Home » Archived » BIRT » PDF Table of Contents
PDF Table of Contents [message #510225] Tue, 26 January 2010 13:53 Go to next message
I am trying to implement the hierarchical structure in the bookmark section of a pdf report.
For example, I have this information in my report:
Table1
Column1
Column2
Table2
Column1
I also would like to have the same structure in bookmark
+ Table1
+ Table2
Clicking the + signs, we will get
- Table1
Column1
Column2
- Table2
Column1
I entered the name of the table and column in their respected TOC field. This is what I have:
Table1
Column1
Column2
Table2
Column1
The structure is flat. Is there anyway to create the hierarchical structure? please advise.
Neil
Re: PDF Table of Contents [message #510565 is a reply to message #510225] Wed, 27 January 2010 16:00 Go to previous messageGo to next message
Neil,
If the elements are nested you should be getting the plus signs.
Take a look at this example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<structure name="toc">
<expression name="expressionValue"
type="javascript">"mytable";</expression>
</structure>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<group id="43">
<property name="groupName">NewTableGroup1</property>
<property name="interval">none</property>
<property name="sortDirection">asc</property>
<expression name="keyExpr"
type="javascript">row["ORDERNUMBER"]</expression>
</structure>
<property name="repeatHeader">true</property>
<property name="hideDetail">false</property>
<property name="pageBreakAfter">auto</property>
<property name="pageBreakBefore">auto</property>
<property name="pageBreakInside">auto</property>
<header>
<row id="44">
<cell id="45">
<data id="56">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="46"/>
<cell id="47"/>
<cell id="48"/>
<cell id="49"/>
</row>
</header>
<footer>
<row id="50">
<cell id="51"/>
<cell id="52"/>
<cell id="53"/>
<cell id="54"/>
<cell id="55"/>
</row>
</footer>
</group>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
type="javascript">row["ORDERLINENUMBER"]</expression>
</structure>
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
</body>
</report>
Neil Wang wrote:
> Table1
> Column1
> Column2
> Table2
> Column1
> + Table1
> + Table2
> - Table1
> Column1
> Column2
> - Table2
> Column1
> Table1
> Column1
> Column2
> Table2
> Column1
> Neil
Re: PDF Table of Contents [message #510573 is a reply to message #510565] Wed, 27 January 2010 16:15 Go to previous messageGo to next message
Hi Jason,
Thank you very much for your reply. I used to have table groups; therefore, I was able to see the plus signs.
The structure that I have in the layout is a table with 1 column and 2 detail rows. Table name is in the first detail row.
I added another table with 1 column and 1 detail row to the second detail row of the first table. Column name is in the detail row of this table.
Therefore, I don't have any table group. Is there any way to see the plus signs without having table groups?
please advise.
Re: PDF Table of Contents [message #510580 is a reply to message #510573] Wed, 27 January 2010 16:25 Go to previous messageGo to next message
Neil,
The tables do not have to be grouped but they have to be nested. If you
have an outer table and two nested tables at the same level, you should
be able to see a plus for the outer but the inner tables will be on the
same level.
Jason
Neil Wang wrote:
> Hi Jason,
> table.
> please advise.
Re: PDF Table of Contents [message #510593 is a reply to message #510580] Wed, 27 January 2010 17:32 Go to previous messageGo to next message
Hi Jason,
This is something similar to what I have. I have a nested table but there is no plus sign in the pdf report bookmark.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.20" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.5.1.v20090903 Build &lt;2.5.1.v20090917-1447></property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source" id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set" id="8">
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property name="displayName">CUSTOMERNAME</text-property>
</structure>
</list-property>
<structure>
<property name="name">CUSTOMERNAME</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.CUSTOMERS.CUSTOMERNAME
from CLASSICMODELS.CUSTOMERS]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Data Set1" id="9">
<structure>
<property name="columnName">LASTNAME</property>
<text-property name="displayName">LASTNAME</text-property>
</structure>
</list-property>
<structure>
<property name="name">LASTNAME</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">LASTNAME</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select CLASSICMODELS.EMPLOYEES.LASTNAME
from CLASSICMODELS.EMPLOYEES]]></xml-property>
<design:attributes>
<design:name>LASTNAME</design:name>
<design:uiHints>
<design:displayName>LASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>LASTNAME</design:label>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<expression name="expression">dataSetRow["CUSTOMERNAME"]</expression >
</structure>
</list-property>
<column id="17"/>
<header>
<row id="11">
<cell id="12">
<label id="18">
<text-property name="text">CUSTOMERNAME</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<data id="19">
<expression name="expressionValue" type="javascript">row["CUSTOMERNAME"]</expression>
</structure>
<property name="resultSetColumn">CUSTOMERNAME</property>
</data>
</cell>
</row>
<row id="20">
<cell id="21">
<table id="22">
<property name="dataSet">Data Set1</property>
<structure>
<expression name="expression">dataSetRow["LASTNAME"]</expression>
</structure>
</list-property>
<column id="29"/>
<header>
<row id="23">
<cell id="24">
<label id="30">
<text-property name="text">LASTNAME</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="25">
<cell id="26">
<data id="31">
<expression name="expressionValue" type="javascript">row["LASTNAME"]</expression>
</structure>
<property name="resultSetColumn">LASTNAME</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="27">
<cell id="28"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
</row>
</footer>
</table>
</body>
</report>
Re: PDF Table of Contents [message #510804 is a reply to message #510593] Thu, 28 January 2010 07:04 Go to previous messageGo to next message
Neil,
Take a look at the attached rpt. Is this what you want?
