Home » Eclipse Projects » Remote Application Platform (RAP) » How to start RAP from command line ?
How to start RAP from command line ? [message #508514] Tue, 19 January 2010 04:47 Go to next message
Thanks.
Re: How to start RAP from command line ? [message #508548 is a reply to message #508514] Tue, 19 January 2010 06:58 Go to previous messageGo to next message
I recommend reading the Introduction and Getting started pages on the
RAP homepage (www.eclipse.org/rap). Doing so you'll learn that RAP
applications are typically deployed in a Web container.
If you have more concrete questions feel free to ask :-)
Stefan.
Re: How to start RAP from command line ? [message #508560 is a reply to message #508548] Tue, 19 January 2010 07:55 Go to previous messageGo to next message
Stefan Röck wrote on Tue, 19 January 2010 06:58
If you have more concrete questions feel free to ask Smile
Stefan.
Thanks Stefan.
I will try to describe our issue:
We have some console application as Eclipse Equinox application. And we would like to try add some web-face to our console application by RAP and we don't want to use tomcat or other AppServer, Jetty is quite enough. How can we start RAP as eclipse equinox application from command line ? I tried do like that but it is not working:
eclipse.exe -configuration_rap -console -consolelog -noSplash
config.ini
osgi.bundles=reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.commands_3.5.0.I20090525-2000.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.design.example_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.expressions_3.4.100.v20091203.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.registry_3.5.0.v20091203.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.osgi.services_3.2.0.v20090520-1800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.jdt.junit.runtime_3.4.200.v20091207-1800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.common_3.6.0.v20091203.jar@2\:start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.junit_1.3.0.20091214-1156@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.ui.views_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.databinding.beans_1.2.0.I20091117-0800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.ui.forms_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.mortbay.jetty.util_6.1.15.v200905182336.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.help_3.5.0.v20091130.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.junit.runtime_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.rwt_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/javax.servlet_2.5.0.v200910301333.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.contenttype_3.4.100.v20091109.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.ui.cheatsheets_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.app_1.2.100.v20091203.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.jobs_3.5.0.v20091125-1620.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.jface.databinding_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.databinding.property_1.2.100.I20090825-0800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/com.ibm.icu.base_4.0.1.v20090822.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.databinding_1.3.0.I20090825-0800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.preferences_3.3.0.v20091203.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.mortbay.jetty.server_6.1.15.v200905151201.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.databinding.observable_1.3.0.I20090901-0800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.junit_3.8.2.v20090203-1005@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.core.runtime_3.6.0.v20091204.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.rwt.q07_1.3.0.20091214-1156.jar,reference\:file\:C\:/Eclipse/BEST/BestRap@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.jface_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.ui_1.3.0.20091214-1156.jar@start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.rap.ui.workbench_1.3.0.20091214-1156.jar@start
osgi.bundles.defaultStartLevel=4
osgi.install.area=file\:C\:\\Eclipse\\3.5\\configuration-rap\\eclipse
osgi.framework=file\:C\:/Eclipse/3.5/configuration-rap/eclipse/plugins/org.eclipse.osgi_3.6.0.v20091204.jar
osgi.configuration.cascaded=false
osgi.noShutdown=true
eclipse.ignoreApp=true
org.osgi.service.http.port=10081
Re: How to start RAP from command line ? [message #508565 is a reply to message #508560] Tue, 19 January 2010 07:58 Go to previous message
Hi Rustam,
there is a FAQ entry that describes how to deploy RAP with an embedded
jetty:
http://wiki.eclipse.org/RAP/FAQ#How_do_I_use_a_RAP_standalon e_application_with_an_embedded_server
Hope that helps.
Benny
>> If you have more concrete questions feel free to ask :)
>> Regards,
>> Stefan.
> Thanks Stefan. I will try to describe our issue: We have some console
> config.ini
> osgi.bundles=reference\:file\:C\:/Eclipse/3.5/configuration- rap/eclipse/plugins/org.eclipse.core.commands_3.5.0.I20090525-2000.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.design.example_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.expressions_3.4.100.v20091203.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.equinox.registry_3.5.0.v20091203.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.osgi.services_3.2.0.v20090520-1800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.jdt.junit.runtime_3.4.200.v20091207-1800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.equinox.common_3.6.0.v20091203.jar@2 \:start,reference\:file\:C\:/Eclipse/3.5/configuration-rap/e clipse/plugins/org.eclipse.rap.junit_1.3.0.20091
214-1156@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.ui.views_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.databinding.beans_1.2.0.I20091117-0800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.ui.forms_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.mortbay.jetty.util_6.1.15.v200905182336.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.equinox.http.servlet_1.0.200.v20090520-1800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.help_3.5.0.v20091130.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.junit.runtime_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.rwt_1.3.0.20091214-1156.
jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/javax.servlet_2.5.0.v200910301333.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.contenttype_3.4.100.v20091109.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.ui.cheatsheets_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.equinox.app_1.2.100.v20091203.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.jobs_3.5.0.v20091125-1620.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.jface.databinding_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.databinding.property_1.2.100.I2009
0825-0800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/com.ibm.icu.base_4.0.1.v20090822.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.databinding_1.3.0.I20090825-0800.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.equinox.preferences_3.3.0.v20091203.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.mortbay.jetty.server_6.1.15.v200905151201.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/ org.eclipse.core.databinding.observable_1.3.0.I20090901-0800 .jar @start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.junit_3.8.2.v20090203-1005@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.core.runtime_3.6.0.v20091204.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.rwt.q07_1.3.0.20091214-1156.jar,refe rence\
:file\:C\:/Eclipse/BEST/BestRap@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.jface_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/ org.eclipse.equinox.http.registry_1.0.200.v20090520-1800.jar @start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.ui_1.3.0.20091214-1156.jar@start ,reference\:file\:C\:/Eclipse/3.5/configuration-rap/eclipse/ plugins/org.eclipse.rap.ui.workbench_1.3.0.20091214-1156.jar@start
> osgi.install.area=file\:C\:\\Eclipse\\3.5\\configuration-rap \\eclipse
> osgi.framework=file\:C\:/Eclipse/3.5/configuration-rap/eclip se/plugins/org.eclipse.osgi_3.6.0.v20091204.jar
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Previous Topic:How to use lables from IDialogConstants for use with RCP and RAP (SingleSource)
Next Topic:Key event handling in RAP
Current Time: Tue Jul 22 22:23:22 EDT 2025
Powered by FUDForum. Page generated in 0.29465 seconds
