Home » Eclipse Projects » Rich Client Platform (RCP) » Multi Plugin Project Problems with Menu(Problem defining Menu item placement.)
Multi Plugin Project Problems with Menu [message #511470] Mon, 01 February 2010 11:41 Go to next message
Good day,
I seem to be having a little problem with telling how I want my Menu Items sorted in the MenuBar. I created a multi project Plugin Project. And I spread my function and views/perspectives over the plugins. Giving each project its own Menu Contribution to the org.eclipse.ui.main.menu. But now it seems to set the menu items at random on generation. I tried adding ?after=other.menu.id.
This how ever does not seem to work if I put it a menu item of the menu:org.eclipse.ui.main.menu (menuContribution).
if i try to the plugin menuContribution
menu:this.plug-in.menu.item?after=other.menu.id
The menu item completely disappears.
Does the plug-in that is having a refer 2 a other plug-in.menu.id have 2 know it. Do I need to add that plug-in to the Imported Packages. Because that would sort of defeat for me the purpose separating modular functions/perspectives in separate project.
If I eny one can shed some lights on this that would be great.
Re: Multi Plugin Project Problems with Menu [message #511492 is a reply to message #511470] Mon, 01 February 2010 12:39 Go to previous messageGo to next message
Hi Martijn,
You talk about menu items in the menu bar but do you mean menus? A menu must
have at least one menu item otherwise it will not show.
Best Regards,
Wim Jongman
-- Southern DOS: Y'all reckon? (Yep/Nope)
(Eclipse Old Skool Quote Service)
> Good day,
Re: Multi Plugin Project Problems with Menu [message #511593 is a reply to message #511492] Tue, 02 February 2010 03:30 Go to previous message
Wim Jongman wrote on Mon, 01 February 2010 12:39
Hi Martijn,
Best Regards,
Wim Jongman
Hi Wim,
The menu has items. It shows if i do not use the ?after=other.menu.id action. But then I got this russian rullet going for the menu items showing. Whitch I ofcourse do not want.
Previous Topic:Example RCP-project: when is Application.stop() supposed to be called?
Next Topic:INI file missing in the deployed RCP product
Current Time: Thu Jul 24 21:09:59 EDT 2025
Powered by FUDForum. Page generated in 0.05787 seconds
