Home » Archived » M2M (model-to-model transformation) » [QVTo] How to export QVTo transformation as Eclipse-plugin
[QVTo] How to export QVTo transformation as Eclipse-plugin [message #504716] Tue, 22 December 2009 00:31 Go to next message
Hi everybody,
I developed a QVTo transformation in Eclipse and I want to know how it can be used for generating a jar file. Indeed, I want to call this transformation from a java program. This java program will be exported as Jar or exe file. (And of course I want that the Jar or Exe file works independently from eclipse)
Thank you for your help
Kaloutcha
Re: [QVTo] How to export QVTo transformation as Eclipse-plugin [message #504717 is a reply to message #504716] Tue, 22 December 2009 05:33 Go to previous messageGo to next message
I forget to say that I am using the Eclipse GanyMEDE
Re: [QVTo] How to export QVTo transformation as Eclipse-plugin [message #504769 is a reply to message #504716] Tue, 22 December 2009 09:42 Go to previous messageGo to next message
Originally posted by: dvorak.radek.gmail.com
Hi Kaloutcha,
I recommend to use a more recent release of QVTo.
There is a new Java invocation API since the Galileo release,
see http://wiki.eclipse.org/QVTOML/Examples/InvokeInJava
The standalone execution (outside Eclipse) feature has been added
in Helios M4 build, published this week.
In this case you invoke your transformation programmatically via the API
mentioned above.
Required dependencies:
org.eclipse.emf.ecore_2.6.0.v200912121603.jar
org.eclipse.emf.common_2.6.0.v200912121603.jar
org.eclipse.emf.ecore.xmi_2.5.0.v200912121603.jar
net.sourceforge.lpg.lpgjavaruntime_1.1.0.v200803061910.jar
org.eclipse.ocl_3.0.0.v200912161120.jar
org.eclipse.ocl.ecore_3.0.0.v200912161120.jar
-- QVTo jars ----------
org.eclipse.m2m.qvt.oml
org.eclipse.m2m.qvt.oml.common
org.eclipse.m2m.qvt.oml.cst.parser
org.eclipse.m2m.qvt.oml.emf.util
org.eclipse.m2m.qvt.oml.ecore.imperativeocl
For package (metamodel) registry, resource factories initialization see
http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F
I will create a wiki page about that.
/Radek
On Tue, 22 Dec 2009 06:31:25 +0100, Kaloutcha <ahmedmekki2000@yahoo.fr>
wrote:
> Hi everybody,
> Regards
> Kaloutcha
Re: [QVTo] How to export QVTo transformation as Eclipse-plugin [message #504863 is a reply to message #504769] Tue, 22 December 2009 22:14 Go to previous messageGo to next message
Hi Radek,
Thank you for your response and I am looking forward for your wiki page that you will create
Kaloutcha
Re: [QVTo] How to export QVTo transformation as Eclipse-plugin [message #508110 is a reply to message #504769] Fri, 15 January 2010 18:50 Go to previous messageGo to next message
How about a minimal headless Eclipse (or standalone OSGi) runtime configuration?
E.g. org.eclipse.m2m.qvt.common depends on both org.eclipse.debug.core and org.eclipse.pde.core ... which I guess are not actually needed for a minimal runtime ...
Re: [QVTo] How to export QVTo transformation as Eclipse-plugin [message #508301 is a reply to message #508110] Mon, 18 January 2010 01:10 Go to previous message
Hi Alex,
There is still some dependency cleanup job to do here.
The 'org.eclipse.m2m.qvt.common', 'org.eclipse.m2m.qvt.oml.emf.util'
bundles should
actually be eliminated from the standalone runtime configuration too.
We just did not manage to do it for M4. However, it should work fine if
no Eclipse dependency is present at runtime.
/Radek
> configuration?
> minimal runtime ...
Previous Topic:[ATL] ATL data types
Next Topic:[QVTO] How to work with inheritance
Current Time: Sun Jul 20 20:58:17 EDT 2025
Powered by FUDForum. Page generated in 0.04439 seconds
