Home » Modeling » M2T (model-to-text transformation) » [Xpand]: FeatureNotFoundException in workflow when metamodel references Ecore metamodel
[Xpand]: FeatureNotFoundException in workflow when metamodel references Ecore metamodel [message #511721] Tue, 02 February 2010 06:26 Go to next message
Hi newsgroup,
i'm totally desperated!
My problem is, that when my metamodel is using some elements from the
ecore metamodel the workflow aborts with an
org.eclipse.emf.ecore.xmi.FeatureNotFoundException...
You may reproduce it by changing the Xpand Sample Project in this way:
1. In the metamodel.ecore file load ecore metamodel resource.
2. Remove the name attribute from Type and therefore add ENamedElement
as a esuper type.
3. Running the workflow now you will get the Exception.
I found some similar problems with referenced metamodels that gave some
hints regarding the workflow definition (none of them helpful):
- add metaModel tags to Generator component
- add referenced ecore file tag to StandaloneSetup bean
Has anybody an idea how to solve this issue???
Perhaps someone can share a working workflow definition for my Sample
Project example?
Regards, Andreas
Re: [Xpand]: FeatureNotFoundException in workflow when metamodel references Ecore metamodel [message #511890 is a reply to message #511721] Wed, 03 February 2010 05:33 Go to previous messageGo to next message
Please post your workflow and the way you reference ecore (ie is it
nsURI or resource uri).
Sven
Andreas Werner schrieb:
> Hi newsgroup,
> as a esuper type.
> Project example?
> Regards, Andreas
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [Xpand]: FeatureNotFoundException in workflow when metamodel references Ecore metamodel [message #511910 is a reply to message #511890] Wed, 03 February 2010 07:04 Go to previous messageGo to next message
Hi Sven,
here is my generator.mwe with some experiments I've done so far.
<?xml version="1.0"?>
<workflow>
<property name="model" value="my.generator.project/src/Model.xmi" />
<property name="src-gen" value="src-gen" />
<!-- set up EMF for standalone execution -->
<bean class="org.eclipse.emf.mwe.utils.StandaloneSetup" >
<platformUri value=".."/>
<!-- 1. Plugin URI doesn't sem to be supported (URI copyied from metamodel.ecore as seen in the editor)
<registerEcoreFile value="platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore " />
<!-- 2. Tried this after copying the Ecore project into workspace
<registerEcoreFile value="platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore " />
<!-- 3. Tried this after copying the Ecore model to sample project
<registerEcoreFile value=" platform:/resource/my.generator.project/src/metamodel/Ecore. ecore " />
<!-- 4. ...
<registerGeneratedEPackage value="org.eclipse.emf.ecore.EcorePackage"/>
</bean>
<!-- load model and store it in slot 'model' -->
<component class="org.eclipse.emf.mwe.utils.Reader">
<uri value="platform:/resource/${model}" />
<modelSlot value="model" />
</component>
<!-- check model -->
<component class="org.eclipse.xtend.check.CheckComponent">
<metaModel id="mm"
class="org.eclipse.xtend.typesystem.emf.EmfRegistryMetaModel "/>
<checkFile value="metamodel::Checks" />
<emfAllChildrenSlot value="model" />
</component>
<!-- generate code -->
<component class="org.eclipse.xpand2.Generator">
<metaModel idRef="mm"/>
<!-- 5. ...
<metaModel class="org.eclipse.xtend.typesystem.emf.EmfMetaModel">
<metaModelPackage value="org.eclipse.emf.ecore.EcorePackage"/>
</metaModel>
<metaModelFile value="platform:/resource/org.eclipse.emf.ecore/model/Ecore.ecore "/>
</metaModel>
</metaModel>
<expand
value="template::Template::main FOR model" />
<outlet path="${src-gen}" >
<postprocessor class="org.eclipse.xpand2.output.JavaBeautifier" />
</outlet>
</component>
</workflow>
Am 03.02.2010 11:33, schrieb Sven Efftinge:
> Sven
>> Hi newsgroup,
>> as a esuper type.
>> some hints regarding the workflow definition (none of them helpful):
>> Project example?
>> Regards, Andreas
Re: [Xpand]: FeatureNotFoundException in workflow when metamodel references Ecore metamodel [message #511917 is a reply to message #511910] Wed, 03 February 2010 02:30 Go to previous messageGo to next message
Is model.xmi and instance of Ecore.ecore?
If you have another *.ecore file which Model.xmi is an instance of,
you'll have to register that.
Usually one refers to ecore files by it's nsURI (check the uri in your
*.ecore file). In that case you only need to register your ecore model
<registerEcoreFile
value="platform:/resource/my.project/model/my.ecore" />
This will register the epackage with the EPackage.Registry.
You don't need to specify the EPackages when configuring the metamodel,
since it uses the EPackage.Registry by default.
<metaModel id="mm"
is sufficient.
Sven
> Hi Sven,
> <workflow>
> <registerEcoreFile
> <registerEcoreFile
> <registerEcoreFile
> <!-- 4. ...
> </bean>
> </component>
> <metaModel id="mm"
> </component>
> <!-- 5. ...
> </metaModel>
> <metaModel
> <metaModelFile
> </metaModel>
> <metaModelFile
> </metaModel>
> <expand
> <postprocessor
> </outlet>
> </component>
> </workflow>
>> Sven
>>> Hi newsgroup,
>>> as a esuper type.
>>> Project example?
>>> Regards, Andreas
Re: [Xpand]: FeatureNotFoundException in workflow when metamodel references Ecore metamodel [message #511929 is a reply to message #511917] Wed, 03 February 2010 08:06 Go to previous message
I got it now! ;)
The problem was, that I subTyped ENamedElement in the metamodel.ecore,
which is not allowed, because ENamedElement is not an EClass...
When subTyping EClass instead of ENamedElement the workflow executes without errors.
But I think it's strange that the EcoreEditor as well as the DynamicInstanceEditor no
warnings or errors have been given!?!?
Am 03.02.2010 13:25, schrieb Sven Efftinge:
> <registerEcoreFile
> <metaModel id="mm"
> is sufficient.
> Sven
>> Hi Sven,
>> <workflow>
>> <registerEcoreFile
>> <registerEcoreFile
>> <registerEcoreFile
>> <!-- 4. ...
>> </bean>
>> </component>
>> <metaModel id="mm"
>> </component>
>> <!-- 5. ...
>> </metaModel>
>> <metaModelFile
>> </metaModel>
>> <metaModelFile
>> </metaModel>
>> <expand
>> </outlet>
>> </component>
>> </workflow>
>>> Sven
>>>> Hi newsgroup,
>>>> as a esuper type.
>>>> Project example?
>>>> Regards, Andreas
Previous Topic:Workflow just terminates on Linux but works on Windows
Next Topic:problem with multiple template files
Current Time: Wed Jul 23 01:49:29 EDT 2025
Powered by FUDForum. Page generated in 0.06945 seconds
