Home » Language IDEs » ServerTools (WTP) » Can't find apache tomcat from eclipse
icon5.gif  Can't find apache tomcat from eclipse [message #510298] Wed, 27 January 2010 02:48 Go to next message
Hi all,
I wanted to create a server to communicate with iPhone application. So I installed Eclipse, WTP, Sysdeo Tomcat, but when I go Eclipse->Preferences->Server->Runtime Environments->Add, I can't see Apache Server Tomcat 5.5! I installed Apache Tomcat 5.5.28 and specified the home path in Preferences->Tomcat, but nothing is showing when I try to add a server (it cannot find the server). I was searching on the net for a long time but I can't seem to fix this problem. Can anyone help me with this issue?
Your help is greatly appreciated!
Deksa
P.S.: Thanks to Angel Vera for redirecting me to this forum!
P.P.S: I wanted to send you some screenshots but I cannot see a place to attach them. (when I tried on the preview with a screenshot from my mac, it didn't render so I presume it is not going to work)
Here is the eclipse error log file (as requested by Angel Vera):
!SESSION 2010-01-22 11:32:36.311 -----------------------------------------------
eclipse.buildId=M20090917-0800
java.version=1.6.0_17
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
Framework arguments: -keyring /Users/x/.eclipse_keyring -showlocation
Command-line arguments: -os macosx -ws carbon -arch x86 -keyring /Users/x/.eclipse_keyring -showlocation
!ENTRY org.eclipse.core.net 1 0 2010-01-22 11:33:02.520
!MESSAGE System property http.nonProxyHosts has been set to local|*.local|169.254/16|*.169.254/16 by an external source. This value will be overwritten using the values from the preferences
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-01-22 11:52:40.420
!MESSAGE Operation details
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.420
!MESSAGE Cannot complete the install because one or more required items could not be found.
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.420
!MESSAGE Software being installed: WST Web Tests 3.1.1.v200908121630-79-F_WEVVFGGImMiIwcr (org.eclipse.wst.web_tests.feature.feature.group 3.1.1.v200908121630-79-F_WEVVFGGImMiIwcr)
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.421
!MESSAGE Missing requirement: HTML UI Performance tests Plug-in 1.0.300.v200810071857 (org.eclipse.wst.html.ui.tests.performance 1.0.300.v200810071857) requires 'bundle org.eclipse.test 0.0.0' but it could not be found
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.421
!MESSAGE Cannot satisfy dependency:
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.421
!MESSAGE From: WST Web Tests 3.1.1.v200908121630-79-F_WEVVFGGImMiIwcr (org.eclipse.wst.web_tests.feature.feature.group 3.1.1.v200908121630-79-F_WEVVFGGImMiIwcr)
!MESSAGE To: org.eclipse.wst.html.ui.tests.performance [1.0.300.v200810071857]
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-01-22 11:52:40.421
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.421
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-01-22 11:52:40.446
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.446
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.446
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.446
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.446
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-01-22 11:52:40.467
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.467
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.467
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 1 2010-01-22 11:52:40.467
!SUBENTRY 3 org.eclipse.equinox.p2.director 4 0 2010-01-22 11:52:40.467
!ENTRY org.eclipse.equinox.p2.repository 2 0 2010-01-22 11:54:28.013
!MESSAGE Connection to http://eclipse.ialto.org/releases/galileo/aggregate/plugins/ org.eclipse.datatools.connectivity.apache.derby_1.0.100.v200 906020900.jar.pack.gz failed on Unable to parse header: </a></div>. Retry attempt 0 started
!STACK 0
org.apache.commons.httpclient.ProtocolException: Unable to parse header: </a></div>
at org.apache.commons.httpclient.HttpParser.parseHeaders(HttpPa rser.java:202)
at org.apache.commons.httpclient.HttpMethodBase.readResponseHea ders(HttpMethodBase.java:1935)
