Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Change L10nResources.java.template
Change L10nResources.java.template [message #511012] Fri, 29 January 2010 09:23 Go to next message
I changed the L10nResources.java.template because every modification on the language package cause 2 problems:
1. when I call getString(String key) with a key, doesn't in the language package the source return me a null value.
  String result = (String) this.values.get(key);
  if (result == null) {
    result = "!!" + key + "!!";
  return result;
2. Change the function getResourcePath(), because my PROPERTIES_PCKG was empty, so the function return //message_en-US.properties
buffer.append("/");
if (PROPERTIES_PCKG.length() > 0) {
  buffer.append(PROPERTIES_PCKG);
  buffer.append("/");
buffer.append(PROPERTIES_PRFX);
if (locale.length() > 0) {
  buffer.append("_");
buffer.append(locale);
Someone has the same problem? Or an other solution?
thanks
Marco
Re: Change L10nResources.java.template [message #511066 is a reply to message #511012] Fri, 29 January 2010 11:47 Go to previous messageGo to next message
Hi Marco,
Could you open a bug on MTJ bugzilla describing these problems?
Diego
Re: Change L10nResources.java.template [message #511218 is a reply to message #511012] Sun, 31 January 2010 06:58 Go to previous messageGo to next message
done
bye
Marco
Re: Change L10nResources.java.template [message #513065 is a reply to message #511218] Mon, 08 February 2010 12:13 Go to previous message
Thanks.
Previous Topic:Obfusator question
Next Topic:Change L10nResources.java.template
Current Time: Sat Jul 19 04:48:22 EDT 2025
Powered by FUDForum. Page generated in 0.03853 seconds
