Home » Modeling » Epsilon » ETL
icon3.gif  ETL [message #510015] Tue, 26 January 2010 03:39 Go to next message
Hello again. I have the following problem: when there is executed the following rule of transformation of primitive types the problem that I have is that when a type does not expire with the rule, in this case that is of type "DATED" does not expire with the rule String2Varchar there is generated a primitive type that for fault is of type CHAR.
rule String2Varchar
transform pr:UML!PrimitiveType
to v:modeloOR!PrimitiveType{
if((pr.name='String') or(pr.name='STRING') or (pr.name='string')){
'String2Varchar'.println();
v.Name:=modeloOR!BasicTypes#CHAR;
But I believe that the correct functioning is that if a type for example to type "DATE" it does not expire with the "if", it does not have to generate a TypePrimitive on not having expired with the judgment IF.
Dimitros, your tell me that was creating a file '.model ' but ¿ I can it execute the rules ETL from a file '.ecore ' of entry and another file '.ecore ' of exit?
If the file of entry was '.ecore ', the rules ETL serian like that?
rule Package2Model
transform t :
ecore!Package
to n : ecore!Model
n.Name:= t.Name;
'Package2Model '.println();
Thanks!!!
Re: ETL [message #510038 is a reply to message #510015] Tue, 26 January 2010 00:20 Go to previous messageGo to next message
Please see comments below.
> rule String2Varchar
I'm afraid I can't understand your question. Could you possibly rephrase
and/or attach some model files with the expected/actual results of the
transformation?
> '.ecore ' of exit?
> rule Package2Model
> transform t : ecore!Package
> to n : ecore!Model {
> n.Name:= t.Name;
If you want to transform one Ecore model to another Ecore model, you
have to give distinct names to your models (e.g. Source and Target) and
make sure you use Ecore classes in your transformation (Ecore doesn't
define a Package or Model class). E.g.
rule EPackage2EPackage
transform s : Source!EPackage
to t : Target!EPackage {
t.name = s.name;
> Thanks!!!
Dimitris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: ETL [message #510069 is a reply to message #510038] Tue, 26 January 2010 08:10 Go to previous messageGo to next message
I have the following function:
rule String2Varchar
And in the model of entry I have the types
Primitive integer
Primitive date
Primitive STRING
The resultant model is
Primitive CHAR
Primitive CHAR
Primitive CHAR
It is to say that the type Primitive integer turns into Primitive CHAR
I do not understand because it happens
Thanks!!!
Re: ETL [message #510203 is a reply to message #510069] Tue, 26 January 2010 11:35 Go to previous messageGo to next message
This happens because CHAR is the first literal in the BasicTypes
enumeration and is used by EMF as the default value in case you don't
explicitly specify one.
Dimitris
> rule String2Varchar
> to v:modeloOR!PrimitiveType{ if((pr.name='String') or(pr.name='STRING')
> Primitive integer
> Primitive date
> Primitive STRING
> Primitive CHAR
> Primitive CHAR
> Primitive CHAR
> Thanks!!!
Re: ETL [message #511239 is a reply to message #510015] Sun, 31 January 2010 11:36 Go to previous messageGo to next message
I have some doubts:
The first one of the doubts that tense is:
I have the code:
operation method_seq(c:UML!Class):modeloOR!Method{
var m: new modeloOR!Method;
for (op in c.ownedOperation) {
m.Name:=op.name;
return m;
operation asignartt(c:UML!Class):modeloOR!TypedTable{
'asignartt'.println();
var sx: new modeloOR!TypedTable;
sx.Name:=c.name+'s<<persistent>>';
return sx;
rule Class2UDT
transform c:UML!Class
to s:modeloOR!StructuredType{
'Class2UDT'.println();
s.Name:=c.name+ "<<udt>>";
s.Name.println();
s.typed:=asignartt(c);
s.method:= method_seq(c);
And for the assignment of s.typed: = asignartt (c); and s.method: = method_seq (c); me the mistake appears " Invalid assignment to property 'typed' " and " Invalid assignment to property 'method' " and I do not understand because this happens.
The second doubt:
When I transform a type CHAR the method creates
Primitive CHAR
Primitive CHAR
Primitive CHAR
and I want that the result is
Primitive integer
Primitive date
Primitive STRING
You were recommending to your me that ' you don't explicitly specify one.
But I do not want to create anything type for default. I want that alone when the condificion 'if' is true it create the type PrimitiveType CHAR.
To obtain it I have thought of putting a precondicion in front of this method of the following form:
pre{
var pr: new UML!PrimitiveType;
rule String2Varchar
But this does not work. Since I can do it?
The third doubt is, which is the equivalence of the method resolveTemp" of ATL in ETL.
The defincion of this function in ATL is:
This specific operation makes it possible to point, from an ATL rule, to any of the target model elements (including non-default ones) that will be generated from a given source model element by an ATL matched rule.
The operation resolveTemp has the following declaration: resolveTemp(var, target_pattern_name). The parameter var corresponds to an ATL variable that contains the source model element from which the searched target model element is produced. The parameter target_pattern_name is a string value that encodes the name of the target pattern element (see Section 4.5.2) that maps the provided source model element (contained by var) into the searched target model element.
I have this code:
typed <-thisModule.resolveTemp(p->refImmediateComposite(),'tt')
I have thought that the transformation would be in ETL:
operation resolveTemp(d:UML!Property):modeloOR!TypedTable{
'resolveTemp'.println();
var t: new modeloOR!TypedTable;
d.eContainer():='tt';
return t;
rule.xxxx
transform :d:UML!Property
to .....
st.typed:=resolveTemp(d);
but, it is not correct....And I also have tried this:
typed:=(p.eContainer().type::='tt');
Thanks!!
