Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » clause "implements" for a EMF generated class
clause "implements" for a EMF generated class [message #510497] Wed, 27 January 2010 11:25 Go to next message
Hi.
I want to declare a clause "implements" for a class which is regenerated using EMF ecore.
If I change the tag @generated adding NOT, to get the "implements" untouched, the code of the class will not be generated...
But if I leave the tag @generated without NOT, when the code was generated, "implements" will be deleted.
So, have you got any suggestion about this issue?
Thanks in advance,
Carlos.
Re: clause "implements" for a EMF generated class [message #510566 is a reply to message #510497] Wed, 27 January 2010 11:02 Go to previous messageGo to next message
Carlos,
There's an @implements tag you can add to the user-doc section to
specify things to be added to the implements clause.
Carlos wrote:
> Hi.
> Thanks in advance,
> Carlos.
Re: clause "implements" for a EMF generated class [message #622056 is a reply to message #510497] Wed, 27 January 2010 15:55 Go to previous message
Carlos,
Carlos wrote:
> Hi.
> Thanks in advance,
> Carlos.
Previous Topic:MWE: capture log output?
Next Topic:Ecoretools sources not included in the SDK
Current Time: Sat Jul 19 01:06:33 EDT 2025
Powered by FUDForum. Page generated in 0.50741 seconds
