Home » Eclipse Projects » Remote Application Platform (RAP) » IFrame based Custom Widget and Incompatibility after RAP Target Update from 1.2.1 to 1.3M4
IFrame based Custom Widget and Incompatibility after RAP Target Update from 1.2.1 to 1.3M4 [message #508714] Tue, 19 January 2010 17:56 Go to next message
We have a Custom Widget (Rich text HTML editor, based on TinyMCE). After
updating from 1.2.1 to 1.3.0 M4 I have detected & solved some problems
with it.
1.) The widget needs now a "backgroundGradient" property:
backgroundGradient : {
check : "Array",
nullable : true,
init : null,
themeable : true
(copy from GfxMixin.js, its not clear why that property is needed here,
that property is used only in one place, in swt theming in
AppearancesBase.js )
2.) The "registry" folder from registered resources is now
"rwt-resources". So that any programmatically access to the registered
resource needs that prefix, e.g. "rwt-resources/tinymce/tinymce.html"
(on 1.2.1 only "tinymce/tinymce.html"), otherwise an 404 error occurs.
So, these are minor changes, but I would like to ask if it so intended?
Nikolai
Re: IFrame based Custom Widget and Incompatibility after RAP Target Update from 1.2.1 to 1.3M4 [message #508816 is a reply to message #508714] Wed, 20 January 2010 08:05 Go to previous messageGo to next message
Hi Nikolai,
in short, yes both changes are intended. Please also see my comments
below for further details.
Rüdiger Herrmann
http://eclipsesource.com
On 19.01.2010 23:56, Nikolai Raitsev wrote:
> with it.
> check : "Array",
> nullable : true,
> init : null,
> themeable : true
I will ask a colleague to answer this, stay tuned...
The "rwt-resources" prefix was introduced with this bug-fix:
281787: Bundle image resources exposed under changing context
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281787
BTW, IResourceManager#getLocation() will return the correct URL.
> Best regards,
> Nikolai
Re: IFrame based Custom Widget and Incompatibility after RAP Target Update from 1.2.1 to 1.3M4 [message #508849 is a reply to message #508714] Wed, 20 January 2010 09:44 Go to previous messageGo to next message
Hi.
> check : "Array",
> nullable : true,
> init : null,
> themeable : true
You are using an appearance in your widgets LCA (Java) or qooxdoo-class
(javascript) that is not compatible, probably "composite" as described
in the Developer Guide. (We need to update this.) If you want to get rid
of the property, i would suggest to use another appearance (e.g. "widget").
Greetings,
Tim
Re: IFrame based Custom Widget and Incompatibility after RAP Target Update from 1.2.1 to 1.3M4 [message #512103 is a reply to message #508816] Wed, 03 February 2010 17:25 Go to previous messageGo to next message
Hi Rüdiger,
thank you for the answer! I have read it, but could not answer.
IResourceManager#getLocation() - thank you for the tip, did not know...:)
Best regards, Nikolai
Rüdiger Herrmann schrieb:
> Hi Nikolai,
> Regards,
Re: IFrame based Custom Widget and Incompatibility after RAP Target Update from 1.2.1 to 1.3M4 [message #512104 is a reply to message #508849] Wed, 03 February 2010 17:30 Go to previous message
Hi Tim,
thank you for the answer,
the Widget on the Java side (not the LCA) extends Composite, not Widget,
maybe is it, what do you mean?
Actually, it is now does not matter, I have solved the problem by
myself. But maybe someone has the same thing and he can find the
solution described here.
Best Regards,
Nikolai
Tim Buschtöns schrieb:
> Hi.
>> check : "Array",
>> nullable : true,
>> init : null,
>> themeable : true
> Greetings,
> Tim
Previous Topic:How to access sessions ?
Next Topic:Plugin version
Current Time: Sun Aug 31 10:25:28 EDT 2025
Powered by FUDForum. Page generated in 0.03827 seconds
