Home » Eclipse Projects » JFace » [Databinding] How to manipulate record order in a TableViewer
[Databinding] How to manipulate record order in a TableViewer [message #511068] Fri, 29 January 2010 11:58
I have a Tableviewer bound to a List using ViewerSupport - that part works fine.
The question is, how to connect up a set of Up/Down/Add/Remove buttons in the view to manipulate
the order of the rows in the table and to add and delete rows, with the result being properly
reflected in the model through the existing bindings.
getTableViewer().getInput() is a BeansObservableListDecorator
getTableViewer().getContentProvider() is a ObservableListContentProvider
Neither appears appropriate for manipulating the view side of the bindings.
Snippet 18 shows the add/remove buttons but connects them to the model directly through its
ListObservables wrapper. Is there an alternative that does not require making the model directly
accessible in the view.
Thanks...
Previous Topic:[databinding] How to manipulate record order in a TableViewer
Next Topic:RuleBasedPartitionScanner problem.
Current Time: Fri Nov 07 17:58:21 EST 2025
Powered by FUDForum. Page generated in 0.01961 seconds
