Generating editor with limited functionality [message #474413] |
Wed, 21 May 2008 05:38  |
Originally posted by: gingin4.gmail.com
for a project work I need to create an UML editor (probably only
implementing state machine diagrams) with limited functionality (I only
need a few tools, not the whole palette available when using the standard
UML2Tools editor).
Additionally, I want to implement some constraints to further limit or
check drawn diagrams. Finally, the diagram should be saved as a textual
UML2 representation to be used with other tools.
I tried different approaches (for example I tried using the GMF
tutorial/cheat sheet with the UML2.ecore and .genmodel files - waaaaay too
complex), but it seems that a light-weight extension with profiles would
be the best way. I found the slides and example from EclipseCon 2008
(#172), but I'm not sure on how to adapt those to my specific requirements.
It would be highly appreciated if somebody could point me into the right
direction, as I feel a bit lost at the moment. Some small steps on how to
start would be very helpful!
Best regards, Stefan
Re: Generating editor with limited functionality [message #625429 is a reply to message #474444] |
Tue, 19 January 2010 09:59  |
Hi!
it's been a long time since you've asked your question and i just found it as i'm looking to solve similar problem as the current UML2Tools state machine editor doesn't display transition labels properly and i wanted to restrict functionality too.
Did you find the solution? Or maybe someone else did?
Galina
FUDForum. Page generated in 0.04854 seconds
