Home » Modeling » EMF » [CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore
[CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore [message #509760] Mon, 25 January 2010 05:29 Go to next message
After converting my application from Teneo/Hibernate to CDO (3.0) using a
Teneo Hibernate Datastore I have a problem with an EJavaObject not being
mapped anymore. Basically is it a java object that I would like to store
binary into the database. With teneo 1.0.1 it worked (using derby or mysql).
Attached is a text file with the hbm mapping and stack traces (log.txt).
Details:
Line 2728:
<property name="value" lazy="false" insert="true" update="true"
not-null="false" unique="false">
<column not-null="false" unique="false" name="`value`" length="1024"/>
<type
name=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">EJavaObject</param>
<param
name="epackage">http://www.eclipse.org/emf/2002/Ecore</param>
</type>
</property>
Exception:
Could not determine type for:
org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype, at
table: steptelegramcontent, for columns:
[org.hibernate.mapping.Column(value)]
org.hibernate.MappingException: Could not determine type for:
Any help is appreciated!
Cheers
Bj
  • Attachment: log.zip
    (Size: 16.16KB, Downloaded 144 times)
Re: [CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore [message #509778 is a reply to message #509760] Mon, 25 January 2010 06:28 Go to previous messageGo to next message
Hi Bjoern,
Yes this works very different than in Teneo. With CDO the types on the client (incl. user types) are not know on the
server. Afaiu CDO can not persist arbitrary user types as it needs to know how to (de-)serialize the objects when
sending them over from the client to the server and back.
Eike or others, how would this be handled? Is there a way that you can specify how an object value (not a native java
lang) should be send to the server?
Depending on how CDO sends the object to the server and represents it there, I can generate the correct mapping for
these non-mapped types.
Btw, I am not sure if this is a blocking issue for you, but you can annotate the efeature as transient then it won't be
persisted for now, so you are not stuck.
gr. Martin
> Details:
> Line 2728:
> <type
> <param
> </type>
> </property>
> Exception:
> Cheers
> Björn
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore [message #509785 is a reply to message #509778] Mon, 25 January 2010 02:28 Go to previous messageGo to next message
Hey Guys,
So far we've not been giving much thought on binary EDataTypes like java
objects or even streams. Currently all EDataTypes except the most
primitive ones and their wrappers have a special handling to make them
serialize efficiently. All other types and especially custom EDataTypes
(as opposed to the ones in Ecore) are (de-) serialized as Strings.
Cheers
/Eike
Martin Taal schrieb:
> Hi Bjoern,
> client (incl. user types) are not know on the server. Afaiu CDO can
> (de-)serialize the objects when sending them over from the client to
> specify how an object value (not a native java lang) should be send to
> the server?
> there, I can generate the correct mapping for these non-mapped types.
> annotate the efeature as transient then it won't be persisted for now,
> gr. Martin
>> using a Teneo Hibernate Datastore I have a problem with an
>> EJavaObject not being mapped anymore. Basically is it a java object
>> that I would like to store binary into the database. With teneo 1.0.1
>> it worked (using derby or mysql). Attached is a text file with the
>> Details:
>> Line 2728:
>> length="1024"/>
>> <type
>> <param
>> </type>
>> </property>
>> Exception:
>> Cheers
>> Björn
Re: [CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore [message #509790 is a reply to message #509778] Mon, 25 January 2010 07:41 Go to previous messageGo to next message
Hello Martin,
Thanks for the tip about annotating the efeature as transient, it will have to be a temporary workaround in order for me to go on with the feasibility tests I'm doing right now.
Cheers
Björn
Re: [CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore [message #509794 is a reply to message #509785] Mon, 25 January 2010 07:50 Go to previous messageGo to next message
Hi Eike,
Okay clear.
Is there a test case in the current test suite which shows this, use an unknown edatatype, case?
I need to make a small change in the mapping logic to handle this. For everyones info, here is the bugzilla covering it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=300659
gr. Martin
Eike Stepper wrote:
> Hey Guys,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hi Bjoern,
>> the server?
>> gr. Martin
>>> Details:
>>> Line 2728:
>>> length="1024"/>
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> Exception:
>>> Cheers
>>> Björn
The Netherlands
Re: [CDO Teneo] Problem mapping an EJavaObject using a CDO Server with a Hibernate Datastore [message #509801 is a reply to message #509794] Mon, 25 January 2010 07:55 Go to previous message
> Hi Eike,
> Okay clear.
Hard to say. But I couldn't find any ecore file with the string:
xsi:type="ecore:EDataType"
Cheers
/Eike
> gr. Martin
> Eike Stepper wrote:
>> Hey Guys,
>> Cheers
>> /Eike
>>> Hi Bjoern,
>>> the server?
>>> gr. Martin
>>>> Details:
>>>> Line 2728:
>>>> length="1024"/>
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> Exception:
>>>> Cheers
>>>> Björn
Previous Topic:[CDO Teneo] Cannot start a CDO Server with a Hibernate Datastore using a Derby Database
Next Topic:Containament reference upper bound
Current Time: Sat Jul 26 08:55:31 EDT 2025
Powered by FUDForum. Page generated in 0.06831 seconds
