Home » Eclipse Projects » Eclipse Platform » global limit on undo/redo stack
global limit on undo/redo stack [message #508871] Wed, 20 January 2010 10:36 Go to next message
I want to set a global limit on undo/redo stack (as it is a EMF/GMF Operation it is huge...)
I already set limit on each IUndoContext of editor but when we have a lot of opened editor it can be too much.
How can I set a global limit?
Aurelien
Re: global limit on undo/redo stack [message #508883 is a reply to message #508871] Wed, 20 January 2010 11:01 Go to previous messageGo to next message
Aurelien,
There isn't such a global limit.
Aurelien Pupier wrote:
> Regards,
> Aurelien
[SOLVED]Re: global limit on undo/redo stack [message #508895 is a reply to message #508871] Wed, 20 January 2010 11:16 Go to previous message
thanks for your quick reply.
Effectively, reading more carefully some comment in the implementation of DefaultOperationHistory.setLimit :
		 * The limit checking methods interpret a null context as a global limit
		 * to be enforced. We do not wish to support a global limit in this
		 * implementation, so we throw an exception for a null context. The rest
		 * of the implementation can handle a null context, so subclasses can
		 * override this if a global limit is desired.
		Assert.isNotNull(context);
So as it is not possible there is the issue describe in my other post. (free the OperationHistory on editor closed)
Previous Topic:OperationHistory not cleaned after editor closed
Next Topic:Eclipse launcher & max heap size problem
Current Time: Wed Jul 23 01:17:51 EDT 2025
Powered by FUDForum. Page generated in 0.03983 seconds
