Listen to selection changes in properties view [message #507948] |
Fri, 15 January 2010 04:48  |
How can I add a listener (and which one) to listen to selection changes in the default properties view. There will no modification, just a selection change.
I tried the IPropertyChangeListener, but this does't seems to work.
mnhg
Re: Listen to selection changes in properties view [message #509389 is a reply to message #507948] |
Fri, 22 January 2010 05:52   |
I found a solution, which seems to work.
First i created my own SelectionProvider to get the selection from my treeviewer and from the propertyview in one provider.
TreeViewer treeViewer=....
MergedSelectionProvider selectionProvider = new MergedSelectionProvider();
treeViewer.addSelectionChangedListener(new ViewerSelectionForwarder(selectionProvider, treeViewer));
getSite().getPage().addSelectionListener(new PropertySelectionForwarder(selectionProvider, treeViewer));
getSite().setSelectionProvider(selectionProvider);
public class MergedSelectionProvider implements ISelectionProvider {
Set<ISelectionChangedListener> listeners = new HashSet<ISelectionChangedListener>();
IStructuredSelection selection = new StructuredSelection();
public void addSelectionChangedListener(ISelectionChangedListener listener) {
listeners.add(listener);
public void removeSelectionChangedListener(
// listeners.remove(listener);
// Not allowed do remove any listener, otherwise nobody listen to the property view
public ISelection getSelection() {
return selection;
public void setSelection(ISelection selection) {
setSelection(this, selection);
public void setSelection(ISelectionProvider provider, ISelection selection) {
if (selection != this.selection) {
this.selection = (IStructuredSelection) selection;
fireSelectionChanged(new SelectionChangedEvent(provider,
this.selection));
private void fireSelectionChanged(final SelectionChangedEvent event) {
for (final ISelectionChangedListener listener : listeners) {
SafeRunnable.run(new SafeRunnable() {
public void run() {
listener.selectionChanged(event);
The following class only forwards the selection changes of the viewer.
public class ViewerSelectionForwarder implements ISelectionChangedListener {
MergedSelectionProvider provider;
Viewer viewer;
public ViewerSelectionForwarder(MergedSelectionProvider provider,
Viewer viewer) {
this.provider = provider;
this.viewer = viewer;
public void selectionChanged(SelectionChangedEvent event) {
provider.setSelection(viewer, event.getSelection());
This class get the selection in the property view directly from the tree control. In my conrete scenario i could get by the name of the tree item and the selected parent element in the viewer to the selected attribute. It's not the nices solution but it's seem to work for my case.
public class PropertySelectionForwarder implements ISelectionListener,
SelectionListener {
Set<PropertySheet> properties = new HashSet<PropertySheet>();
Viewer viewer;
public PropertySelectionForwarder(MergedSelectionProvider provider,
Viewer viewer) {
// Register property view
public void selectionChanged(IWorkbenchPart part, ISelection selection) {
if (part instanceof PropertySheet && !properties.contains(part)) {
PropertySheetPage p = (PropertySheetPage) ((PropertySheet) part)
.getCurrentPage();
Tree t = (Tree) p.getControl();
t.addSelectionListener(this);
properties.add((PropertySheet) part);
// selection change in property view
public void widgetDefaultSelected(SelectionEvent e) { // ignore
public void widgetSelected(SelectionEvent e) {
if (!(e.item instanceof TreeItem)
|| !(viewer.getSelection() instanceof IStructuredSelection)) {
fireSelection(new StructuredSelection());
return;
IStructuredSelection sel = (IStructuredSelection) viewer.getSelection();
if (sel.size() != 1
|| !(sel.getFirstElement() instanceof XMLEditorElement)) {
return;
TreeItem t = (TreeItem) e.item;
if (!(t.getData() instanceof PropertySheetEntry)) {
return;
XMLEditorElement parent = (XMLEditorElement) sel.getFirstElement();
PropertySheetEntry pse = (PropertySheetEntry) t.getData();
XMLEditorAttribute attribute = parent.getAttributeByName(pse
.getDisplayName());
fireSelection(new StructuredSelection(attribute));
private void fireSelection(IStructuredSelection selection) {
provider.setSelection(selection);
Any opinions, suggestions or error?
FUDForum. Page generated in 0.03540 seconds
