Use CSS to position div in a BIRT Report [message #509166] |
Thu, 21 January 2010 09:56  |
Hi all,
I'm trying to use an external css to position div elements I have created in my Birt report.
I use a Text element (with HTML Format) in which I have declared my div element. I have a css file which defines position of these div elements but I dont' achieve to use it. When I try the "Use CSS File" option in BIRT, BIRT doesn't recognize my style.
So, is it possible to do such a thing ? And, if it is, how ?
Thanx in advance for any help,
Jack
[Updated on: Thu, 21 January 2010 09:57] by Moderator
Re: Use CSS to position div in a BIRT Report [message #509852 is a reply to message #509842] |
Mon, 25 January 2010 10:27  |
Also do not put the style in the text element just the HTML.
Jason
Jason Weathersby wrote:
> Jack,
> Try to create a dummy css file to put in the resource folder when you
> are in the designer. When you use the external style sheet feature, use
> the check box to apply a view time css, which you should specify a file
> path or url to. Finally preview in the web viewer instead of the
> preview tab.
> Jason
> abedi wrote:
>> In fact, this css file comes from another web application, and the aim
>> is to use it as is.
>> So I can't inline the style like you told me.
>> As in an HMTL page, I'd like to use a CSS just by linking it
>> Jack
FUDForum. Page generated in 0.10437 seconds
