Home » Modeling » Epsilon » Problem to run basic epsilon examples
icon4.gif  Problem to run basic epsilon examples [message #509836] Mon, 25 January 2010 10:09 Go to next message
I downloaded the "Tree2Graph" example and tried to run it with Epsilon plugin for Eclipse, but it did not work.
here is the error I get when I try to launch :
	at org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenStream.java:95)
	at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.java:238)
	at org.eclipse.epsilon.eol.AbstractModule.invokeMainRule(AbstractModule.java:182)
	at org.eclipse.epsilon.eol.AbstractModule.parse(AbstractModule.java:142)
	at org.eclipse.epsilon.etl.dt.launching.EtlLaunchConfigurationDelegate.launch(EtlLaunchConfigurationDelegate.java:48)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:853)
	at org.eclipse.debug.internal.core.LaunchConfiguration.launch(LaunchConfiguration.java:703)
	at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(DebugUIPlugin.java:866)
	at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlugin.java:1069)
I have eclipse 3.5, with java jdk 1.6 on Linux.
I also tried other examples (OO2DB) but I always get the same error.
I'll be very grateful if someone could help me out!
Thanks !
Boris.
Re: Problem to run basic epsilon examples [message #509850 is a reply to message #509836] Mon, 25 January 2010 10:31 Go to previous messageGo to next message
I've seen similar exceptions occur when the file specified in the launch
configuration doesn't exist. Did you follow the instructions in the "Get
it!" tab in
http://www.eclipse.org/gmt/epsilon/examples/index.php?exampl e=org.eclipse.epsilon.examples.tree2graph
precisely?
Dimitris
borislucas@wanadoo.fr wrote:
> Hello,
> at
> org.antlr.runtime.CommonTokenStream.fillBuffer(CommonTokenSt ream.java:95)
> at org.antlr.runtime.CommonTokenStream.LT(CommonTokenStream.jav a:238)
> at
> org.eclipse.epsilon.eol.AbstractModule.invokeMainRule(Abstra ctModule.java:182)
> at
> org.eclipse.epsilon.eol.AbstractModule.parse(AbstractModule. java:142)
> at
> org.eclipse.epsilon.etl.dt.launching.EtlLaunchConfigurationD elegate.launch(EtlLaunchConfigurationDelegate.java:48)
> at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:853)
> at
> org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:703)
> at
> org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:866)
> at
> org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1069)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Thanks !
> Boris.
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Problem to run basic epsilon examples [message #511377 is a reply to message #509850] Mon, 01 February 2010 08:22 Go to previous messageGo to next message
Thank you for your answer, I tried it but it didn't change anything.
Does anyone have any other idea?
Boris
Re: Problem to run basic epsilon examples [message #511381 is a reply to message #511377] Mon, 01 February 2010 08:32 Go to previous messageGo to next message
Hi Boris,
I'm afraid I can't reproduce this. I've followed the steps below
1. Download org.eclipse.epsilon.examples.tree2graph.zip
2. Download org.eclipse.epsilon.examples.metamodels.zip
3. extract them
4. import them into Eclipse as projects
5. right click on Tree.ecore and click "Register EPackages"
6. right click on Graph.ecore and click "Register EPackages"
7. right click on Tree2Graph.launch and select Run as->Tree2Graph
and the transformation appears to be running fine. Could you please
reproduce the steps above and let me know if the problem persists?
Dimitris
> Boris
Re: Problem to run basic epsilon examples [message #511940 is a reply to message #511381] Wed, 03 February 2010 08:30 Go to previous messageGo to next message
I tried again with these very steps, it still doesn't work.
But I was thinking that maybe it is not normal that the metamodel part and the "tree2graph" part are separate in two different project, and thus the metamodels are not visible for "tree2graph"...?
But I suppose that's the purpose of "register package"...
Anyway , thanks again for taking time to help me!
Re: Problem to run basic epsilon examples [message #512050 is a reply to message #511940] Wed, 03 February 2010 13:01 Go to previous message
That's strange! Just to make sure: are you working with the Eclipse
Modeling Distribution? If so, I can think of no other solution rather
than to have a live screensharing session via Yuuguu so that I can have
a look at this directly...
Dimitris
Re: Problem to run basic epsilon examples [message #585029 is a reply to message #509836] Mon, 25 January 2010 10:31 Go to previous message
it!" tab in
precisely?
Dimitris
> Hello,
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks !
> Boris.
Re: Problem to run basic epsilon examples [message #585454 is a reply to message #509850] Mon, 01 February 2010 08:22 Go to previous message
Boris
Re: Problem to run basic epsilon examples [message #585466 is a reply to message #585454] Mon, 01 February 2010 08:32 Go to previous message
Hi Boris,
3. extract them
Dimitris
> Boris
Re: Problem to run basic epsilon examples [message #585636 is a reply to message #511381] Wed, 03 February 2010 08:30 Go to previous message
Re: Problem to run basic epsilon examples [message #585659 is a reply to message #585636] Wed, 03 February 2010 13:01 Go to previous message
Dimitris
Previous Topic:[EUGENIA] Define link targets in list
Next Topic:How does synchronize gmfgen work?
Current Time: Thu Jul 24 19:25:47 EDT 2025
Powered by FUDForum. Page generated in 0.07369 seconds
