Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Many browser widgets in many threads
Many browser widgets in many threads [message #507952] Fri, 15 January 2010 04:54 Go to next message
Hi all, I'm facing a problem during the development of a test tool that implements the simulation of many different page requests from many browser instances.
I'm on a WinXP Sp2 box w/ JDK 1.6.0_16, Galileo Eclipse, Eclipse SDK 3.5.1 and SWT 3.555.
With the two following classes:
Test.java
import java.util.ArrayList;
import org.eclipse.swt.*;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.browser.*;
import org.eclipse.swt.layout.*;
public class Test {
* @param args
* @throws InterruptedException
public static void main(String[] args) throws InterruptedException {
Display display = new Display();
ArrayList<BrowserThread> brThreads = new ArrayList<BrowserThread>();
String[] sites = {"http://www.ansa.it", "http://www.apple.com"};
try {
for(String value : sites) {
BrowserThread brThr = new BrowserThread(display, value);
brThreads.add(brThr);
brThr.start();
for (BrowserThread brThr: brThreads) {
if (brThr.isAlive()) {
brThr.join();
} catch (SWTError e) {
System.out.println("Could not instantiate Browser: " + e.getMessage());
//shell.dispose();
return;
//display.dispose();
and BrowserThread.java
import org.eclipse.swt.SWT;
import org.eclipse.swt.SWTError;
import org.eclipse.swt.browser.Browser;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Shell;
* @author 11612764
public class BrowserThread extends Thread {
private Display display;
private Shell shell;
private String url;
BrowserThread(Display display, String url) {
this.display = display;
this.url = url;
this.shell = new Shell(display);
shell.setLayout(new FillLayout());
shell.setText(url);
public void run() {
Browser browser;
try {
browser = new Browser(this.shell, SWT.NONE);
shell.open();
browser.setUrl(url);
while (!shell.isDisposed()) {
if (!display.readAndDispatch()) Thread.sleep(5000);
shell.dispose();
shell.dispose();
return;
} catch (InterruptedException e) {
e.printStackTrace();
I obtained the following error:
Exception in thread "Thread-0" org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(Unknown Source)
at org.eclipse.swt.widgets.Widget.error(Unknown Source)
at org.eclipse.swt.widgets.Widget.checkWidget(Unknown Source)
at org.eclipse.swt.widgets.Widget.checkParent(Unknown Source)
at org.eclipse.swt.widgets.Widget.<init>(Unknown Source)
at org.eclipse.swt.widgets.Control.<init>(Unknown Source)
at org.eclipse.swt.widgets.Scrollable.<init>(Unknown Source)
at org.eclipse.swt.widgets.Composite.<init>(Unknown Source)
at org.eclipse.swt.browser.Browser.<init>(Unknown Source)
at BrowserThread.run(BrowserThread.java:30)
Exception in thread "Thread-1" org.eclipse.swt.SWTException: Invalid thread access
Any advice?
Thank you
Rob
Re: Many browser widgets in many threads [message #508018 is a reply to message #507952] Fri, 15 January 2010 10:08 Go to previous messageGo to next message
See http://www.eclipse.org/swt/faq.php#uithread , all swt interactions must
be on the main UI thread.
Grant
"nysalsa" <nysalsa@hotmail.it> wrote in message
news:hipe0n$g8o$1@build.eclipse.org...
instances.
and SWT 3.555.
> Test.java
> public class Test {
> * @param args
> try {
> brThr.start();
> brThr.join();
> //shell.dispose();
> return;
> import org.eclipse.swt.widgets.Display;
> * @author 11612764
> private String url;
> this.url = url;
> shell.setText(url);
> public void run() {
> Browser browser;
> try {
> shell.open();
> shell.dispose();
> shell.dispose();
> return;
thread access
thread access
> Any advice?
> Thank you
> Rob
Re: Many browser widgets in many threads [message #508804 is a reply to message #507952] Wed, 20 January 2010 06:48 Go to previous messageGo to next message
Thank you Grant, I understood in another way that part of the documentation (my fault... sorry).
This drives a question: having to simulate many user page-requests with pre-defined gap between then (i.e. 4 secs between the first and the second one) how can I do that ?
I read that the page rendering is asynchronous but it seems that that second request waits for the complete page rendering of the first one.
What I'm missing ?
Thank you in advance
Rob
Re: Many browser widgets in many threads [message #508874 is a reply to message #508804] Wed, 20 January 2010 10:46 Go to previous message
You can use Display.timerExec() to execute something after a specified
number of milliseconds has passed, for an example of this see
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.swt.sni ppets/src/org/eclipse/swt/snippets/Snippet16.java?view=co .
The native browsers generally should not wait for a page rendering to
complete if a setUrl() or setText() is issued in the meantime, though it's
ultimately up to the native browser implementation to handle this. If you
want to be notified of when a page load completes then you can add a
ProgressListener to the Browser and its completed() method will be invoked.
Grant
news:hj6qjd$1g2$1@build.eclipse.org...
> What I'm missing ?
> Rob
Previous Topic:SWT painting performance
Next Topic:Customizing Traverse-keys for ColumnViewerEditor
Current Time: Sun Jul 27 07:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.03419 seconds
