Home » Archived » Buckminster » Aggregator NPE when building repo with Maven
Aggregator NPE when building repo with Maven [message #510222] Tue, 26 January 2010 08:44 Go to next message
we're using the Aggregator to generate Maven-conformant Repositories
with the Option Maven Result.
At the end of the build, while adding maven metadata we get an NPE
Build failed! Exception was java.lang.NullPointerException:
at
org.eclipse.buckminster.aggregator.engine.maven.MavenManager .getVersionString(MavenManager.java:228)
at
org.eclipse.buckminster.aggregator.engine.maven.MavenManager .saveXMLs(MavenManager.java:382)
at
org.eclipse.buckminster.aggregator.engine.maven.MavenManager .saveMetadata(MavenManager.java:242)
at
org.eclipse.buckminster.aggregator.engine.MirrorGenerator.ru n(MirrorGenerator.java:868)
at
org.eclipse.buckminster.aggregator.engine.Builder.runMirrori ng(Builder.java:1206)
at org.eclipse.buckminster.aggregator.engine.Builder.run(Builde r.java:693)
at
org.eclipse.buckminster.aggregator.presentation.AggregatorAc tionBarContributor$BuildRepoAction$1.run(AggregatorActionBar Contributor.java:278)
We use Buckminster Aggregator Editor 1.0.0.r11086.
Thanks in advance.
Marko
Re: Aggregator NPE when building repo with Maven [message #510252 is a reply to message #510222] Tue, 26 January 2010 17:20 Go to previous messageGo to next message
I will look into this and let you know tomorrow.
Is the maven repository you map anything that is public? If so, please post it here so that I could debug easier.
Thanks.
Kind regards
Filip
exquisitus napsal(a):
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Thanks in advance.
> Regards
> Marko
Re: Aggregator NPE when building repo with Maven [message #510288 is a reply to message #510252] Wed, 27 January 2010 01:19 Go to previous messageGo to next message
Hi Filip,
thanks for your quick response. I'm not using any public maven repos. I
only map galileo p2 and some own p2 repos, and mirror the bundles to
produce a Maven repo, like mentioned in the Aggregator Example.
I like to consume the generated repo in nexus.
When the build is almost complete, the build process is logging
"Writing maven metadata" and then the NPE occours.
Kind regards
Marko
> Thanks.
> Kind regards
> Filip
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Thanks in advance.
>> Regards
>> Marko
Re: Aggregator NPE when building repo with Maven [message #510300 is a reply to message #510288] Wed, 27 January 2010 02:59 Go to previous messageGo to next message
Hi Marko,
sorry for the confusion - I had the p2 repos (not maven repos) you map in my mind :-)
So your answer is galileo + your own (private) repos.
I'll let you know when I find something.
Filip
Marko Espig napsal(a):
> Hi Filip,
> When the build is almost complete, the build process is logging "Writing
> Kind regards
> Marko
>> Thanks.
>> Kind regards
>> Filip
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks in advance.
>>> Regards
>>> Marko
Re: Aggregator NPE when building repo with Maven [message #510397 is a reply to message #510300] Wed, 27 January 2010 07:41 Go to previous messageGo to next message
I found and (hopefully) fixed the problem. Unfortunately, for some reason, I am unable to rebuild the update site right now (some problems at build.eclipse.org). I'll try later.
Filip
Filip Hrbek napsal(a):
> Hi Marko,
> in my mind :-)
> Filip
>> Hi Filip,
>> I only map galileo p2 and some own p2 repos, and mirror the bundles to
>> Kind regards
>> Marko
>>> Thanks.
>>> Kind regards
>>> Filip
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thanks in advance.
>>>> Regards
>>>> Marko
Re: Aggregator NPE when building repo with Maven [message #510740 is a reply to message #510288] Thu, 28 January 2010 04:20 Go to previous messageGo to next message
This problem has been fixed. The fixed version (Buckminster Aggregator Editor 1.0.0.r11118) is available on our update site:
http://download.eclipse.org/tools/buckminster/updates-3.5
Please try again and let me know if you succeed or not.
Filip
> Hi Filip,
> Kind regards
> Marko
>> Thanks.
>> Kind regards
>> Filip
>>> Hi,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thanks in advance.
>>> Regards
>>> Marko
Re: Aggregator NPE when building repo with Maven [message #510877 is a reply to message #510740] Thu, 28 January 2010 18:00 Go to previous message
Hi Filip,
I have tried it, it works as expected now.
Thank's, I appreciate your immediate assistance.
Marko
Am 28.01.2010 15:08, schrieb Filip Hrbek:
> Filip
>> Hi Filip,
>> Kind regards
>> Marko
>>> Thanks.
>>> Kind regards
>>> Filip
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thanks in advance.
>>>> Regards
>>>> Marko
Previous Topic:Creating Eclipse RCP plugins with a Maven dependency
Next Topic:Problems installing headless buckminster 3.6
Current Time: Thu Sep 04 21:12:18 EDT 2025
Powered by FUDForum. Page generated in 0.05976 seconds
