INI file missing in the deployed RCP product [message #511576] |
Tue, 02 February 2010 01:37  |
Hi all
I am new to RCP. When I finished creating an RCP app, I deployed it.. but could not find the eclipse.ini file or <launcher>.ini file.
I need this ini file so as to increase the memory usage as my product gives out of memory exception when too much data is given to it.
How do I put an INI file onto my deployed product so that the memory usage may be controlled so that it can handle large amounts of data given to it?
Thank you,
Re: INI file missing in the deployed RCP product [message #511596 is a reply to message #511579] |
Tue, 02 February 2010 03:34  |
Hi Daniel,
Thanks for the reply.
Actually, the build.properties file under the bin.includes does not have any mention of a .ini file.
build.properties file :=
source.. = src/
output.. = bin/
bin.includes = plugin.xml,\
META-INF/,\
icons/,\
So what INI file and how must I include it into the build.prop file?
And ...
the org.eclipse.core.runtime.products does not have any property refering it.... so should I be explicitly creating another property in the XML refering the same ini file i have specified in the build.properties?
Thank You,
FUDForum. Page generated in 0.05580 seconds
