Home » Eclipse Projects » Rich Client Platform (RCP) » Using asyncExec in TitleAreaDialog
Using asyncExec in TitleAreaDialog [message #507702] Thu, 14 January 2010 07:15 Go to next message
Hello!
I created a TitleAreaDialog that does some background processing in
a non-ui thread. The non-ui thread is run in method okPressed().
Now I'm trying to manipulate the UI from the non-ui thread by the
use of Display.asyncExec(). Unfortunately my runnable doesn't get
executed.
There are no exceptions. The dialog is opend in
ApplicationWorkbenchAdvisor.postStartup()
Here's the code of the dialog:
------------------------- SNIP -----------------------------
import org.eclipse.core.runtime.jobs.JobChangeAdapter;
import org.eclipse.jface.dialogs.IDialogConstants;
import org.eclipse.jface.dialogs.TitleAreaDialog;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
import com.swtdesigner.SWTResourceManager;
public class LoginDialog extends TitleAreaDialog {
private Text text_2;
private Text text_1;
private Text text;
private Label label;
* Create the dialog
* @param parentShell
public LoginDialog(Shell parentShell) {
super(parentShell);
* Create contents of the dialog
* @param parent
protected Control createDialogArea(Composite parent) {
label = new Label(container, SWT.NONE);
label.setVisible(false);
label.setText("Prüfen...");
return area;
protected void okPressed() {
final Display display = Display.getDefault();
Thread t = new Thread() {
public void run() {
try {
// some background processing
Thread.sleep(2000);
display.syncExec(new Runnable(){
public void run() {
label.setText("Finished");
LoginDialog.super.okPressed();
} catch (InterruptedException e) {
e.printStackTrace();
t.start();
------------------------------ SNAP -----------------------------
Hope there is someone who can help me with this.
Greetings,
Fabian
Re: Using asyncExec in TitleAreaDialog [message #508202 is a reply to message #507702] Sun, 17 January 2010 10:43 Go to previous messageGo to next message
Hi Fabian,
I don't get the Logindialog.super.okPressed();
What's with the super?
Wim
> Hello!
> executed.
> import org.eclipse.swt.widgets.Display;
> private Text text;
> * Create the dialog
> super(parentShell);
> * @param parent
> @Override
> label.setText("Pr
Re: Using asyncExec in TitleAreaDialog [message #508255 is a reply to message #508202] Mon, 18 January 2010 02:14 Go to previous messageGo to next message
Hi Wim,
By callign LoginDialog.super.okPressed() I intended to refer to
TitleAreaDialog's okPressed() method.
Best regards, Fabian
Re: Using asyncExec in TitleAreaDialog [message #508697 is a reply to message #508255] Tue, 19 January 2010 16:42 Go to previous messageGo to next message
Hi Fabian,
But that does not contain the asyn call...
Best Regards,
Wim Jongman
-- All wiyht. Rho sritched mg kegtops awound?
(Eclipse Old Skool Quote Service)
> Hi Wim,
Re: Using asyncExec in TitleAreaDialog [message #508698 is a reply to message #508697] Tue, 19 January 2010 16:44 Go to previous messageGo to next message
I mean: the super does not contain the call to the synexec.
Best Regards,
Wim Jongman
-- "640K ought to be enough for anybody." - Bill Gates, 1981
> Hi Fabian,
> Best Regards,
> Wim Jongman
>> Hi Wim,
Re: Using asyncExec in TitleAreaDialog [message #508829 is a reply to message #508698] Wed, 20 January 2010 03:54 Go to previous messageGo to next message
Yeah that's right but I don't think that this is the cause.
Using the Eclipse debugger, I can verify that the Runnable
isn't even called by the platform.
Am 19.01.2010 22:44, schrieb Wim Jongman:
Re: Using asyncExec in TitleAreaDialog [message #509497 is a reply to message #508829] Fri, 22 January 2010 11:01 Go to previous messageGo to next message
I've changed your code to a runnable snippet and the Runnable does get run.
Which platform and eclipse version are you using? Does the snippet below
work for you? Do you see any obvious differences between the snippet and
the code in your app?
Display display = new Display();
Shell shell = new Shell(display);
shell.setBounds(10,10,200,200);
shell.open();
new LoginDialog(shell).open();
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) display.sleep();
display.dispose();
super(parentShell);
Composite container = new Composite(parent, SWT.NONE);
container.setLayout(new FillLayout());
//label.setVisible(false);
label.setText("Pr
Re: Using asyncExec in TitleAreaDialog [message #509712 is a reply to message #509497] Mon, 25 January 2010 02:35 Go to previous messageGo to next message
Hello Grant,
your snippet works nicely as I would expect it. I'm using Eclipse RCP
3.4 and Java 1.6.0_17
Do you have any idea why it doesn't work in a rich client app? Maybe
it is because the class is called in
ApplicationWorkbenchAdvisor.postStartup() ???
Re: Using asyncExec in TitleAreaDialog [message #509837 is a reply to message #509712] Mon, 25 January 2010 10:00 Go to previous message
I think that your best bet is to put a breakpoint at your
"display.syncExec(new Runnable(){" line and debug into the syncExec() call
to see if anything happens that prevents your Runnable from being run.
Since syncExec() is supposed to execute the Runnable immediately you should
not have to trace too far to see what's happening.
Grant
"Fabian Dankof" <dankof@abis-reicom.de> wrote in message
news:hjjhh7$8fl$1@build.eclipse.org...
> Hello Grant,
Previous Topic:When is the RCP complete and the rest is done using plug-ins
Next Topic:Activities based on source variables
Current Time: Wed Jul 30 20:15:34 EDT 2025
Powered by FUDForum. Page generated in 0.11357 seconds
