Re: [Xpand] Advices not applied [message #512236 is a reply to message #512216] |
Thu, 04 February 2010 08:27  |
Sven Efftinge wrote:
> Esteban DUGUEPEROUX schrieb:
>> Hi Sven,
>> Thanks it works fine now.
>> But in one of my AROUND statement a call to a local DEFINE statement
>> which call a DEFINE statement in the main template doesn't works.
>> I must copy DEFINE statements that I would like to use in my second
>> template (where AROUND statements are defined) from the main template
>> to my second template.
>> Is it clear?
> Not yet, sorry.
> Are you saying that your not able to call DEFINEs from within an AROUND?
> Sven
I can call local DEFINE statements to my template where I have defined
my AROUND statements but not the DEFINE statements from the main
template which is called for my code generation.
Code example :
Java code which launch my code generation :
Generator generator = new Generator( );
String aspectTemplate = "fr::inria::adam::calico::AspectTemplate";
generator.addAdvice(aspectTemplate);
generator.setExpand("fr::inria::adam::calico::common::JavaGeneration::main
FOR GenerationDefinition");
generator.invoke(ctx, monitor, issues);
my main template :
«DEFINE main FOR generation::GenerationDefinition»
«EXPAND componentImplementation FOR this»
«ENDDEFINE»
«DEFINE plop FOR generation::Plop»
«ENDDEFINE»
my aspect template :
«AROUND *componentImplementation FOR generation::GenerationDefinition»
«EXPAND plop FOR this.onePlop»
«ENDAROUND»
this doesn't works because I can't call "plop" DEFINE statement defined
in the main template and consequently I must recopy the "plop" DEFINE
statement in my aspect template.
Hum nothing better than an example.
Re: [Xpand] Advices not applied [message #512261 is a reply to message #512236] |
Thu, 04 February 2010 04:26  |
You'll have to call it by its qualified name.
<<EXPAND my::path::TemplateFile::plop FOR this.onePlop>>
Sven
>>> Hi Sven,
>>> Is it clear?
>> Not yet, sorry.
>> Sven
> Code example :
> my main template :
> «ENDDEFINE»
> «ENDDEFINE»
> «ENDAROUND»
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand] Advices not applied [message #512263 is a reply to message #512261] |
Thanks it works and sorry for the stupid question because it was obvious
answer.
Best Regards.
> Sven
>>>> Hi Sven,
>>>> template to my second template.
>>>> Is it clear?
>>> Not yet, sorry.
>>> Sven
>> Code example :
>> my main template :
>> «ENDDEFINE»
>> «ENDDEFINE»
>> «ENDAROUND»
>> defined in the main template and consequently I must recopy the "plop"
>> DEFINE statement in my aspect template.
FUDForum. Page generated in 0.27658 seconds
