[EMF Compare] Comparing Strings [message #508623] |
Tue, 19 January 2010 11:24  |
Hi.
I'm using Xtext and am trying to compare 2 files to check if the serialization behaves as supposed to. If I remove or add model elements, everything works fine and the changes are recognized. But changes in attributes that hold Strings seem not to be compared. So if I edit the content of an attribute that is of kind String, these changes are not computed. Do you have any hint for this kind of problem?
Roland
[Updated on: Wed, 20 January 2010 02:09] by Moderator
Re: [EMF Compare] Comparing Strings [message #510350 is a reply to message #509126] |
Wed, 27 January 2010 00:38   |
--------------040508030803070509010608
Hi Roland,
Sorry for the delay, didn't realize you had answered.
We've never faced this issue : names and other Strings are compared as
everything else, there is no special handling for EString-typed attributes.
I'll need the two models you're trying to compare in order to try and
help you any more than this, or basic samples to reproduce the issue.
Laurent Goubet
Obeo
PS : you should use MatchService.doMatch() instead of instantiating the
GenericMatchEngine and calling its "modelMatch()" method yourself.
Roland S. wrote:
> Hi Laurent,
> my code looks like:
> Map<String, Object> options = new HashMap<String, Object>();
> GenericMatchEngine gme = new GenericMatchEngine();
> options.put(MatchOptions.OPTION_DISTINCT_METAMODELS, false);
> options.put(MatchOptions.OPTION_IGNORE_ID, true);
> options.put(MatchOptions.OPTION_IGNORE_XMI_ID, true);
> EObject model1 = loader.loadModel(path1);
> EObject model2 = loader.loadModel(path2);
> MatchModel match = gme.modelMatch(model1, model2,options);
> where model1 is the original file that is parsed by the ANTLR-parser
> generated with Xtext. Model2 represents the modified text file. The
> files contain classes similar to Java-classes. The class name is an
> attribute of type EString. When i change this name the difference is not
> recoqnized by modelMath().
> I hope this helps.
> Roland
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040508030803070509010608--
Re: [EMF Compare] Comparing Strings [message #622050 is a reply to message #622028] |
Wed, 27 January 2010 05:36  |
Hi Roland,
Laurent Goubet
Obeo
Roland S. wrote:
> Hi Laurent,
> my code looks like:
> I hope this helps.
> Roland
FUDForum. Page generated in 0.04490 seconds
