Home » Language IDEs » Java Development Tools (JDT) » How to change syntax highlighting colors (for XML) ?
How to change syntax highlighting colors (for XML) ? [message #509427] Fri, 22 January 2010 07:38 Go to next message
Assume I currently editing an XML file.
How can I change the current highlighting colors schema?
How can I export this new XML color schema and import it in another Eclipse installation?
Ben
Re: How to change syntax highlighting colors (for XML) ? [message #509431 is a reply to message #509427] Fri, 22 January 2010 02:46 Go to previous messageGo to next message
Which plugin you use?
If you plugin has extended the colors preference, you should be see
it in Preferences-> General->Appearance->Colors and Fonts.
Again, your plugin should have extended the preference export
(File->Export->Preferences)
- Prakash
Platform UI Team, IBM
Blog <http://blog.eclipse-tips.com>
Twitter <http://www.twitter.com/Eclipse_Tips>
Re: How to change syntax highlighting colors (for XML) ? [message #510419 is a reply to message #509431] Wed, 27 January 2010 08:52 Go to previous message
Prakash G.R. wrote on Fri, 22 January 2010 02:46
Why is this important?
I downloaded Galileo Java EE IDE and imported some XSD/XML files. That's it.
Is there no general, default highlighting schema?
How can I find out otherwise which "plugin" is currently used?
How do I find out if "my" plugin extend the colors preferences?
What if "my" plugin did NOT extend the colors preferences?
Which color preferences are used then by default?
Ben
Previous Topic:HELP ME ABOUT nWire
Next Topic:Different text fonts for read only files
Current Time: Sat Jul 19 00:43:10 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
