieve platform-specific launchers [message #512256 is a reply to message #512254] |
Thu, 04 February 2010 09:11   |
Hi Thomas,
that you very much, adding that to the component query fixed the problem:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0"
resourceMap="site.rmap">
<cq:rootRequest name="com.opencanarias.mset.rosetta.site.feature"
componentType="eclipse.feature"/>
<cq:property key="target.arch" value="*"/>
<cq:property key="target.os" value="*"/>
<cq:property key="target.ws" value="*"/>
</cq:componentQuery>
Adding a log of component match rejection would help a lot. Thanks!
Now I'm getting this:
ERROR: An internal error occurred during: "Installing".
java.lang.OutOfMemoryError: Java heap space
at
org.eclipse.jdt.internal.compiler.util.Util.getInputStreamAs CharArray(Util.java:415)
at
org.eclipse.jdt.internal.compiler.util.ManifestAnalyzer.anal yzeManifestContents(ManifestAnalyzer.java:42)
at
org.eclipse.jdt.internal.core.ClasspathEntry.getCalledFileNa mes(ClasspathEntry.java:916)
at
org.eclipse.jdt.internal.core.ClasspathEntry.resolvedChained Libraries(ClasspathEntry.java:879)
at
org.eclipse.jdt.internal.core.ClasspathEntry.resolvedChained Libraries(ClasspathEntry.java:866)
at
org.eclipse.jdt.internal.core.ClasspathEntry.resolvedChained Libraries(ClasspathEntry.java:1394)
at
org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2610)
at
org.eclipse.jdt.internal.core.JavaProject.resolveClasspath(J avaProject.java:2679)
at
org.eclipse.jdt.internal.core.ClasspathChange.generateDelta( ClasspathChange.java:218)
at
org.eclipse.jdt.internal.core.DeltaProcessor.resourceChanged (DeltaProcessor.java:1916)
at
org.eclipse.jdt.internal.core.DeltaProcessingState.resourceC hanged(DeltaProcessingState.java:470)
at
org.eclipse.core.internal.events.NotificationManager$2.run(N otificationManager.java:291)
at
org.eclipse.core.internal.events.NotificationManager.notify( NotificationManager.java:285)
at
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:149)
at
org.eclipse.core.internal.resources.Workspace.broadcastPostC hange(Workspace.java:313)
at
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:1022)
at
org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:45)
WARN: Problem during meta-data refresh: Java heap space
at java.util.Arrays.copyOf(Unknown Source)
at java.lang.AbstractStringBuilder.expandCapacity(Unknown Source)
at java.lang.AbstractStringBuilder.append(Unknown Source)
at java.lang.StringBuffer.append(Unknown Source)
at
org.eclipse.core.internal.localstore.BucketTree.locationFor( BucketTree.java:128)
at
org.eclipse.core.internal.localstore.BucketTree.loadBucketFo r(BucketTree.java:113)
at
org.eclipse.core.internal.properties.PropertyManager2.getPro perty(PropertyManager2.java:132)
at
org.eclipse.core.internal.resources.Resource.getPersistentPr operty(Resource.java:1067)
at
org.eclipse.buckminster.core.metadata.MetadataSynchronizer$R esetVisitor.visit(MetadataSynchronizer.java:170)
at org.eclipse.core.internal.resources.Resource$2.visit(Resourc e.java:108)
at
org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:60)
at
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:82)
at
org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:86)
ERROR: An internal error occurred during: "Flushing content description
cache.".
at
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:50)
at
org.eclipse.core.internal.dtree.NoDataDeltaNode.asBackwardDe lta(NoDataDeltaNode.java:59)
at
at
at
at
at
at
INFO: Import complete.
at
at
at
org.eclipse.core.internal.dtree.DataDeltaNode.asBackwardDelt a(DataDeltaNode.java:47)
at
org.eclipse.core.internal.dtree.DeltaDataTree.asBackwardDelt a(DeltaDataTree.java:88)
at
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:816)
at
org.eclipse.core.internal.dtree.DeltaDataTree.reroot(DeltaDa taTree.java:792)
at
org.eclipse.core.internal.watson.ElementTree.immutable(Eleme ntTree.java:517)Doing
full workspace refresh
at
org.eclipse.core.internal.events.ResourceDeltaFactory.comput eDelta(ResourceDeltaFactory.java:42)
at
org.eclipse.core.internal.events.NotificationManager.getDelt a(NotificationManager.java:231)
at
org.eclipse.core.internal.events.NotificationManager.broadca stChanges(NotificationManager.java:140)
at
at
at
cache.".
ERROR: An internal error occurred during: "Metadata refresh".
ERROR: Internal Error
ERROR: Error while refreshingworkspace: Java heap space
Waiting for jobs to end
ERROR: Error while saving workspace: Java heap space
ERROR: Project refresh on com.opencanarias.mset.kdm.audit.view failed: null
at
org.eclipse.buckminster.pde.internal.PDETargetPlatform.doWit hActivePlatform(PDETargetPlatform.java:236)
at
org.eclipse.buckminster.pde.internal.PDETargetPlatform.getOS (PDETargetPlatform.java:131)
at
org.eclipse.buckminster.core.RMContext.getGlobalPropertyAddi tions(RMContext.java:231)
at org.eclipse.buckminster.core.RMContext.<init>(RMContext.java:282)
at org.eclipse.buckminster.core.RMContext.<init>(RMContext.java:277)
at
org.eclipse.buckminster.core.resolver.ResolutionContext.<init >(ResolutionContext.java:56)
at
org.eclipse.buckminster.core.resolver.ResolutionContext.<init >(ResolutionContext.java:49)
at
org.eclipse.buckminster.core.metadata.MetadataSynchronizer.r efreshProject(MetadataSynchronizer.java:364)
at
org.eclipse.buckminster.core.metadata.MetadataSynchronizer$M etadataRefreshJob.run(MetadataSynchronizer.java:140)
However, the job returns as "successful".
Should hudson be executed with more heap space to avoid this? My RCP
application is pretty big.
Thanks for your help again, I've been struggling with the fragment
rejection for days :P
Cheers!
Víctor.
Thomas Hallgren escribió:
> Hi Víctor,
> filter mismatch. I checked the code and Buckminster does that without
> without wildcard settings for the properties target.os, target.ws, and
> target.arch. I.e.
> target.os=*
> target.ws=*
> target.arch=*
> Regards,
> Thomas Hallgren
>> Hi guys,
>> multiple platforms.
>> import
>> Local resolver
>> 1.0.200.v20090519
>> Local resolver
>> local(materialized)
>> local(workspace)
>> local(target)
>> 1.0.0.v20090519
>> map
>> resources
>> local({0}/{1}/)
>> local({0}/{1}/)
>> resourceMap
>> ERROR Provider
>> Cheers,
>> Víctor.
Re: Bucky + Hudson does not retrieve platform-specific launchers [message #512302 is a reply to message #512300] |
Thu, 04 February 2010 10:42  |
Great that you could solve your issues.
Like stated, increasing the hudson memory is not necessary unless it's
really hudson that's running out of memory. From my experience that
usually only happens when it's parsing large Junit Reports and that alike.
The buckminster invokation is (currently) done with a ProcessBuilder so
it's a completly seperated process.
That said, a little bit more memory for Hudson won't hurt anybody of
course :)
Johannes
Current Time: Sun Aug 31 13:39:18 EDT 2025
Powered by FUDForum. Page generated in 0.05566 seconds