Jason
id="1">
<data-sources>
<oda-data-source
id="7">
<ex-property>
</ex-property>
<ex-property>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<text-property
<expression
</structure>
</list-property>
type="javascript">"outertable";</expression>
</structure>
<column id="17"/>
<header>
<row id="11">
<cell id="12">
<label id="18">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<data id="19">
</structure>
<property
</data>
</cell>
</row>
<row id="20">
<cell id="21">
<table id="22">
<structure>
<property
<text-property
<expression
<property
</structure>
</list-property>
type="javascript">"innertable";</expression>
</structure>
<column id="29"/>
<header>
<row id="23">
<cell id="24">
<label id="30">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="25">
<cell id="26">
<data id="31">
<expression
</structure>
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="27">
<cell id="28"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
</row>
</footer>
</table>
</body>
</report>
Neil Wang wrote:
> Hi Jason,
> id="1">
> 2.5.1.v20090903 Build <2.5.1.v20090917-1447></property>
> <data-sources>
> <oda-data-source
> id="7">
> <ex-property>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> <text-property
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> <oda-data-set
> <structure>
> <text-property
> </structure>
> </list-property>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <model:DesignValues
> <design:attributes>
> <design:uiHints>
> </design:uiHints>
> <design:usageHints>
> ]]></xml-property>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="10">
> <structure>
> <text-property
> <expression
> </structure>
> </list-property>
> <column id="17"/>
> <header>
> <row id="11">
> <cell id="12">
> <label id="18">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="13">
> <cell id="14">
> <data id="19">
> </structure>
> <property
> </data>
> </cell>
> </row>
> <row id="20">
> <cell id="21">
> <table id="22">
> <structure>
> <property
> <text-property
> <expression
> <property
> </structure>
> </list-property>
> <column id="29"/>
> <header>
> <row id="23">
> <cell id="24">
> <label id="30">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="25">
> <cell id="26">
> <data id="31">
> <expression
> </structure>
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="27">
> <cell id="28"/>
> </row>
> </footer>
> </table>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="15">
> <cell id="16"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: PDF Table of Contents [message #510817 is a reply to message #510804] Thu, 28 January 2010 12:32 Go to previous messageGo to next message
Hi Jason,
Thanks for the reply.
This is what I am looking for:
+CUSTOMERNAME
Expanding the plus sign, we get
-CUSTOMERNAME
LASTNAME
I used to be able to achieve it by using table groups; however, I don't have table groups anymore.
Right now, it seems like the format is:
-outertable
CUSTOMERNAME
+innertable
-outertable
CUSTOMERNAME
-innertable
LASTNAME
The question is, does the "innertable" level have to be there in order for the plus sign to show up?
I assume it does but would like to confirm it.
regards,
Neil
Re: PDF Table of Contents [message #510830 is a reply to message #510817] Thu, 28 January 2010 13:38 Go to previous messageGo to next message
Neil,
This can be done with the addition of a grid. Take a look:
Jason
id="1">
<data-sources>
<oda-data-source
id="7">
<ex-property>
</ex-property>
<ex-property>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
<oda-data-set
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="10">
<structure>
<text-property
<expression
</structure>
</list-property>
<column id="17"/>
<header>
<row id="11">
<cell id="12">
<label id="18">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="13">
<cell id="14">
<data id="19">
<property
</data>
</cell>
</row>
<row id="20">
<cell id="21">
<grid id="48">
</structure>
<column id="49"/>
<row id="50">
<cell id="51">
<table id="22">
Set1</property>
<list-property
<structure>
<property
<text-property
<expression
<property
</structure>
</list-property>
<column id="29"/>
<header>
<row id="23">
<cell id="24">
<label id="30">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="25">
<cell id="26">
<data id="31">
<structure
name="toc">
<expression
</structure>
<property
</data>
</cell>
</row>
</detail>
<footer>
<row id="27">
<cell id="28"/>
</row>
</footer>
</table>
</cell>
</row>
</grid>
</cell>
</row>
</detail>
<footer>
<row id="15">
<cell id="16"/>
</row>
</footer>
</table>
</body>
</report>
Neil Wang wrote:
> Hi Jason,
> +CUSTOMERNAME
> -CUSTOMERNAME
> LASTNAME
> -outertable
> CUSTOMERNAME
> +innertable
> -outertable
> CUSTOMERNAME
> -innertable
> LASTNAME
> regards,
> Neil
Re: PDF Table of Contents [message #510841 is a reply to message #510830] Thu, 28 January 2010 14:17 Go to previous message
Hi Jason,
It works fine now. thanks a lot~
Previous Topic:Getting too space between 2 paragraphs in Html Text
Next Topic:ROM element VariableElement changed from BIRT 2.3.0 -> 2.5.1 ?
Current Time: Sat Jul 19 01:12:41 EDT 2025
Powered by FUDForum. Page generated in 0.05538 seconds
