Home » Language IDEs » ServerTools (WTP) » extending javascript content assist for script partition of html editor?
extending javascript content assist for script partition of html editor? [message #508969] Wed, 20 January 2010 17:23 Go to next message
Originally posted by: adataylo.cisco.com
I'm trying to build Dojo support into the sse/jsdt provided html/jsp/js
editors (i.e. i don't want to create some new version of these editors
like aptana has). I've been able to get something which approaches what
I want by using the org.eclipse.wst.xml.core.modelQueryExtensions
extension point for html element and attribute content assist, and using
the org.eclipse.wst.jsdt.ui.javaCompletionProposalComputer extension
point for javascript content assist within the javascript editor.
However I cannot seem to find an appropriate way to get my content
assist into a javascript code block within the html editor. I would
think that my org.eclipse.wst.jsdt.ui.javaCompletionProposalComputer
extension would also be applied to that partition of the html editor,
but it doesn't seem to work that way.
Is there any way to do this (other than what I've already tried below)?
I have tried:
1) adding a dojo installation to the build path -- isn't sufficient as
the parser won't pick up anything remotely resembling the level of
content assist that i require
2) providing a custom .js library and using the
org.eclipse.wst.jsdt.core.JsGlobalScopeContainerInitializer /
org.eclipse.wst.jsdt.ui.JsGlobalScopeContainerPage extension points --
content assist shows up, but it takes 20-30 seconds for the content
assist popup to appear (which doesn't appear to be a problem with my .js
file as the same delay can be seen using the internet explorer library).
3) inferencing engine extension (researched but not implemented as i
read some posts in another thread where someone implemented this
extension for dojo and also experienced 20-30 second delays).
Re: extending javascript content assist for script partition of html editor? [message #508983 is a reply to message #508969] Wed, 20 January 2010 19:43 Go to previous messageGo to next message
Currently you could use the provisional extension point:
<extension point="org.eclipse.wst.sse.ui.editorConfiguration">
	<provisionalConfiguration
		type="contentassistprocessor"
		class="org.eclipse.wst.jsdt.web.ui.internal.contentassist.JSDTContentAssistant"
		target="org.eclipse.jst.jsp.SCRIPT.JAVASCRIPT" />
</extension>
(This is an example taken from org.eclipse.wst.jsdt.web.support.jsp/plugin.xml)
But as soon as Bug 258999 you will have much more control over where your content assist suggestions are activated and even would allow you to put them on their own page.
I hope that answers your question.
Blue Skies,
~Ian
Re: extending javascript content assist for script partition of html editor? [message #508993 is a reply to message #508983] Wed, 20 January 2010 22:59 Go to previous messageGo to next message
It appears that this works.
I'm curious however, both the solution that you mention and the
org.eclipse.wst.xml.core.modelQueryExtensions solution I'm already using
both seem to "hijack" the content assist completely. Meaning in this
case, for example, if i want the existing javascript completions to show
up, I either have to extend JSDTContentAssistant or recreate the logic
in that class in some fashion.
If the above is correct then other plugins which also implement these
extensions won't play nice with one another. Will the "proposal cycle"
bugfix you mention in your previous post alleviate this issue? Or am I
missing the mark completely? I can successfully create multiple
extensions for the XML editor, perhaps the others support it as well and
I'm doing something incorrectly?
Re: extending javascript content assist for script partition of html editor? [message #509158 is a reply to message #508993] Thu, 21 January 2010 09:40 Go to previous messageGo to next message
Eclipse User wrote on Wed, 20 January 2010 22:59
I'm glad.
That is strange because in neither case should it be clobbering the results of the other processors. In the case of the provisional content assist extension all processors registered for a given partition type should be asked for their results and have them displayed. And in the case of the model query extension all of the model query extensions should be asked for their results. Though in this case it seems that the use of the provisional content assist extension is the more correct thing to do. But again it should just be adding its results to the other extensions, not clobbering them.
Something you may try is create two provisonal extensions of your own and register them for the same partition type and see if the results of both show up.
Another approach is, it sounds like you may have the WTP code in question loaded in your workspace and if you do you could take a look at StructuredContentAssistnat#getContentAssistProcessor which is the method that loads the provisional content assist extensions.
You are also more then welcome to open a Bugzilla against Source Editor if you are still having issues with the other provisional extensions getting clobbered.
The fix for Bug 258999 definitely has no issue with multiple content assist computers (terminology change for the patch) registered for the same content type and region either displaying on their own content assist page or being appended to existing content assist pages for that region.
Also just so you know the fix for Bug 258999 while providing a much more configurable way of implementing content assist extensions will still load the what will become depreciated provisional content assist extension that is currently in place so if you write something using the current extension mechanism now it should continue to work after the enhancement.
Re: extending javascript content assist for script partition of html editor? [message #509309 is a reply to message #509158] Thu, 21 January 2010 17:40 Go to previous messageGo to next message
> I'm glad.
>> using both seem to "hijack" the content assist completely. Meaning in
>> this case, for example, if i want the existing javascript completions
>> to show up, I either have to extend JSDTContentAssistant or recreate
>> the logic in that class in some fashion.
> both show up.
I was mistaken. Sure enough when i code up 2 plugins as you suggest the
content assist from both plugins shows up (for both modelQueryExtensions
and contentassistprocessor). I did, however, discover what led me to
this false conclusion for javascript. I was testing on a project that
did not have the JS nature, and an NPE will be thrown:
at
org.eclipse.wst.jsdt.ui.text.java.CompletionProposalCollecto r. <init>(CompletionProposalCollector.java:137)
at
org.eclipse.wst.jsdt.web.ui.internal.contentassist.JSDTPropo salCollector. <init>(JSDTProposalCollector.java:50)
when invoking content assist from within the script block of an html or
jsp file. Add the JS nature to the project, and voila the NPE goes away
and the JS completions show up.
I'm currently searching bugzilla to see if this is a known issue. In
the meantime I'll code to the contentassistprocessor extension.
Thanks!
Adam
> getting clobbered.
>> and I'm doing something incorrectly?
> The fix for https://bugs.eclipse.org/bugs/show_bug.cgi?id=258999
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=258999 while providing a
Re: extending javascript content assist for script partition of html editor? [message #509507 is a reply to message #509309] Fri, 22 January 2010 11:27 Go to previous messageGo to next message
Eclipse User wrote on Thu, 21 January 2010 17:40
If you could please report back here with either an existing bug you found or the new bug you open, for documentations sake, that would be much appreciated.
~Ian
Re: extending javascript content assist for script partition of html editor? [message #509568 is a reply to message #509507] Fri, 22 January 2010 19:13 Go to previous message
> much appreciated.
I was unable to find an existing bug. The bug I entered is:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=300585
Adam
Previous Topic:Nothing in WEB-INF!
Next Topic:Eclipse 3.4.2 + WTP-SDK 3.0.5 + FreeBSD 8.0
Current Time: Sat Jul 26 08:08:41 EDT 2025
Powered by FUDForum. Page generated in 0.06820 seconds