Re: ETL [message #511256 is a reply to message #511239] Sun, 31 January 2010 17:53 Go to previous messageGo to next message
Could you please send me a complete snapshot of your project
(transformation, models, metamodels etc) so that I can have a look at this?
Dimitris
c wrote:
> I have some doubts:
> I have the code:
> var m: new modeloOR!Method; for (op in c.ownedOperation) {
> m.Name:=op.name;
> return m;
> return sx;
> rule Class2UDT
> s.Name.println();
> s.method:= method_seq(c); }
> The second doubt:
> When I transform a type CHAR the method creates Primitive CHAR
> Primitive CHAR
> Primitive CHAR and I want that the result is
> Primitive integer
> Primitive date
> Primitive STRING
> CHAR.
> pre{
> rule String2Varchar
> of ATL in ETL.
> I have this code:
> return t;
> rule.xxxx
> to .....
> Thanks!!
Re: ETL [message #511871 is a reply to message #511256] Wed, 03 February 2010 05:05 Go to previous messageGo to next message
Can someone help me?
Thanks..
Re: ETL [message #512049 is a reply to message #511871] Wed, 03 February 2010 12:57 Go to previous messageGo to next message
I've replied to your email.
Dimitris
> Thanks..
icon4.gif  Re: ETL [message #512112 is a reply to message #512049] Wed, 03 February 2010 18:07 Go to previous messageGo to next message
Thank you for answering me. I am sorry to be a nuisance so much, but I try to solve the problems for hours before writing in the forum.
I know that the error that appears of 'Invalid assignment to property 'typed' " ' refers to incompatible types,but this is not true.
Before writing in the forum, use the functions '.println () ' of the following form
//Invalid assignment to property 'typed'
//s.typed:=asignartt(c);
'type is'.println();
asignartt(c).println();'
and the exits is:
'type is
TypedTable [Name=Class2UDTs<<persistent>>, ] '.
But I look that the type of the variable 's.typed' is of the same type that the value returned by the function'operation asignartt(c:UML!Class):modeloOR!TypedTable{'.
In the file' '
I look in the file 'modeloOR.ecore' at the field 'typed' of the StructuredType that is the type of the variable 's' and also it is of type TypedTable
Because of it I have written in the forum. Because it gives a problem of incompatible types when it is not true and do not be to which other reasons it can owe.
Thank you for saying the existence of the function to me 'equivalent' and excuse me to my for the inconveniences
A greeting
Re: ETL [message #512320 is a reply to message #512112] Thu, 04 February 2010 11:37 Go to previous messageGo to next message
Hi Carol,
I can't reproduce this with the last version of the transformation you
sent me (1st Feb). After fixing the name of UM.model -> UML.model,
launch.xml runs with no errors... Perhaps you've sent me an older version?
Dimitris
> following form //Invalid assignment to property 'typed'
> and the exits is:
> 'type is
> In the file' '
> type TypedTable
> reasons it can owe.
> A greeting
Re: ETL [message #512406 is a reply to message #512320] Thu, 04 February 2010 18:25 Go to previous messageGo to next message
Hello Dimitrios. I have sent the last version to your mail.The reason of that your you do not see the mistakes is because the line this of code commented.
Thank you.
Re: ETL [message #512742 is a reply to message #512406] Sat, 06 February 2010 20:00 Go to previous message
Hi Carol,
OK. I've now reproduced this. The problem is that StructuredType.typed
is an 1..* feature but asignartt() returns a single TypedTable.
Therefore, instead of performing an assignment
you should be adding the result to s.typed:
s.typed.add(asignartt(c));
Fixing this makes the transformation run with no errors.
Dimitris
> commented.
> Thank you.
Re: ETL [message #585395 is a reply to message #511239] Sun, 31 January 2010 17:53 Go to previous message
Dimitris
c wrote:
> I have some doubts:
> I have the code:
> m.Name:=op.name;
> return m;
> return sx;
> rule Class2UDT
> s.Name.println();
> The second doubt:
> Primitive CHAR
> Primitive integer
> Primitive date
> Primitive STRING
> CHAR.
> pre{
> rule String2Varchar
> of ATL in ETL.
> I have this code:
> return t;
> rule.xxxx
> to .....
> Thanks!!
Re: ETL [message #585617 is a reply to message #511256] Wed, 03 February 2010 05:05 Go to previous message
Thanks..
Re: ETL [message #585649 is a reply to message #585617] Wed, 03 February 2010 12:57 Go to previous message
Dimitris
> Thanks..
Re: ETL [message #585690 is a reply to message #512049] Wed, 03 February 2010 18:07 Go to previous message
and the exits is:
'type is
In the file' '
A greeting
Re: ETL [message #585703 is a reply to message #585690] Thu, 04 February 2010 11:37 Go to previous message
Hi Carol,
Dimitris
> and the exits is:
> 'type is
> In the file' '
> type TypedTable
> reasons it can owe.
> A greeting
Re: ETL [message #585715 is a reply to message #512320] Thu, 04 February 2010 18:25 Go to previous message
Thank you.
Re: ETL [message #585815 is a reply to message #585715] Sat, 06 February 2010 20:00 Go to previous message
Hi Carol,
Dimitris
> commented.
> Thank you.
Previous Topic:[EOL, Ecore2GMF.eol] How duplicate GmfMap!NodeMapping?
Next Topic:Transform UML Class diagram to UML Class diagram
Current Time: Wed Jul 23 05:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.12189 seconds
