Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Nested calls to 'iterate' method
[Acceleo] Nested calls to 'iterate' method [message #509636] Sat, 23 January 2010 16:47 Go to next message
is it possible to make nested calls to 'iterate' method?
my problem is:
i want to get the type of all paramethers of an method. This is very easy to do by using 'for' loops (consider i an interface):
[for (op : Operation | i.operations)]
[for (at : Parameter | op.parameters)]
	[at.type.name/]
[/for]
[/for]
This code is working, but i want to do this using a query. I've tried the code below but it does not return any value:
[query public getParametersPackage(i : Interface) : Sequence(T) =
	i.operations->iterate(elem; res: Sequence(String) = Sequence{} |
	elem.parameters->iterate(a; b : Sequence(String) = Sequence{} |
	res->append(a.type.name)
what is the problem? is my query wrong?
thanks
Re: [Acceleo] Nested calls to 'iterate' method [message #509642 is a reply to message #509636] Sat, 23 January 2010 17:43 Go to previous messageGo to next message
Have you tried something like this :
[query public getAllTypes(i : Interface) : Set(T) =
    i.operations.parameters.type->asSet()/]
It should answer to your needs...
Re: [Acceleo] Nested calls to 'iterate' method [message #509650 is a reply to message #509642] Sat, 23 January 2010 20:50 Go to previous messageGo to next message
Sebastien
yes, it is working! thanks...
but i got curious about using nested iterate calls... is it possible?
Re: [Acceleo] Nested calls to 'iterate' method [message #510662 is a reply to message #509650] Thu, 28 January 2010 04:34 Go to previous messageGo to next message
--------------020506040009020106060405
Hi Andre,
Nested iterate calls are possible, but IIRC you have to explicitely
append to the "result" variables in each iterate. That would give
something like
res->union(elem.parameters->iterate(a; res2 : Sequence(String) =
Sequence{} |
res2->append(a.type.name))))
But for the sake of your coworkers or those that will follow after you
to maintain your modules, _avoid_ iterates at all costs : they totally
hinder the readeability of your expressions.
There's pretty much always a way to work around iterates. Sebastien's
solution is way more elegant, but even without that, use specific OCL
loops whenever possible. The "collect", "select", "reject", ...
operations are there to answer specific iteration needs. For exemple,
your expression could be rewrote as
"i.operations->collect(parameters->collect(type.name))"
Laurent Goubet
Obeo
Andre wrote:
> Sebastien
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------020506040009020106060405--
Re: [Acceleo] Nested calls to 'iterate' method [message #510735 is a reply to message #510662] Thu, 28 January 2010 09:06 Go to previous message
Laurent
I dont know why, but for me it's easier to think about iterations than other operations (collect, reject, ...), but i'll try to follow your advice.
thanks,
Previous Topic:[Acceleo] Suggestion : icons for autocompletion
Next Topic:Xpand vs Acceleo vs JET
Current Time: Wed Jul 23 05:37:26 EDT 2025
Powered by FUDForum. Page generated in 0.51199 seconds