at org.apache.commons.httpclient.HttpMethodBase.readResponse(Ht tpMethodBase.java:1737)
at org.apache.commons.httpclient.HttpMethodBase.execute(HttpMet hodBase.java:1098)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientR etrieveFileTransfer$GzipGetMethod.execute(HttpClientRetrieve FileTransfer.java:113)
at org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:398)
at org.apache.commons.httpclient.HttpMethodDirector.executeMeth od(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpC lient.java:346)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientR etrieveFileTransfer.performConnect(HttpClientRetrieveFileTra nsfer.java:1017)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientR etrieveFileTransfer.openStreams(HttpClientRetrieveFileTransf er.java:610)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:808)
at org.eclipse.ecf.provider.filetransfer.retrieve.AbstractRetri eveFileTransfer.sendRetrieveRequest(AbstractRetrieveFileTran sfer.java:506)
at org.eclipse.ecf.provider.filetransfer.retrieve.MultiProtocol RetrieveAdapter.sendRetrieveRequest(MultiProtocolRetrieveAda pter.java:98)
at org.eclipse.equinox.internal.p2.repository.FileReader.sendRe trieveRequest(FileReader.java:317)
at org.eclipse.equinox.internal.p2.repository.FileReader.readIn to(FileReader.java:263)
at org.eclipse.equinox.internal.p2.repository.RepositoryTranspo rt.download(RepositoryTransport.java:71)
at org.eclipse.equinox.internal.p2.repository.RepositoryTranspo rt.download(RepositoryTransport.java:127)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:468)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:451)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:518)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.getArtifact(MirrorRequest.java:200)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:175)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:159)
at org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:95)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:507)
at org.eclipse.equinox.internal.p2.artifact.repository.simple.D ownloadJob.run(DownloadJob.java:64)
!SESSION 2010-01-22 11:56:19.736 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-22 11:56:31.667
!ENTRY org.eclipse.osgi 2 1 2010-01-22 12:03:31.338
!MESSAGE NLS unused message: contextRootLabelInvalid in: org.eclipse.jst.servlet.ui.project.facet.WebFacetInstallPage
!MESSAGE NLS unused message: contentDirLabelInvalid in: org.eclipse.jst.servlet.ui.project.facet.WebFacetInstallPage
!SESSION 2010-01-25 09:15:50.877 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 09:16:03.192
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-01-25 09:27:50.294
!MESSAGE Unable to load the repository http://www.sysdeo.com/eclipse/tomcatplugin
!STACK 1
org.eclipse.equinox.internal.provisional.p2.core.ProvisionEx ception: Unknown Host: http://www.sysdeo.com/eclipse/tomcatplugin/content.xml
at org.eclipse.equinox.internal.p2.metadata.repository.CacheMan ager.createCache(CacheManager.java:179)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.getLocalFile(SimpleM etadataRepositoryFactory.java:60)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.validateAndLoad(Simp leMetadataRepositoryFactory.java:99)
at org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository.SimpleMetadataRepositoryFactory.load(SimpleMetadataR epositoryFactory.java:87)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.factoryLoad(MetadataRepositoryManager.java :54)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:669)
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractR epositoryManager.loadRepository(AbstractRepositoryManager.ja va:617)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:92)
at org.eclipse.equinox.internal.p2.metadata.repository.Metadata RepositoryManager.loadRepository(MetadataRepositoryManager.j ava:88)
at org.eclipse.equinox.internal.provisional.p2.ui.operations.Pr ovisioningUtil.loadMetadataRepository(ProvisioningUtil.java: 88)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableMeta dataRepositoryManager.doLoadRepository(QueryableMetadataRepo sitoryManager.java:55)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadRepository(QueryableRepositoryManager.java :195)
