Home » Eclipse Projects » Rich Client Platform (RCP) » Creating a parameter controlled ViewerFilter for CommonNavigator(Creating a parameter controlled ViewerFilter for CommonNavigator)
Creating a parameter controlled ViewerFilter for CommonNavigator [message #511895] Wed, 03 February 2010 06:00 Go to next message
I have created a nice working ViewerFilter for my CommonNavigator.
The problem is that my implementation is very specific because the filter uses a String to determine whether the resource should be filtered or not.
Example:
public boolean select(Viewer viewer, Object parentElement, Object element) {
String filter = "CAT";
Now I would like to make the exact same filter with DOG, HORSE and so on. It would violate the DRY principle to duplicate the implementation and change the hardcoded filter string.
I would rather like to specify the filter string as a parameter (filterExpression ???) in some extension point and look this up within the ViewerFilter.
Any solutions with code examples are greatly appreciated.
Re: Creating a parameter controlled ViewerFilter for CommonNavigator [message #511947 is a reply to message #511895] Wed, 03 February 2010 08:58 Go to previous message
It seems to be almost impossible to do this without having to do a ton of work. So I guess I am better of violating the DRY principle - Grrrr!
The main problem being that the ViewerFilter instance is only known at runtime by the CommonFilterDescriptorManager.
This class binds the ViewerFilter instances to a CommonFilterDescriptor (contains the info from plugin.xml).
public class CommonFilterDescriptorManager {
	private static final CommonFilterDescriptorManager INSTANCE = new CommonFilterDescriptorManager();
	private static final CommonFilterDescriptor[] NO_FILTER_DESCRIPTORS = new CommonFilterDescriptor[0];
	private final Set filters = new HashSet();
However everything about this class is private.
What I need is a getViewerFilter(CommonFilterDescriptor) method - or an alternative way to this.
I already spent to much time on this - so I am off to duplicating my filter code.
[Updated on: Wed, 03 February 2010 08:59] by Moderator
Previous Topic:RCP + jws multiplatform
Next Topic:status bar injected into DAO
Current Time: Wed Jul 23 06:15:22 EDT 2025
Powered by FUDForum. Page generated in 0.09571 seconds
