Home » Language IDEs » PHP Development Tools (PDT) » Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER?
Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #511681] Tue, 02 February 2010 09:03 Go to next message
Hi all,
i configured my Eclipse to use 4 spaces for indention (instead of a tab).
When i hit "TAB" in the php editor of PDT i get 4 spaces. Ok, good.
But.
When i hit "ENTER" i get tabs instead of 4 spaces, but why?
Is that a bug or how do i need to configure my eclipse/PDT to work well?
Best regards
Daniela Waranie
Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #511863 is a reply to message #511681] Wed, 03 February 2010 04:43 Go to previous messageGo to next message
Hi all,
to illustrate my problem you can find a code example on:
http://pastie.org/807270
Please confirm the bug or help me please.
Best regards
Daniela Waranie
Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #511874 is a reply to message #511681] Wed, 03 February 2010 00:14 Go to previous messageGo to next message
Hi all,
another example (but about replacing tab whitespaces):
http://pastie.org/807288
Can you confirm this bug or is it a misconfiguration?
Best regards
Daniela Waranie
Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #511899 is a reply to message #511874] Wed, 03 February 2010 05:55 Go to previous messageGo to next message
Originally posted by: christian.wolf.sedo.de
Hi Daniela,
I tried to reproduce that behaviour and found a way:
if I simply set the "Window > Preferences > General > Editors > Text
Editors > Insert spaces for tabs" option, I get the exact behaviour you
described.
However, if I wanted to switch from tab to space indentation, I first
navigated to "Window > Preferences > PHP > Code Style > Formatter",
setting "Tab policy" and "Indentation size" accordingly. After setting
these options, hitting both "tab" and "enter" insert spaces instead of
tabs in every situation.
Perhaps this configuration helps you, too,
best
Christian A. Wolf
Daniela Waranie schrieb:
> Hi all,
> Best regards
> Daniela Waranie
Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #512001 is a reply to message #511899] Wed, 03 February 2010 05:58 Go to previous messageGo to next message
Hi Christian,
your tip is good, but sadly not perfect...
It works for my example (tabs are now replaced in that case):
And it works for my first example:
But that works when only a tab whitespace is marked/selected. When
selecting more than a whitespace no replacement takes place.
See this for details on the behavior:
http://pastie.org/807654
It seems that "auto indentation" copies the indentation characters from
the line above (which may contain tab whitespaces). This means "auto
indentation" is not respecting the settings (!).
See this for details:
http://pastie.org/807683
my settings:
1) "Window > Preferences > General > Editors > Text Editors > Insert
spaces for tabs"
2) "Window > Preferences > General > Editors > Text Editors > Display
tab width = 4"
3) "Window > Preferences > PHP > Code Style > Formatter >Tab policy =
Spaces"
4) "Window > Preferences > PHP > Code Style > Formatter >Indentation
size = 4"
Can any one confirm this bug.
Or is this a misconfiguration?
Best regards
Daniela Waranie
icon10.gif  Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #652639 is a reply to message #511681] Fri, 04 February 2011 14:34 Go to previous messageGo to next message
From what I am seeing here:
It doesn't look like a bug... it looks like its by design... at least it seems like good design to me... Very Happy
There is a "tab policy" setting for each language you're writing in...
So:
1) General->Editors->Text Editors (has a tab policy that you'll use when you're writing in PHP)
2) JavaScript-> Code Style -> Formatter (requires you to create a new "Profile" for JavaScript then modify the indentation properties, or change an existing one... but who modifies defaults these days?)
3) Web -> CSS Files -> Editor (Has a radio button for tabs or spaces. You can set the indentation size too.)
4) Web -> HTML Files -> Editor (Has the same radio buttons and indentation size property as CSS.)
Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #660664 is a reply to message #511681] Sun, 20 March 2011 17:21 Go to previous messageGo to next message
Hi Guys,
Did anyone find a resolution to this problem? I have the exact same problem.
Re: Why do i get tabs instead of 4 spaces when auto indention takes place on hitting ENTER? [message #663091 is a reply to message #511681] Sun, 03 April 2011 10:13 Go to previous message
Also there is a bug report.
However I don't give a damn about a PDT anymore. I have switched to the PHPStorm and I'm happy with it.
Previous Topic:Errors when trying to open a php file.
Next Topic:PHP Executable gets "lost"
Current Time: Sat Jul 26 19:17:52 EDT 2025
Powered by FUDForum. Page generated in 0.04871 seconds
