Home » Modeling » EMF » Change in EMF Reference Navigability
Change in EMF Reference Navigability [message #509327] Thu, 21 January 2010 19:28 Go to next message
we have an EMF model in which we had the following reference :
A (1) ----------> (1) B (Older version)
we now changed the reference to be bi-directional as below:
A (1) ----------- (1) B (Current version)
after the change when any existing resource (created using the older version EMF model) is loaded, although both A and B get loaded, the reference between A and B is not created.
i tracked the cause down to the XMLHandler.setValueFromId() method.
if my understanding of the method is right, the reference is created (mustAdd=true) only if the reference is uni-directional or it is a bi-directional with cardinality
of A (1) ------- (*) B.
for our case of A (1) ----------- (1) B, since the reference is bi-directional with cardinality of A (1) ------- (1) B, the reference creation seems to be deferred till B is loaded.
while loading an existing resource (created using the prior EMF model), B does not know about the reference to A as the reference was initially uni-directional. as such, although
B gets loaded the reference to A is not created since the information is absent in the resource.
i would like some guidance on how to solve this issue.
one approach i can think of is to extend the XMLHandler and override the setValueFromId() method. but inorder to do that, i would like to have some insight on the existing implementation rationale and whether it is by intention or an oversight.
a second approach would be to set the option deferIDREFResolution=true while loading the resource.
that would set the mustAdd=true flag and force the creation of the reference.
any other suggestions would be much appreciated.
thanks,
- Hemant
Re: Change in EMF Reference Navigability [message #509399 is a reply to message #509327] Fri, 22 January 2010 01:34 Go to previous messageGo to next message
Hemant,
Comments below.
Hemant Kolwalkar wrote:
> reference.
Do these references need to span resources? If not, you should consider
making the B -> A reference transient. Then the other end will be set
and that will populate both ends.
> thanks,
> - Hemant
Re: Change in EMF Reference Navigability [message #509719 is a reply to message #509399] Mon, 25 January 2010 03:11 Go to previous message
Hi Ed,
the reference would not need to span resources with our current usage but one cannot rule it out the possibility in future.
as you suggested, i did try by setting B -> A reference transient in the Rose model. but when i tried to reload the genmodel, i get the error message "Cross document bidirectional reference must not be transient; reference 'B' -> 'A' ".
also would'nt setting to "transient =true" exclude the reference from serialization to the resource? if thats rue then that approach may not work for our use-case.
what is your take on the deferIDREFResolution=true approach? from the documentation, doing so also would help in improving loading performance is definitely welcome. any downsides to using the deferIDREFResolution?
thanks,
- Hemant
Re: Change in EMF Reference Navigability [message #509747 is a reply to message #509719] Mon, 25 January 2010 00:00 Go to previous message
Hermant,
Comments below.
> Hi Ed,
You'd also need to turn off proxy resolving, that's why I was asking
about the need for cross document references.
That won't help the cross document case. In that case you must have a
proxy at both ends and since your older serialization doesn't include
that, you'll have to do more than just fiddle with the model's settings.
It has to build a table so will use more memory, but if there are lots
of forward references, it has to do that anyway.
> thanks,
> - Hemant
Previous Topic:Get rid of Example EMF Model Creation Wizards
Next Topic:NullPointer at org.eclipse.emf.common.EMFPlugin$InternalHelper.log(EMFPlugin.java:736)
Current Time: Fri Jul 18 17:21:59 EDT 2025
Powered by FUDForum. Page generated in 0.04239 seconds
