Home » Modeling » M2T (model-to-text transformation) » [xpand] dynamic expansion of template
[xpand] dynamic expansion of template [message #508215] Sun, 17 January 2010 07:58 Go to next message
I just noticed that bug 161915 was closed due to some move operations, but it
doesn't look like the issue has been resolved... This is about determining the
name of the template to expand dynamically at runtime. I could really use this
feature because I do a lot of M2MT before the actual code generation and the
class and method names all come from the transformed model. Without the
dynamic expansion, I have to use a rather unpleasant IF - ELSEIF
sequence. Perhaps this bug should be re-opened?
Volker
* Volker Wegert * http://www.volker-wegert.de/contact *
"With sufficient thrust, pigs fly just fine. However, this is not necessarily
a good idea. It is hard to be sure where they are going to land, and it could
be dangerous sitting under them as they fly overhead." (RFC 1925)
Re: [xpand] dynamic expansion of template [message #508226 is a reply to message #508215] Sun, 17 January 2010 16:21 Go to previous messageGo to next message
Hi Volker,
I believe, the old bug you mentioned is related to the bug I opened in the Eclipse Bugzilla some time ago: 288536.
Joerg
Re: [xpand] dynamic expansion of template [message #508267 is a reply to message #508226] Mon, 18 January 2010 03:25 Go to previous messageGo to next message
Hi Volker, Joerg,
it is now possible to inject the ExecutionContext
into the JavaExtension. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=261603
Can you imagine to solve your use case with that capability?
Can we close bug 288536 as well?
Sven
Joerg Reichert schrieb:
> Hi Volker,
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=288536
> Joerg
Need professional support for Xtext and EMF?
Go to: http://xtext.itemis.com
Twitter : @svenefftinge
Blog : blog.efftinge.de
Re: [xpand] dynamic expansion of template [message #509120 is a reply to message #508226] Thu, 21 January 2010 07:50 Go to previous messageGo to next message
Joerg Reichert <joerg.reichert@itemis.de> writes:
I don't think so. Your bug is about Xtend, I'm talking of making the EXPAND
target in the Xpand language dynamic. Or did I misunderstand you?
Volker
"INTEL inside" - The world's most widely used warning label.
Re: [xpand] dynamic expansion of template [message #509121 is a reply to message #508267] Thu, 21 January 2010 07:57 Go to previous messageGo to next message
Sven Efftinge <sven.efftinge@itemis.de> writes:
In my case no. What I need is
<<EXPAND getTemplateName(...) FOR foo>>
where getTemplateName is an *expression* that returns the actual name of the
template to expand. Maybe some syntactical tweak is required because
getTemplateName is a name that actually might be DEFINEd - so probably this
would be something like
<<EXPAND @getTemplateName(...) FOR foo>>
to designate a dynamic expansion.
My current workaround is really ugly and hard to maintain:
<<IF getTemplateName(...) == "Foo">>
<<EXPAND generateFoo FOR this>>
<<ELSEIF getTemplateName(...) == "Bar">>
<<EXPAND generateBar FOR this>>
....and so on. A total of 300+ lines of this stuff, enough to hide a lot of
typos.
Volker
"In the spirit of taking things too far, here is a fully functional
5-dimensional analog of Rubik's cube."
(http://www.gravitation3d.com/magiccube5d/)
Re: [xpand] dynamic expansion of template [message #509658 is a reply to message #509121] Sun, 24 January 2010 07:37 Go to previous messageGo to next message
> typos.
So your intend basically is to invoke templates reflectively? Given the
templates are fixed, one could generate the dispatcher template you outline
above automatically. The Xpand parser can be used to find out which
templates there are. EMF generates the Model-Switch classes to handle type
hierarchies in a similar way.
Alternatively, with Sven's remark concerning Java-instance invocations
(#261603) and his idea to treat template expansion like invocations
(#299311), it might be possible to write a reflective dispatcher as Java
extension.
Erhard
Re: [xpand] dynamic expansion of template [message #509667 is a reply to message #508267] Sun, 24 January 2010 10:03 Go to previous messageGo to next message
Hi Sven,
the fix of the bug 261603 indeed enables me to meet my requirement:
project structure:
project
+ src
++ javaextension
+++ Helper.java
++ template
+++ Template.xpt
+++ GeneratorExtension.ext
+++ OtherExtension.ext
Template.xpt
«IMPORT ...»
«EXTENSION template::GeneratorExtensions»
«DEFINE ... FOR ...»
	«FILE "test.txt"»
		«helloWorld()»
	«ENDFILE»
«ENDDEFINE»
import ...;
String helloWorld() : JAVA javaextension.Helper.getHelloWorld();
Here is one thing to fix: the Xtend editor creates still a marker complaining that "The method getHelloWorld is not public static". This check have to be removed from the editor implementation.
OtherExtension.ext
import ...;
String getWorld() : "World";
Helper.java
public class Helper implements IExecutionContextAware {
	private String hello;
	public Helper() {
		hello = "Hello";
	public String getHelloWorld() {
		ExtensionFile file;
		String result = "unknown";
		try {
			file = ParseFacade.file(new FileReader(new File(
					"src/template/OtherExtension.ext")), "OtherExtension");
			ExecutionContextImpl ec = (ExecutionContextImpl) getExecutionContext()
					.cloneWithResource(file);
			ExpressionFacade ef = new ExpressionFacade(ec);
			result = (String) ef.evaluate("getWorld()");
			// setExecutionContext(ec);
		} catch (FileNotFoundException e) {
			e.printStackTrace();
		return hello + " " + result;
	private ExecutionContext ctx;
	public ExecutionContext getExecutionContext() {
		return ctx;
	public void setExecutionContext(ExecutionContext ctx) {
		this.ctx = ctx;
that eventually will produce
generated test.txt
Hello World
conclusion
The solution above only works for Xtend (as the injected ExecutionContext is only able to execute extensions). As I looked into the code it seems not to be possible to enhance the JavaExtensionStatement implementation to also inject the XpandExecutionContext that would enable to call a template method dynamically with that kind of code:
    XpandExecutionContext xpandContext = get XpandExecutionContext();
    XpandFacade facade = XpandFacade.create(xpandContext);
    facade.evaluate("templates::TemplateFile::defineMethod", modelElement);
So it seems to be reasonable to enhance the Xpand language with such a feature as Volker proposed.
Joerg
Re: [xpand] dynamic expansion of template [message #509670 is a reply to message #509120] Sun, 24 January 2010 10:09 Go to previous messageGo to next message
Hi Volker,
no you didn't. Without having tested it before I had assumed that the solution for Xtend would be adaptable for Xpand, too. But it isn't as I pointed out in my previous post.
Joerg
Re: [xpand] dynamic expansion of template [message #510034 is a reply to message #509670] Tue, 26 January 2010 04:55 Go to previous message
The injected ExecutionContext actually is an XpandExecutionContext, if
the extension was invoked from an Xpand context (i.e. an Xpand generator
component).
The following code does the trick:
this.ctx = ctx;
public void invokeXpand(Object target, String definition) {
if (ctx instanceof XpandExecutionContext) {
XpandExecutionContext ctx2 = (XpandExecutionContext) ctx;
XpandFacade.create(ctx2).evaluate(definition, target);
Note, that the definition has to be qualified.
Sven
> Hi Volker,
> Joerg
Previous Topic:Howto run MWE workflow programmatically with classpath?
Next Topic:[JET] Break or continue for <c:iterate>
Current Time: Sat Jul 26 08:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.07375 seconds
