Home » Eclipse Projects » Standard Widget Toolkit (SWT) » best way to create a tablefolder with lots of button(No more handles problem)
best way to create a tablefolder with lots of button [message #509049] Thu, 21 January 2010 04:43 Go to next message
hi, I have problems to create a tablefolder with lots of element (more than 1000).
there is my code (that I simplified)
import org.eclipse.swt.SWT;
import org.eclipse.swt.custom.TableEditor;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Table;
import org.eclipse.swt.widgets.TableColumn;
import org.eclipse.swt.widgets.TableItem;
public class testframe {
		Display display = new Display();
		Shell shell = new Shell(display);
		shell.setLayout(new FillLayout());
		Table table = new Table(shell, SWT.BORDER | SWT.V_SCROLL);
		table.setLinesVisible(true);
		table.setHeaderVisible(true);
		table.setBounds(0, 0, 800, 500);
		for (int i = 1; i < 11; i++) {
			TableColumn tc = new TableColumn(table, SWT.NONE);
			tc.setText("col :" + i);
			tc.setWidth(100);
		for (int line = 0; line < 10000; line++) {
			System.out.println("line" + line);
			TableItem NCurItem = new TableItem(table, SWT.NONE);
			for (int col = 0; col < 10; col++) {
				TableEditor editor = new TableEditor(table);
				Button button = new Button(table, SWT.CHECK | SWT.CENTER);
				button.pack();
				editor.minimumWidth = button.getSize().x;
				editor.horizontalAlignment = SWT.CENTER;
				editor.setEditor(button, NCurItem, col);
				NCurItem.setData(Integer.toString(col), editor);
		shell.open();
		while (!shell.isDisposed()) {
			if (!display.readAndDispatch())
				display.sleep();
		display.dispose();
I have 2 problem.
first, I have a no more handles problem .
is there a better way to create button (text, spinner)without create a table editor for each column. (but with a listener of cause).
second thing, if I put only 100 lines (replacing 10000).
I have enough handles, but it's very slow to use and it take lot of time to si it.
is there any way to pass trough these problem (slow and no more handles ?) thank you
a++
Re: best way to create a tablefolder with lots of button [message #509099 is a reply to message #509049] Thu, 21 January 2010 06:55 Go to previous messageGo to next message
> than 1000).
> I have 2 problem.
> second thing, if I put only 100 lines (replacing 10000). I have enough
> ?) thank you
I recommend to use a jface TableViewer with check box editors. Check
out
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet056BooleanCellEditor.java?view=markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet061FakedNativeCellEditor.java?view=markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.jface.s nippets/Eclipse%20JFace%20Snippets/org/eclipse/jface/snippet s/viewers/Snippet048TreeViewerTabWithCheckboxFor3_3.java?vie w=markup
You can replace the TreeViewer by a Tableviewer.
HTH & Greetings from Bremen,
Daniel Krügler
Re: best way to create a tablefolder with lots of button [message #509133 is a reply to message #509049] Thu, 21 January 2010 08:29 Go to previous message
thanks,I ll try that
a++
Previous Topic:Problem on eclipse startup:org.eclipse.swt.SWTError: Cannot initialize Drop
Next Topic:Popup location of context menu contributed by a MenuManager
Current Time: Sun Jul 27 03:46:36 EDT 2025
Powered by FUDForum. Page generated in 0.05278 seconds
