[Mac] Refreshing window does not work well after resize or maximize [message #508782] |
Wed, 20 January 2010 05:08  |
Hi all,
I am having some troubles with our application on MacOS X only. Indeed, when I try to resize or maximize my workbench, refresh of the UI does not work correctly: some of my views become only gray areas (namely the diagram outline and the properties views). The GMF-diagram editor still works, but it also suffer from display issues, for example when using palette.
Once the application arrives in this inconsistent state, it sometimes come back to a normal state when resizing the window.
Did anyone already experienced such a kind of issues? Do you have tips to get it solved?
Thanks in advance,
Mickael Istria - BonitaSoft S.A.
http://www.bonitasoft.com/products/downloads.php
Re: [Mac] Refreshing window does not work well after resize or maximize [message #509490 is a reply to message #508782] |
Fri, 22 January 2010 10:14  |
Hi Mickael,
I have not heard of this before. Questions:
- which eclipse/swt release are you using (Cocoa/Carbon, and version)?
-> if it's an old release, can you try a recent one like
http://download.eclipse.org/eclipse/downloads/drops/S-3.6M4- 200912101301/index.php ?
- does it happen for you with stand-alone eclipse, or just with your app?
- are you able to provide some means of reproducing the problem (eg.- a
minimal implementation of your app that shows it happening)?
-> if so then I would suggest logging a bug with swt at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform &component=SWT
- can you think of any other info that could be helpful in attempting to
diagnose this from afar?
Grant
"Mickael Istria" <mickael.istria@bonitasoft.com> wrote in message
news:hj6kmc$qn0$1@build.eclipse.org...
> Hi all,
get it solved?
> Thanks in advance,
FUDForum. Page generated in 0.03271 seconds