at org.eclipse.equinox.internal.provisional.p2.ui.QueryableRepo sitoryManager.loadAll(QueryableRepositoryManager.java:108)
at org.eclipse.equinox.internal.p2.ui.sdk.PreloadingRepositoryH andler$2.run(PreloadingRepositoryHandler.java:71)
Caused by: java.net.UnknownHostException: www.sysdeo.com
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:177)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:432)
at java.net.Socket.connect(Socket.java:525)
at org.eclipse.ecf.provider.filetransfer.events.socket.SocketEv entCreateUtil.createSocket(SocketEventCreateUtil.java:43)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:81)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:73)
at org.eclipse.ecf.internal.provider.filetransfer.httpclient.EC FHttpClientProtocolSocketFactory.createSocket(ECFHttpClientP rotocolSocketFactory.java:65)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnec tion.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionMan ager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionM anager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWith Retry(HttpMethodDirector.java:387)
at org.eclipse.ecf.provider.filetransfer.httpclient.HttpClientF ileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java :204)
at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSys temBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:7 1)
... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1006 2010-01-25 09:27:50.295
!MESSAGE Unknown Host: http://www.sysdeo.com/eclipse/tomcatplugin/content.xml
!STACK 0
!SESSION 2010-01-25 09:38:47.865 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 09:38:51.938
!SESSION 2010-01-25 09:45:08.313 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 09:45:12.430
!ENTRY org.eclipse.equinox.p2.ui 4 0 2010-01-25 09:46:20.436
!STACK 1
... 1 more
!SUBENTRY 1 org.eclipse.equinox.p2.repository 4 1006 2010-01-25 09:46:20.437
!STACK 0
!SESSION 2010-01-25 10:10:38.055 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 10:10:44.911
!SESSION 2010-01-25 10:21:33.591 -----------------------------------------------
Command-line arguments: -os macosx -ws carbon -arch x86 -clean
!ENTRY org.eclipse.core.net 1 0 2010-01-25 10:21:48.142
!SESSION 2010-01-25 10:25:12.662 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 10:25:24.181
!SESSION 2010-01-25 10:34:27.416 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 10:34:33.063
!ENTRY org.eclipse.osgi 2 1 2010-01-25 10:35:52.407
!ENTRY org.eclipse.equinox.p2.director 4 1 2010-01-25 10:55:50.442
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 0 2010-01-25 10:55:50.442
!MESSAGE Software currently installed: Jonas WTP Adapter 5.1.0 (org.ow2.jonas.wtp.adapter.feature.group 5.1.0)
!MESSAGE Missing requirement: org.ow2.jonas.wtp.adapter.ui 5.1.0 requires 'bundle org.eclipse.jst.server.generic.ui 0.0.0' but it could not be found
!SUBENTRY 1 org.eclipse.equinox.p2.director 4 1 2010-01-25 10:55:50.442
!SUBENTRY 2 org.eclipse.equinox.p2.director 4 0 2010-01-25 10:55:50.442
!MESSAGE From: Jonas WTP Adapter 5.1.0 (org.ow2.jonas.wtp.adapter.feature.group 5.1.0)
!MESSAGE To: org.ow2.jonas.wtp.adapter.ui [5.1.0]
!SESSION 2010-01-25 11:00:43.238 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-25 11:00:48.916
!SESSION 2010-01-26 09:12:19.132 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-26 09:12:30.816
!SESSION 2010-01-26 09:58:48.777 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-26 09:58:54.404
!SESSION 2010-01-27 08:20:54.917 -----------------------------------------------
!ENTRY org.eclipse.core.net 1 0 2010-01-27 08:21:05.672
Re: Can't find apache tomcat from eclipse [message #510439 is a reply to message #510298] Wed, 27 January 2010 09:34 Go to previous messageGo to next message
When you go to Eclipse->Preferences->Server->Runtime Environments->Add,
what categories do you see?
Larry
P.S. In case you weren't aware, Sysdeo Tomcat is separate implementation
of Tomcat server support. Unless something has changed, it does not
integrate with WTP, i.e. it has it's own "web" project type and doesn't
work with WTP's Dynamic Web Projects.
