Home » Eclipse Projects » Rich Client Platform (RCP) » RCP : Create custom Help (PDF file) from Menu("Help" menu item must open a PDF help file(created by me))
RCP : Create custom Help (PDF file) from Menu [message #507906] Fri, 15 January 2010 00:59 Go to next message
Hi all,
I have an RCP application. I want to create a menu item called as Help Content within the Help menu. However, instead of using the usual Eclipse help plugin, I want this menu item to open a pdf file that was created by me.. This pdf file has all the help contents...
How do we go about doing this? Tried searching in the net for this for 2 days continuously... all I came across was how to use Eclipse help plug ins in RCP (which I don't need!)
I hope I am clear enough.
Thx.
Re: RCP : Create custom Help (PDF file) from Menu [message #508048 is a reply to message #507906] Fri, 15 January 2010 11:40 Go to previous message
On Fri, 15 Jan 2010 00:59:32 -0500, Karan wrote:
> Hi all,
You can use the SWT Broswer object and give it the URL path.
Previous Topic:Creating a sidebar - how can I resize a view programatically?
Next Topic:Update mechanism & feature versions
Current Time: Sat Jul 26 08:44:29 EDT 2025
Powered by FUDForum. Page generated in 0.03969 seconds
