Home » Eclipse Projects » Standard Widget Toolkit (SWT) » OLE embedding and paste automation for Word(How to execute "paste" command using swt.ole.win32?)
OLE embedding and paste automation for Word [message #494744] Mon, 02 November 2009 08:41 Go to next message
I have successfully used the stuff in org.eclipse.swt.ole.win32 to embed Microsoft Word in a SWT shell. For example (layout, exeption handling etc removed):
Display swtDisplay = new Display();
Shell swtShell = new Shell(swtDisplay);
swtShell.open();
Menu menuBar = new Menu(swtShell, SWT.BAR);
swtShell.setMenuBar(menuBar);
OleFrame oleFrame = new OleFrame(swtShell, SWT.NONE);
OleClientSite site = new OleClientSite(oleFrame, SWT.NONE, "Word.Document");
site.doVerb(org.eclipse.swt.ole.win32.OLE.OLEIVERB_SHOW);
while (!swtShell.isDisposed ()) {
  if (!swtDisplay.readAndDispatch()) swtDisplay.sleep ();
This works perfectly, with Word (and own "container") menus etc displaying and working correctly. But next I would like to command Word to paste data from clipboard to cursor position. I tried:
if((site.queryStatus(OLE.OLECMDID_PASTE) & OLE.OLECMDF_ENABLED) != 0) {
  site.exec(OLE.OLECMDID_PASTE, OLE.OLECMDEXECOPT_DONTPROMPTUSER, null, null);
But it seems that OLECMDID_PASTE is neither ENABLED or even SUPPORTED. I went through all the OLECMDIDs, and some of them were ENABLED and worked nicely. None of copy/cut/paste trio did work.
I also tried with Excel, and paste did not work with it either. I have Office 2003.
So, is this a feature of Office programs, or is there a problem with SWT OLE, or am I doing something funny, ...?
Maybe there is an alternative way to do this using OLE Automation, but I could not figure out how to do that.
I got it to "somewhat working state" by using java.awt.Robot to issue ctrl-v key press event, but I'd really like some real solution Very Happy
So, thank you for any insight.
[Updated on: Mon, 02 November 2009 08:42] by Moderator
Re: OLE embedding and paste automation for Word [message #495058 is a reply to message #494744] Tue, 03 November 2009 11:36 Go to previous messageGo to next message
I don't know why queryStatus(...) is answering 0, but if it's giving other
results for other commands then presumably it's working in swt, and for some
reason Word just doesn't want Paste to be invoked this way. This can be
done with OLE Automation instead, the lines you need are:
OleAutomation document = new OleAutomation(clientSite);
int[] ids = document.getIDsOfNames(new String[] {"Application"});
Variant result = document.getProperty(ids[0]);
document.dispose();
OleAutomation application = result.getAutomation();
result.dispose();
ids = application.getIDsOfNames(new String[] {"Selection"});
result = application.getProperty(ids[0]);
application.dispose();
OleAutomation selection = result.getAutomation();
result.dispose();
ids = selection.getIDsOfNames(new String[] {"Paste"});
selection.invoke(ids[0]);
selection.dispose();
Grant
"Tuomo" <thyyryla@cc.hut.fi> wrote in message
news:hcmnht$180$1@build.eclipse.org...
removed):
> swtShell.open();
"Word.Document");
null);
nicely. None of copy/cur/paste trio did work.
Office 2003.
ctrl-v key press event, but I'd really like some real solution :d
Re: OLE embedding and paste automation for Word [message #495205 is a reply to message #494744] Wed, 04 November 2009 02:39 Go to previous messageGo to next message
Thank you Grant!
Now it is working nicely.
Tuomo
Re: OLE embedding and paste automation for Word [message #495310 is a reply to message #495205] Wed, 04 November 2009 09:46 Go to previous messageGo to next message
I just noticed one small problem in the lines I provided:
"selection.invoke(ids[0]);" should become "result =
selection.invoke(ids[0]); result.dispose();"
Grant
news:hcrb4f$t94$1@build.eclipse.org...
> Thank you Grant!
> Regards,
> Tuomo
Re: OLE embedding and paste automation for Word [message #498111 is a reply to message #495310] Sat, 14 November 2009 10:37 Go to previous messageGo to next message
Hi Grant,
I also want to thank you. I was looking for the Paste operation, but encountered the same problems reported by Tuomo. So your answer was very welcome.
Still, now I am trying to make the "SelectAll", then "Copy" operation, (still with Word ActiveX) but I am not able to do it.
Do you have the solution also for this? Anyway in these situations, where can we find documentation on how to do these common operation?
Thank you in advance
Vincenzo Caselli
Re: OLE embedding and paste automation for Word [message #498354 is a reply to message #498111] Mon, 16 November 2009 09:50 Go to previous messageGo to next message
Hi Vincenzo,
The documentation on MSDN is generally pretty good. The links that are
applicable to these cases are:
Document: http://msdn.microsoft.com/en-us/library/bb257531.aspx
Application: http://msdn.microsoft.com/en-us/library/bb244569.aspx
Selection: http://msdn.microsoft.com/en-us/library/bb259574.aspx
To do the select all I think you invoke Document.Select(), and to do the
copy invoke Selection.Copy().
Grant
"Vincenzo Caselli" <v.caselli@rcp-vision.com> wrote in message
news:hdmiqu$8ib$1@build.eclipse.org...
> Hi Grant,
welcome.
> Vincenzo Caselli
Re: OLE embedding and paste automation for Word [message #508700 is a reply to message #498354] Tue, 19 January 2010 17:05 Go to previous messageGo to next message
Now I would like to go to the end of the document.
I've read the MS links, but can't understand how to apply the concepts in Java ...
It seems that the right command is "EndKey" on the "Selection" object, but still I am not able to invoke it correctly
someone can help?
Vincenzo
Re: OLE embedding and paste automation for Word [message #509902 is a reply to message #508700] Mon, 25 January 2010 12:20 Go to previous message
If the passing of function arguments is what you're wondering about, you
need to get their ids when getting the function's id, and provide these ids
along with the argument values. This would look like:
ids = selection.getIDsOfNames(new String[] {"EndKey", "Unit"});
int[] argIds = {ids[1]};
Variant[] args = new Variant[1];
args[0] = new Variant(4 /* wdParagraph */);
selection.invoke(ids[0], args, argIds);
args[0].dispose();
I did a quick experiment and invoking EndKey didn't have the desired effect
(I have Word 2000 installed, perhaps this works in newer versions?). I'm
sure there's a command somewhere for doing this that can be invoked using an
approach like the one here.
Grant
news:hj5aah$avv$1@build.eclipse.org...
Java ...
> someone can help?
> Thanks
> Vincenzo
Previous Topic:FormLayout and child relative height
Next Topic:Let JAWS Reads Line numbers
Current Time: Thu Jul 17 17:01:32 EDT 2025
Powered by FUDForum. Page generated in 0.29901 seconds
