Home » Eclipse Projects » JFace » How to correctly write a custom widget based on existing widgets
How to correctly write a custom widget based on existing widgets [message #511726] |
Tue, 02 February 2010 11:30  |
--nextPart3122358.8WjPxlS8eG
Content-Type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8Bit
I am trying to build specialized widgets from existing widgets to allow
efficient databinding. My first experimental widget is a combo that selects
an EObject (EMF object) from an EList.
The widget works as expected, but I am not a SWT/Jface specialist and
therefore I would like to know if the implementation is correct the way I
did it.
I would appreciate if anyone of the SWT/Jface gurus could take a look.
I attached the widget in question.
Here's a snippet on how I use it in my sample code:
IWidgetValueProperty comboSelectionProp =
new EListComboSelectionProperty();
IWidgetListProperty comboItemsProp = new EListComboItemsProperty();
dbc.bindList(comboItemsProp.observe(module), EMFEditProperties.list(
domain,
FeaturePath.fromList(
AdministrationPackage.Literals.MODULE_ACCESS__USER,
AdministrationPackage.Literals.USER__MODEL,
AdministrationPackage.Literals.MODEL__MODULES)).observeDetai l(
AccessRightForm.this));
dbc.bindValue(comboSelectionProp.observe(module), EMFEditProperties
.value(domain,
AdministrationPackage.Literals.MODULE_ACCESS__MODULE)
.observeDetail(AccessRightForm.this));
Thanks in advance
Lothar
Content-Type: text/x-java; name="EListComboItemsProperty.java"
Content-Disposition: attachment; filename="EListComboItemsProperty.java"
package biz.tradescape.mmt.ui.databinding;
import java.util.List;
import org.eclipse.core.databinding.observable.list.ListDiff;
import org.eclipse.core.databinding.property.INativePropertyListene r;
import org.eclipse.core.databinding.property.ISimplePropertyListene r;
import org.eclipse.emf.common.util.EList;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.jface.databinding.swt.WidgetListProperty;
import biz.tradescape.mmt.ui.widgets.EListCombo;
public class EListComboItemsProperty
extends
WidgetListProperty
@SuppressWarnings("rawtypes")
protected List doGetList(Object source)
EListCombo combo = (EListCombo) source;
return combo.getItems();
@SuppressWarnings(
"rawtypes", "unchecked"
protected void doSetList(Object source, List list, ListDiff diff)
combo.setItems((List<? extends EObject>) list);
public INativePropertyListener adaptListener(ISimplePropertyListener listener)
return null;
public Object getElementType()
return EList.class;
Content-Type: text/x-java; name="EListCombo.java"
Content-Disposition: attachment; filename="EListCombo.java"
package biz.tradescape.mmt.ui.widgets;
import java.lang.reflect.InvocationTargetException;
import java.lang.reflect.Method;
import java.text.MessageFormat;
import java.util.ArrayList;
import java.util.Collections;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Combo;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Event;
import org.eclipse.swt.widgets.Listener;
import biz.tradescape.mmt.ui.Activator;
extends
Composite
private Combo combo;
private List<EObject> items = new ArrayList<EObject>();
private Method method;
private class ListenerProxy
implements
Listener
int eventType;
Listener listener;
public ListenerProxy(
int eventType, Listener handler)
this.eventType = eventType;
this.listener = handler;
proxyListeners.add(this);
public void handleEvent(Event event)
event.widget = EListCombo.this;
listener.handleEvent(event);
private List<ListenerProxy> proxyListeners = new ArrayList<ListenerProxy>();
public EListCombo(
Composite parent, int style)
super(parent, SWT.NONE);
setLayout(new FillLayout());
combo = new Combo(this, style);
public void addListener(int eventType, Listener handler)
ListenerProxy proxy = null;
synchronized (proxyListeners)
proxy = new ListenerProxy(eventType, handler);
Activator.logTrace(this.getClass().getSimpleName(), MessageFormat.format(
"Proxy for handler {0}, eventType {1} added", handler, eventType));
combo.addListener(eventType, proxy);
public void removeListener(int eventType, Listener handler)
for (ListenerProxy check : proxyListeners)
if (check.eventType == eventType && check.listener == handler)
proxy = check;
proxyListeners.remove(proxy);
.format(
"Proxy for handler {0}, eventType {1} removed", handler,
eventType));
break;
if (proxy != null)
combo.removeListener(eventType, proxy);
else
"Proxy for handler {0}, eventType {1} is null", handler, eventType));
public int getSelectionIndex()
int result = combo.getSelectionIndex();
"getSelectionIndex result={0}", result));
return result;
public EObject getItem(int index)
EObject result = items.get(index);
"getItem result={0}", result));
return result;
public List<? extends EObject> getItems()
"getItems {0} ({1})", items.size(), items));
return Collections.unmodifiableList(items);
public void setItems(List<? extends EObject> list)
if (items == null)
SWT.error(SWT.ERROR_NULL_ARGUMENT);
items.clear();
items.addAll(list);
"setItems {0} ({1})", items.size(), items));
updateCombo();
public void select(EObject object)
combo.select(items.indexOf(object));
public void setItemTextMethod(Method method)
this.method = method;
private String getText(EObject object)
String name = null;
if (method != null)
try
name = (String) method.invoke(object);
catch (IllegalArgumentException e)
; // ignore
catch (IllegalAccessException e)
; // ignore
catch (InvocationTargetException e)
; // ignore
if (name == null)
name = object.toString();
return name;
private void updateCombo()
combo.removeAll();
int index = 0;
for (EObject item : items)
String text = getText(item);
combo.add(text, index++);
Content-Type: text/x-java; name="EListComboSelectionProperty.java"
Content-Disposition: attachment; filename="EListComboSelectionProperty.java"
import org.eclipse.jface.databinding.swt.WidgetValueProperty;
public class EListComboSelectionProperty
extends
WidgetValueProperty
public EListComboSelectionProperty()
super(SWT.Modify);
protected Object doGetValue(Object source)
int index = combo.getSelectionIndex();
if (index == -1)
return null;
else
return combo.getItem(index);
protected void doSetValue(Object source, Object value)
for (Object item : combo.getItems())
if (value == item)
combo.select((EObject) value);
public Object getValueType()
return EObject.class;
--nextPart3122358.8WjPxlS8eG--
Re: How to correctly write a custom widget based on existing widgets [message #519026 is a reply to message #511726] |
Fri, 05 March 2010 13:29  |
Instead of creating your own EListCombo, you can use JFace ComboViewer, and provide an ObservableListContentProvider:
Combo combo = new Combo(parent, style);
ComboViewer viewer = new ComboViewer(combo);
myLabelProvider = .... // customize items label
viewer.setLabelProvider(myLabelProvider);
viewer.setContentProvider(ObservableListContentProvider());
IObservableList observableList = ... // create list of observable items
viewer.setInput(observableList);
// bind viewer selection to domain element
IObservable myDomainObservable = ...
dbc.bindValue(ViewerProperties.singleSelection().observe(vie wer), myDomainObservable);
Current Time: Wed Jul 23 11:49:55 EDT 2025
Powered by FUDForum. Page generated in 0.03811 seconds
