Problem with database connection (postgresql) [message #509653] |
Sun, 24 January 2010 05:38  |
Hi all,
I downloaded the BIRT all-in-one package 2.5.1 and the latest jdbc4 driver for postgresql from http://jdbc.postgresql.org/. Unfortunately I'm not able to connect to my database; when I click 'Test connection' I get this error:
Quote: | org.eclipse.birt.report.data.oda.jdbc.JDBCException: There is an error in get connection, Der Verbindungsversuch schlug fehl..
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.doCo nnect(JDBCDriverManager.java:262)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.getC onnection(JDBCDriverManager.java:186)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.tryC reateConnection(JDBCDriverManager.java:706)
at org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager.test Connection(JDBCDriverManager.java:612)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.t estConnection(DriverLoader.java:120)
at org.eclipse.birt.report.data.oda.jdbc.ui.util.DriverLoader.t estConnection(DriverLoader.java:133)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.testConnection(JDBCSelectionPageHelper.java:653 )
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper.access$7(JDBCSelectionPageHelper.java:627)
at org.eclipse.birt.report.data.oda.jdbc.ui.profile.JDBCSelecti onPageHelper$7.widgetSelected(JDBCSelectionPageHelper.java:5 49)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.birt.report.designer.ui.dialogs.BaseDialog.open( BaseDialog.java:110)
at org.eclipse.birt.report.designer.data.ui.providers.EditableD ataSourceNodeProvider.performEdit(EditableDataSourceNodeProv ider.java:72)
at org.eclipse.birt.report.designer.internal.ui.views.DefaultNo deProvider.performRequest(DefaultNodeProvider.java:426)
at org.eclipse.birt.report.designer.internal.ui.views.actions.E ditAction.doAction(EditAction.java:90)
at org.eclipse.birt.report.designer.internal.ui.views.actions.A bstractElementAction.run(AbstractElementAction.java:70)
at org.eclipse.birt.report.designer.internal.ui.views.RenameLis tener.doubleClick(RenameListener.java:214)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredV iewer.java:821)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(S tructuredViewer.java:819)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSel ect(AbstractTreeViewer.java:1419)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSe lected(StructuredViewer.java:1195)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEven t(OpenStrategy.java:238)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.ja va:235)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:296)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
I'm using BIRT on Debian Squeeze with Postgresql 8.4.1. I can connect to the database on the command line and with pgadmin.
All help on this issue is much appreciated.
Christoph
Re: Problem with database connection (postgresql) [message #513966 is a reply to message #511137] |
Thu, 11 February 2010 14:49   |
Christoph Eiden <ceidix@googlemail.com> writes:
> Jason,
> Yes, I double-checked and the driver is nowhere else in my classpath.
> I'll open a bug on this issue.
> Christoph
Hi all,
Just to close this issue, actually, it was caused by changes in Debian. I found a solution in message #505058:
| Originally posted by: gunnar.stahl.gunnarstahl.org
| The problem was caused by a pretty unbelievable thing introduced in debian. Found out that java was no longer able to do any sort of network connections anymore. Even connections to localhost failed...
| Someone decided to introduce a ipv6-only switch in netbase via /etc/sysctl.d/bindv6only.conf. While this may or may not be a usefull default behaviour for the general the result is that java is no longer able to do networking at all.
| So to solve it you have to edit /etc/sysctl.d/bindv6only.conf and
| change the value of net.ipv6.bindv6only from "1" to "0". Then do a
| "sudo invoke-rc.d procps restart". After that, java has networking
| again.
| Found that solution on "http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=560056".
After following this, the connection works fine.
Christoph
Re: Problem with database connection (postgresql) [message #513971 is a reply to message #513966] |
Thu, 11 February 2010 15:13  |
Thanks for adding this.
>> Jason,
>> Thanks,
>> Christoph
> Hi all,
> | again.
> Regards,
> Christoph
FUDForum. Page generated in 5.27719 seconds
