Home » Eclipse Projects » Mylyn » Jira/Bugzilla connector behind proxy: "Stream Closed" message
Jira/Bugzilla connector behind proxy: "Stream Closed" message [message #64683] Fri, 30 January 2009 04:28 Go to next message
Hi all,
I try to access to a Jira server through a proxy.
I'm sure than both server & proxy are ok since:
* I can connect to Jira server in HTTP, or thanks to Jira connector
without proxy (when I'm at home)
* proxy is working for Eclipse software update, SVN repository access, or
Mylyn generic Web connector
When using Jira connector, I get a "Stream Closed" error message when I
validate settings.
When using Bugzilla connector, I get the following message: "I/O Error
occurred while communicating with https://bugs.eclipse.org/bugs."
Can someone help?
Thx
Re: Jira/Bugzilla connector behind proxy: "Stream Closed" message [message #511061 is a reply to message #64683] Fri, 29 January 2010 11:35 Go to previous message
I'm experinced the same.
with JIRA connector.
Any ideas?
Re: Jira/Bugzilla connector behind proxy: "Stream Closed" message [message #600548 is a reply to message #64683] Fri, 29 January 2010 11:35 Go to previous message
Any ideas?
Previous Topic:Auto-switching to a branch related to task
Next Topic:Bugzilla connector fails after Mylyn update 3.0.4
Current Time: Mon Oct 27 23:20:15 EDT 2025
Powered by FUDForum. Page generated in 0.04390 seconds
