run as eclipse application [message #510605] |
Wed, 27 January 2010 18:25  |
I try to build a EMF-based meta-model, I had built some meta-models and a friend of mine sent me a couple.
I open an EMF project, created (open) Ecore file, created the genmodel file and applied generate all in order to generate all relevant files.
However, I failed to use the Run as eclipse application, actually instead there is the message none applicable, I open the Run configurations and there is no eclipse application
I would appreciate any help
Azzam
Re: run as eclipse application [message #510608 is a reply to message #510605] |
Wed, 27 January 2010 18:31  |
Azzam,
Someone else complained about something similar a while back and it
turned out they didn't have the PDE (Plugin Development Environment)
installed. So that would be my guess.
> and a friend of mine sent me a couple. I open an EMF project, created
> Azzam
FUDForum. Page generated in 0.26041 seconds