Deksa wrote:
> Hi all,
> with this issue?
> Deksa
<snip/>
Re: Can't find apache tomcat from eclipse [message #510590 is a reply to message #510439] Wed, 27 January 2010 17:17 Go to previous messageGo to next message
Hi Larry,
It shows only "J2EE Runtime Library". Nothing more.
I started tomcat on the machine (from console and tried the supplied sample jsp - it works), but it seems like there is some dependency missing in the eclipse.
Is there a place where I can specify to the eclipse the home of tomcat? Does he find these runtime environments automatically?
I know about sysdeo tomcat plug-in. I remember using wtp and I didn't remember if I used sysdeo and wtp together so I tried downloading that plugin also... but I need wtp working.
Anyway thanks for the reply!
Kind Regards,
Deksa
Re: Can't find apache tomcat from eclipse [message #510616 is a reply to message #510590] Wed, 27 January 2010 20:16 Go to previous messageGo to next message
On 1/27/2010 5:17 PM, Deksa wrote:
> It shows only "J2EE Runtime Library". Nothing more. I started tomcat on
> but it seems like there is some dependency missing in the eclipse. Is
You would normally set up Tomcat as a server runtime on a preference
page under the "Server" category.
If this is a Tomcat package installed as part of your OS, it's most
likely had its layout altered from the builds you would get directly
from http://tomcat.apache.org/ The layout of those builds is what's
expected as it's the only one WTP can reliably predict.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Can't find apache tomcat from eclipse [message #510617 is a reply to message #510590] Wed, 27 January 2010 15:46 Go to previous messageGo to next message
Deksa wrote:
> Hi Larry,
> Kind Regards,
> Deksa
Other categories should be listed in this preference page regardless of
the presence of the servers on your system. It indicates that a number
of WTP server related plug-ins are not running. Unfortunately, I don't
know off the top of my head what missing dependency would cause those
plug-ins not to run and not take out the "Eclipse->Preferences->Server"
preference page as well.
You could try the technique I use when trying to diagnose dependency
issues, which is to add "-debug" and "-clean" to the Eclipse startup
arguments. If added to the eclipse.ini file, they should appear each on
their own line and above the "-vmargs" line. The "-debug" will cause
the Error Log view to list plug-ins (called bundles) which don't
"resolve", i.e. can't run due to missing dependencies. The "-clean"
forces Eclipse to resolve all the bundles again, which Eclipse would
otherwise skip since it has already been done and would make startup
time unnecessarily longer. When Eclipse finally starts, open the Error
Log to see which bundles didn't resolve.
If this problem is due to missing dependencies,
"org.eclipse.jst.server.tomcat.core" should be one of those bundles that
didn't resolve. If you expand that item, it should show what
dependencies it is missing. These missing dependencies may actually be
missing, but could also be a "cascade" problem because that bundle is
missing one or more of it's dependencies. Finding the "root" missing
dependencies can be a bit of a challenge sometimes. If you are able to
try this, is "org.eclipse.jst.server.tomcat.core" unresolved and what
are its missing bundles?
Larry
Re: Can't find apache tomcat from eclipse [message #510782 is a reply to message #510617] Thu, 28 January 2010 10:44 Go to previous message
application. So I
specified
I try
the net
help me
> with this issue?
items
> could not be found.
10:55:50.442
10:55:50.442
could
> not be found
You have WTP's prereqs installed, right, such as the right version
of EMF in particular? Did you put this installation together
manually, or did you start with the Galileo SR1 "Eclipse IDE for
Java EE Developers"?
Nitin Dahyabhai
IBM Rational
Previous Topic:STDERR in red in eclipse for tomcat 5.5
Next Topic:WTP project API/extension
Current Time: Wed Jul 23 10:09:13 EDT 2025
Powered by FUDForum. Page generated in 0.07917 seconds
