Re: Extending Visual Editor to generate XML instead of Java code [message #618360 is a reply to message #618359] |
Fri, 22 January 2010 09:06  |
We have also some experiences with this architecture. We have developped two
editors: one for XSWT and another for a proprietary UI XML. Our conclusion
is the architetcure is too complicate with VE based on 2 JVMS and JEM. And
the system is not flexible enough. Based on XML, it could be much simple and
powerful. It is what we adopt in XWT Designer.
Best regards
Yves YANG
"Sanjeev" <sanjeevk@invivosoft.com> wrote in message
news:hj9m78$sle$1@build.eclipse.org...
> Try SwixEditor, which is uses some core VE plugins to persist UI in
> swixml. You can download the editor from
> http://www.invivosoft.com/downloads/swixplugins_3.2.25.zip
> This editor can be customized to render any custom xml schema. I can
> provide instructions on building such an editor. I'm also trying to
> opensource swixeditor, and if someone can help me with instructions on how
> to opensource it, I can donate all the code.'
> Thanks
FUDForum. Page generated in 0.26890 seconds
