Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP AGR newbi has some questions
TPTP AGR newbi has some questions [message #510341] Wed, 27 January 2010 05:22 Go to next message
I am a newbe in TPTP AGR and I have some questions about it.
1. Is there a chance to export the test.execution file into a xml file, which will generate by a test.
2. The testreport which can be generatet contains only the count of testcases and a result, but no names for the single testcases and no how lang takes the only testcases or was was the resukt of the single testcases. Is there a chance to get these results in a report.
3. Can I export the test scripts for the test cases also into xml files. I want to do this for saving the testscripts and maka diffs between two versions of a script.
Re: TPTP AGR newbi has some questions [message #510372 is a reply to message #510341] Wed, 27 January 2010 06:30 Go to previous message
Hi Michelle,
Please my answers below:
Paul
"Michelle Davidson" <michelle.davidson@gmx.de> wrote in message
news:hjp44i$9ps$1@build.eclipse.org...
> Hello,
Yes, using the as-is XML Test Report in the Business Intelligence and
Reporting Tools (BIRT) Test Reports (see
http://www.eclipse.org/tptp/home/downloads/?buildId=TPTP-4.7 .0-201001261900#AsIsComponents).
Yes, using the as-is Tabular Test Pass Report in the Business Intelligence
and Reporting Tools (BIRT) Test Reports (see
For example:
http://www.eclipse.org/tptp/test/reports/4.6.2_i2_TP1/index. html
Note, none of he reports will contain timing inforamation at the test case
level, only at the test suite level.
No. However, they are serialized to compressed XMI files, which can be
opened using a uncompress utility (e.g. WinZip or 7-Zip) for comparison.
Previous Topic:Sugestion to update the help.
Next Topic:Access to Variables of testcase in VerificationHooksMethode
Current Time: Sun Jul 27 09:12:02 EDT 2025
Powered by FUDForum. Page generated in 0.03911 seconds
