Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Inconsistent Line Ending Style
[Acceleo] Inconsistent Line Ending Style [message #509621] Sat, 23 January 2010 12:07 Go to next message
I tried out Acceleo for the first time and was pretty happy that it
worked very smoothly. I generated some Java code with Acceleo and wanted
to check in the code into an SVN repository. However, the commit failed
due to the "Inconsistent Line Ending Style" error. Apparently, Acceleo
generates code with inconsistent line endings. I assume this is a bug?
Or am I doing something wrong? By the way, I am using Acceleo 2.8.1 on
Galileo running on Windows XP.
Markus
Re: [Acceleo] Inconsistent Line Ending Style [message #510364 is a reply to message #509621] Wed, 27 January 2010 01:06 Go to previous messageGo to next message
--------------000002000903060700070902
Hi Markus,
I have never seen this error, yet it is fully possible that you end up
with inconsistent line endings if you generate code under windows while
explicitely using "\n" in your templates (or generating under unix with
"\r\n" in your templates) as for "regular" line ends, Acceleo takes the
system default while explicitely defined line ends in the templates are
preserved.
We are thinking of a way to allow users to define the line ending style
Acceleo should use for generations (converting both explicit and
implicit line ends along the way), but haven't made any plans for it yet.
Laurent Goubet
Obeo
Markus Herrmannsd
Re: [Acceleo] Inconsistent Line Ending Style [message #510984 is a reply to message #510364] Fri, 29 January 2010 07:43 Go to previous messageGo to next message
Hi Laurent,
I do not explicitely use line endings in my templates. However, I have
used the wizard to create the project. Can it be that this wizard
imports files that have been created with another operating system?
Markus
Laurent Goubet schrieb:
> Hi Markus,
> preserved.
> Laurent Goubet
> Obeo
> Markus Herrmannsdörfer wrote:
>> Hi,
>> wanted to check in the code into an SVN repository. However, the
>> commit failed due to the "Inconsistent Line Ending Style" error.
>> Apparently, Acceleo generates code with inconsistent line endings. I
>> assume this is a bug? Or am I doing something wrong? By the way, I am
>> using Acceleo 2.8.1 on Galileo running on Windows XP.
>> Cheers,
>> Markus
Re: [Acceleo] Inconsistent Line Ending Style [message #511364 is a reply to message #510984] Mon, 01 February 2010 07:59 Go to previous message
--------------050309020906020208060008
Markus,
The wizards (for now) use JET templates to initialize Acceleo projects.
I'll have to double check JET's policy for line endings, but I'll try
and fix this asap if it is where the problem lies.
Laurent Goubet
Obeo
Markus Herrmannsd
Previous Topic:[Xpand] Referenced model unaccessible
Next Topic:How to access information about the code generated?
Current Time: Sat Jul 26 02:08:46 EDT 2025
Powered by FUDForum. Page generated in 0.45396 seconds
